Old 02-12-2018, 06:48 PM
WisconsinHick1's Avatar
WisconsinHick1 WisconsinHick1 is offline
Default Remote Oil Filter Setup?
What manufacturers should I look into to remote mount an oil filter setup? My drag truck engine plate setup will not allow enough room for a standard oil filter setup so I am needing to remote mount it.
Any info would be great thanks.
Green Bean Out
The Rag In
Old 02-12-2018, 09:58 PM
RPM Motorsports's Avatar
smokinum
Cut the flange off the factory cooler and tap the back side NPT for AN fittings. Run the two hoses to a Moroso remote mount
(Russ)
17 CC/SB L5P 4x4 High Country
73 RC/NB LBZ Nova Grocery getter
Old 02-13-2018, 12:43 PM
diesel-max's Avatar
diesel-max diesel-max is offline
Haisley Never heard of her
Wagler has a billet plate that bolts onto the side of the motor that's threaded for like -10 or -12 lines.
Its affordable to, like $75 or something, I don't really remember what it was. I have that on my pulling motor, going to one of these; https://pitstopusa.com/i-19454917-pe...ead-10-an.html
and using a WIX racing filter.
the Oberg and Clearview filters are great as well if you have the money to spend on one.
1996 F-250 LLY Pullin truck....... 3.0 Smoothbore "Dirty Secret"
Huge thanks to: Wagler Competition Products, and Mark B. @Danville performance!
'15.5 Denali HD LML.
Exhaust,Tuned, Ratio Tec, twin Kennedy lift pumps.
'05 Twin turbo LLY.
LBZ Block, LBZ S&S 150% overs, LBZ heads, Callies CompStar, Wagler Street rods, Wagler Comp Stg. 2 Camshaft, Hamilton springs, Smith bro. Pushrods, ARP head/main/rockershafts, Dual CP3's, Michiana Diesel built Allison/ 1074-3D Suncoast converter, twins/DP VGT and StainlessDiesel S485/96/1.10 5Blade
Old 02-13-2018, 07:05 PM
countrycorey's Avatar
countrycorey countrycorey is offline
Trust Me I'm an Engineer
Are the wix racing filters that good?
Sent from my SAMSUNG-SM-G930A using Tapatalk
2007 Chevy Classic CCSB LS 4x4 w/ LBZ & 6 Spd Ally
Graystone Metallic
295/70/17 Nitto Trail Grapplers on Chrome H2s w/ LMM Centers
Custom CamLocker Toolbox
Grizzly Nerf Bars
Pioneer 4100 Head Unit
JL Audio Components
Sportsman Max4 Seat Covers
MPI GT4202/Stock
HSP Coolant Tank
Tinted Windows
MBRP 5"
PCV Rerouted
EGR Blocker & Fingerstick
Nicktane 1 Micron Filter & Adapter
Banks Hot Side Intercooler Tube
ProFab Y-Bridge and 3" Cold Side Boost Tube
AutoMeter Phantom II Boost and EGT on A-Pillar
Hammerhead Armor Replacement Front Bumper
EFILive from IdahoRob
Fleece All On Mod
Old 02-13-2018, 09:46 PM
PureHybrid's Avatar
Isuzu Shakes IT
They are good filters, but protection isn't their main purpose.
Jesse
Old 02-14-2018, 06:17 AM
Understood
Graystone Metallic
Grizzly Nerf Bars
JL Audio Components
MPI GT4202/Stock
HSP Coolant Tank
Tinted Windows
MBRP 5"
PCV Rerouted
Fleece All On Mod
Old 02-20-2018, 08:07 PM
Do you have any pictures by chance Russ?
Green Bean Out
The Rag In
Old 02-20-2018, 11:23 PM
smokinum
Yeah Iíll get you one tomorrow bud.
(Russ)
  #9
Old 02-21-2018, 10:19 AM
duramaxzak's Avatar
duramaxzak duramaxzak is offline
Wanna be puller!
http://empire-performance.com/empire...pe-opc6601.php
- ZAK
2011 CHEVY 2500HD CCSB Duramax/Allison LTZ
2005 CHEVY 2500HD RCLB 2WD Duramax/Allison
2002 GMC 2500HD RCLB Duramax/allison 2.6 puller
Special thanks to:
- Danville performance, Mark.
- Suncoast transmission's, Andrew.
- Wehrli custom fab, Jason.
- Profab, Rick
- Turbo performance, Levi.
- HSP, Joe and Dave.
- SoCal diesel.
- Wagler competition, Jeramy.
  #10
Old 02-21-2018, 10:51 AM
jpowel29's Avatar
jpowel29 jpowel29 is offline
I ran the Oberg stainless filter head and then switched over to the Wix racing spin on remote. With just the Oberg stainless screen I didn't think I was getting enough filtration (I think the screen mesh is 100 micron). Cold start oil pressure with just the Oberg was very high as well. Once I went with the remote spin on cold oil pressure came back down some.
Trying some new things...
  #11
Old 02-21-2018, 02:21 PM
Well I talked to Wagler and there's removes the oil cooler just like Empire I see. This truck will be driven on the street so I am not getting rid of the oil cooler.
Green Bean Out
The Rag In
  #12
Old 02-21-2018, 02:30 PM
MAXX IT OUT's Avatar
MAXX IT OUT MAXX IT OUT is offline
<<<IT WORKS
You are looking for something like this?
2001 2500HD Red on Black.
ATS Dual CP3, 4 inchIntake and S366, ARP 625 head studs and main studs, LBZ Rods, Delipped pistons, Hamilton valve Spring, 30 over injectors, 5in Turbo Back exhaust, ATS Transmission, Fass 150, and Running on Moonshine.
DIED AND NOW HAS BEEN RAISE FROM THE DEAD
1971 C10 Restoration/ProTouring Project, Hoping for a Dmax
  #13
Old 02-21-2018, 02:57 PM
<<<IT WORKS
I when out and grabbed my spare oil cooler unit, the unit I posted above will not work due to the base being 2 5/8 instead of the 3 5/8 for our filter. It looks like you can tap the oil return passage fairly easy to 13/16-16. Then just remove the pipe nub from the oil filter feed and replace both with NTP to AN fitting.
  #14
Old 02-21-2018, 03:36 PM
<<<IT WORKS
There isn't a lot of materiel between the second port of the oil filter and the oil passages to the block.
  #15
Old 02-21-2018, 05:32 PM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
We run the Socal oil cooler deleting adapter with -12 an lines out to a moroso filter head. Run a baldwin B7 filter with a screen on top of the filter just to catch things if needed.
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
