Go Back   Duramax Diesels Forum > Duramax/Diesel Technical > Duramax Hard Parts
View Poll Results: Please pick the one that you had break
LB7/LLY 01-05 57 34.97%
LBZ/LMM 06-10 90 55.21%
LML 11+ 16 9.82%
Voters: 163. You may not vote on this poll
Reply
Thread Tools Display Modes
  #1216
Old 06-11-2018, 11:38 PM
RPM Motorsports's Avatar
RPM Motorsports RPM Motorsports is offline
smokinum
Default
This one had 114k mi.
__________________
(Russ)
17 CC/SB L5P 4x4 High Country
73 RC/NB LBZ Nova Grocery getter
  #1217
Old 06-12-2018, 04:36 AM
NC-smokinlmm's Avatar
NC-smokinlmm NC-smokinlmm is offline
<<<Future tuna killer
Default
Heavy hauler?
__________________
2010 GMC 1500 SCSB Denali Clone < lifted 22's/33's, Kooks, Magnaflow, 5.3, 6l80, TVS1900, lots of boost, Mayhem tuned, etc...
2015 Corvette Stingray Z 51 < Stock...
2016 LML CCSB Denali < Lifted 22's/35's, Fox 2.0 < I officially need help.
  #1218
Old 06-12-2018, 05:34 AM
caseih03's Avatar
caseih03 caseih03 is offline
FNG
Default
Probably main cap/block fitment issue. Caps to small/blocks too wide, cap walks, spins main bearing, makes crank brittle, now your crank is a 2 piece.
  #1219
Old 06-13-2018, 10:12 PM
dirtymax36's Avatar
dirtymax36 dirtymax36 is offline
2nd place is last
Default
Has anyone had any failures or can name and “cons” for the new callies durastar crank ? Other than it needs to be properly internally balanced to your rotating assembly. Seeing if there’s any failures before purchasing.
__________________
04.5 LLY CCSB Built Motor/trans. Some fast spinny things.
  #1220
Old 06-13-2018, 11:31 PM
LBZ's Avatar
LBZ LBZ is offline
Default
I don't think there are enough of them out there to say either way if they are worth it or not or any better than the other more popular options that are out there.
  #1221
Old 06-14-2018, 12:59 AM
kidturbo's Avatar
kidturbo kidturbo is offline
Piston Tester
Default
OEM specs, with better steel.
Few OEM cranks break first year, so guessing only time or mileage will tell that tale.
Reply
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
1badjimmy
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
