Old 05-16-2018, 06:18 PM
Bigred22556 Bigred22556 is offline
FNG
Default Weird allison issue
So I'm having an issue and it has happened with two transmissions now at random times my transmission will puke all its fluid out fill it back up and it will be fine no leaks for weeks then it dumps all the fluid again I'm at a loss as to what it'll be
Old 05-16-2018, 07:54 PM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
Does temperature spike during this?
"OldManTan"
04 SC/SB 1500 big fuel, big SXE turbo, TH400 9.72 @ 150.
06 Cummins cc/sb EFI by Hardway.
Tailgate Member #1 I prefer the backdoor
Old 05-16-2018, 08:05 PM
Mike L.'s Avatar
Mike L. Mike L. is offline
Have someone qualified check it. We have no idea without seeing the truck.
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
Old 05-16-2018, 08:43 PM
FNG
No temp spikes at all and that's the problem I'm a trans tech and it has me dumbfounded two transmissions same issue new Tcm same issue I'm lost
Old 05-16-2018, 10:58 PM
2004LB7's Avatar
2004LB7 2004LB7 is offline
Same or new converter? What is the fluid level on the dip stick while warm prior to it puking?
Is the fluid clean and clear when it comes out or is it milky or strawberry shake colored?
2008 Chevrolet 3500HD DRW LTZ
Old 05-17-2018, 06:27 AM
torqued2dmax's Avatar
Did you flush the cooler prior to installing the first transmission ?
05 CC/LB DRW LLY Allison
Old 05-17-2018, 09:28 AM
FNG
The fluid is clean new converter on both transmissions and it is at proper levels for the temperature it doesn't matter if the trans is hot or cold when it pukes fluid it has done it cold at start up and hot on shut down and the cooler was flushed both times
Old 05-17-2018, 09:58 AM
Mike L.'s Avatar
Possible a front seal on the transfer case leaking into the trans. Check fluid in the TC.
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #9
Old 05-17-2018, 04:07 PM
FNG
I checked it and it's full I also built it when i replaced the transmission the first time
  #10
Old 05-17-2018, 07:09 PM
WVRigrat05's Avatar
Wound for sound
Checked the vent?
Reger
100k miles. Piston eater.
