Old 11-05-2017, 07:22 PM
Robby Avery's Avatar
Robby Avery Robby Avery is offline
GM TECH @ FENDER GMC
Default The wifes 2005 1500 2wd suburban...........
Simple question I want to swap out the ipc cluster for a factory cluster that has the factory trans temp gauge. I'll have to pull the part number out of it to see what will interchange with. i would like to use a 05 duramax cluster and not a denali cluster just to keep it clean and factory looking. What is the best option so as to not brick it when I program it. I'm sure its been done just want to know what I'm up against. fwiw it has standard cluster in it no business pid or log pids when scrolling through the steering wheel buttons on dic but it does have the illuminated prnd321 thanks in advance
2006 Chevy 2500HD LBZ Duramax Summit White CCSB Tan (neutral) leather LT3 pkg w/sunroof OEM bra 4x4, ISSPRO EV, ATS Twin CP3's, Built Allison, Eaton E-locker front stock G80 rear, Kennedy Twin pump filter combo kit, Snow Perf Stage 2 w/m injection, 4in to 5in banks tip, HM Big K&N, Mickey Thompson Baja Claw TTC 315/75/16 on stock rims, Rancho RS9000XL, Fabtech HD TR, Cognito P&I Brace kit, DD/Puller/Work Truck
2002 Chevy 2500HD LB7 Duramax Summit White CCSB Grey (neutral) leather LT3 pkg OEM bra 4x4, Kennedy Twin Pump Filter Combo Kit, ISSPRO EV, PPE Boost Valve, DTS Built Allison, MikeL Cooler, ATS Billet Flexplate, DTS 3in DS IC pipe, Bill's 5in CAI (White), Big K&N, 4in to 7in black stack, Mickey Thompson Baja Claw TTC 315/75/16 on stock rims, Cognito P&I Brace kit, Sleeves, Energy Sway bar Kit, DD/Puller/Work truck
Special Thanks: (David) DTS, (Guy) Socal Diesel, (Nick & crew) DuramaxTuner, (Dan) PPE, (John) Kennedy Diesel, (Tony) All Season
Old 11-06-2017, 11:00 AM
1FastBrick 1FastBrick is offline
You can use a cluster from a Gas 2500 truck. They had the trans temp as well as the SS trucks.
You may run into issues using a diesel cluster in a gas truck. I know for 1 the tach is different between the two. i would imagine there is programing differences too.
Old 11-06-2017, 06:09 PM
I didn't even think about the tach good call. Did the 2500 gas cluster have tpms caplibiltiy?
Old 11-06-2017, 07:49 PM
That I don't know with stock 2500 programing. But they had the trans cooler and I know you can Program it as a 1500 and the trans cooler temp works correctly so I would think so.
The boards were pretty similar from what I Have seen. The ones with out the trans temp are missing a chip that has to be programed and the stepper motor.
From what I have been told the chip has to be programed prior to soldering it on to control the stepper.
It's not just a calibration change or a reflash that makes it work. The Guys that do it would not give me any more info. Just enough to explain why the guys that try do it themselves are unsuccessful on getting it to work when adding the chip and the stepper.
Old 11-06-2017, 08:02 PM
Hmmmm so where does the ecm read the trans temperature from when the tech2 is plugged in? I presume the pin is not there in the cluster connector end either? One would think that since all harness were practically the same the pins are there just not occupied. it's still a learning curve for me as I have access to schematics just never have time to study them as I'm running around diagnosing customer vehicles at work
Old 11-06-2017, 08:08 PM
The Sensor in the valve body. The data is there as you can see on the scan tool.
But to control the sweeper properly it needs a chip to interpret the signal.
At least this was my understanding. Let me find the thread where they guy shows the difference between the two boards.
Old 11-06-2017, 08:19 PM
Thank you 1fastbrick I'm excited to do this simple upgrade as it'll give me insight to how the temp fluctuates sure 4l60e are not Allison's but data is knowledge in my book
Old 11-06-2017, 08:25 PM
This is 1 thread. But I found another one that showed the differences. Of course I cant find it now.
https://www.performancetrucks.net/fo...2/#post4835258
  #9
Old 11-07-2017, 10:53 PM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
The gas and diesel clusters are largely interchangeable. The tach will work on either one, but the diesel tach goes to 5,000 RPM while the has tach goes to 6,000. So you'll peg the tach if you run a diesel cluster on a gas engine. It will work fine otherwise, and read accurately.
The diesel cluster is the only one with the Overdrive Off light. I've seen the LED present in an 8.1L cluster, but the programming isn't there and it doesn't work. This won't matter for you, just general info.
Late model 2500 gas (and diesel) clusters have the TPMS light. I think just 2005-2006 clusters work, I haven't been able to make any 2003-2004 clusters run the TPMS light, even if I add it.
Finally, the general rule of thumb is you can run a newer cluster than the vehicle without problems, but not the other way. So a 2006 8.1L cluster in your 2005 will be fine, but a 2003 cluster might cause a battery drain or other issues.
  #10
Old 02-20-2018, 05:06 PM
Thank you Dave that's what I was looking for now to hunt a cluster that want brick on me
