  #1
Old 12-31-2013, 03:21 PM
duramaxnokaoi duramaxnokaoi is offline
Gearhead
Default Pulling Motor... Lift points?
So I've got an 11 CCLB DRW that I bought with a blown head gasket (hopefully).
I started pulling the motor today. Removed the entire cooling stack and disconnected lots of electrical components. I've still got a few grounds, fuel lines, and starter wire are the known tasks.
My questions are. On an LML, where can you pick the motor from? I don't see anything at the back of the engine to hoist from. In the front, on one side, I think I can use a bolt through the blank accessory (extra alternator or CP pump), and maybe use one of the alternator bolts on the other side of the front, but what about the back of the engine?
I've also never pulled an engine from a car/truck before, so I guess I need to pull the torque converter bolts? Anybody know of any good DIY instructions for doing this?
Any tips, tricks etc would be greatly appreciated.
  #2
Old 12-31-2013, 03:36 PM
blk smoke lb7's Avatar
blk smoke lb7 blk smoke lb7 is offline
<-----Lots of green $
Default
There should be 2 m 12 bolt holes in the back of either head.I just screw a bolt thru a chain end and either bot thru the alt bracket or right where the second alt goes right above the power steering.
__________________
04 LB7 CC/SB EFI live, S366,S483 , Born again 08/10/2011 11.64@117
Some wicked tuning by Bo-Bo (Bob olson) Thx Bob
Quote:
Originally Posted by flyinelvis11
i'll let you use anything i got except my wife and my truck; it's too easy to throw a rod in either one):h
Quote: Carter 44
Boost is like a hot girl with an STD...you know you want to hit it but your afraid of the consequences
rollncoal07:Twining is wining
Quote:
Originally Posted by McRat View Post
You come off as a Timeshare Condo salesman on this site.
If you were helping folk with problems, or asking for input on your problems, it might be different, but from where I see, you are only a little different than the Russian spammers selling iPads that we delete.
Act like more of a human, and less like a spambot, and you'd probably catch less heat. This is "family", and it's our corner bar, and a group of guys with grease all over them leaning over fenders of somebodies truck that ain't making the right boost.
It's also one of few sites with more hardcore wrenches and racers than wannabees.
You're welcome to be a member here, and post about your build, but don't expect people to shower you with roses yet. That comes with seat time on the site, and on the track.
  #3
Old 12-31-2013, 03:51 PM
Harbin_22's Avatar
Harbin_22 Harbin_22 is offline
Turning it back up!
Default
Same as he said. Yes you have to remove the starter and take the converter bolts out.
__________________
10' CCSB
Carrillos, Fingers 16.5:1 Cast Pistons, 3388AF Cam, PPE Dual CP3's, Exergy 200% inj, Danvile Billet 72R, HSP tripples/2-SXE369's, Limitless Diesel All Billet Comp Trans with LD TC, DHD lock up, Air Dog, Banks, RDL, CalTracs, QA1, M/A, Isspro, Novakanes/420's, 30x14 cheaters
Tuning from Mark@Danville
1,101HP/1727ftlbs
6.56@111 1/8
10.12@138 1/4
  #4
pornstar dancin's Avatar
pornstar dancin pornstar dancin is offline
pornstar dancin
Default
Obviously you will have to remove the bell housing bolts and there should be six converter bolts I believe. If you have radiator and front end off the truck you can get a few long extensions to get at them easy through the starter hole
Also take pictures and label everything if this is your first time. Def will help with reassembly
Good luck!
__________________
02 gmc
2.6 puller
  #5
Old 12-31-2013, 04:32 PM
Default
I take the fan and shroud off remove the rad top support and the rad and the motor clears with turbo and all.If it was me I wouldn't pull the front fenders and all its not needed and if you don't get them back on right the body lines are off and if you do it my way no need to discharge the a/c, just lay it off to the side without touching the battery.
__________________
  #6
Old 12-31-2013, 05:13 PM
dracing70's Avatar
dracing70 dracing70 is offline
SH--- GETTING EXPENSIVE!
Default
I always try to use four lift points on the hour corners of the heads. I have used two diagonally but it seems sketchy. X2 on the exit route remove everything in front and the top rail on the core support and leave main core support bottom in. I'll send a pic. I also use a load leveler it makes everything easier. Summit carries them.
__________________
Special thanks to Mark, Larry and everyone at Danville.
2004.5 lly 2500 chevy 4x4 very big Danville turbo, efi live, carrillo rods, so cal pistons ,arp studs ,brodix heads . Hsp manifolds and custom intake along with a DR Tuning custom stainless remote mount,very very very very very large exergy sticks,twin modded cp3 pumps. Tranny is obviously built with billet shafts in house by DR Tuning. Plus many other goodies!
also have a 2003 lb7 crew cab dually dark green mostly stock with stage five suncoast, full cognito front suspension semi 10 lug wheel kit with 19.5 alcoa's and s b intake
  #7
Old 12-31-2013, 05:17 PM
dracing70's Avatar
Default
Top rail is out only radiator remains then engine slides right out
__________________
  #8
Old 12-31-2013, 05:18 PM
dracing70's Avatar
Default
Best friend when installing
__________________
  #9
Old 01-01-2014, 05:48 PM
Gearhead
Default
Quote:
Perfect exactly what I was looking for Many thanks.
Any idea what the thread pitch is on those M12's? I'd guess 1.5 or 2.0 maybe? Also any idea how deep the thread hole in the head is?
  #10
Old 01-01-2014, 05:50 PM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
Default
1.5 IIRC
Head depth is a little more than 1/2"
__________________
"OldManTan"
04 SC/SB 1500 big fuel, big SXE turbo, TH400 9.72 @ 150.
06 Cummins cc/sb EFI by Hardway.
Tailgate Member #1 I prefer the backdoor
  #11
Old 01-01-2014, 05:54 PM
Default
The head is identical front and back locate the holes your going to use on the back and find the same holes on the front and you will know what thread and how deep.Should be the same pitch as the bolts that hold the acc bracket on.
__________________
  #12
Old 01-01-2014, 06:17 PM
Gearhead
Default
Great info thanks again guys.
Since I've never unbolted an engine from trans... when I am unbolting the converter via the starter hole, will I have to turn the engine over to access all of the bolts (I assume so) and if so what is the best method? If I had to guess I'd say remove all the glow plugs and turn the motor over by the main crank bolt, an extension and breaker bar?
  #13
Old 01-01-2014, 06:20 PM
Gearhead
Default
http://www.duramaxdiesels.com/forum/...nt.php?id=3711
  #14
Old 01-01-2014, 06:23 PM
Gearhead
Default
Has anyone else noticed the irregular fan blade pattern? Anyone know why they did it like that? Not sure why the pics are loading 90˚ off
http://www.duramaxdiesels.com/forum/...nt.php?id=3710
  #15
Old 01-01-2014, 07:30 PM
dracing70's Avatar
Default
U can use the crank bolt that holds on the dampner to turn or use a flat screwdriver through the converter access hole on the bell housing. But I ususlly use the crank bolt. Turn the engine clockwise.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
