  #91
Old 04-20-2018, 06:54 PM
WVRigrat05's Avatar
WVRigrat05 WVRigrat05 is offline
Wound for sound
Default
Quote:
Originally Posted by artementy View Post
Why use high pressure hydraulic hoses for the transmission cooler lines? GM does it with quick connects and C-clips.
The stock lines are junk, Iíve changed mine twice in 90k miles. Just because itís GM doesnít mean itís awesome.
__________________
Reger
05' Black Chevy CC/SB LT- Blackout Performance built motor/trans/tuning- Gone
The Blessed Hellride- 08' White GMC Sierra SLT CC/SB,
100k miles. Piston eater.
Wife's ride- 2016 Pearl white Legacy limited 3.6R
Rig ride/new DD-02' Black Eddie Bauer explorer 4.6, -180k, still sporting original trans, outlasted two Duramaxs.
  #92
Old 04-21-2018, 06:37 AM
LCAC_Man LCAC_Man is offline
Gearhead
Default
Quote:
Originally Posted by the_engineers View Post
It's a full-floater. So is that automatically a 10.5"?
Well, I've heard that there was some full floating 9.75" rears out there(in gas powered express/savanas) but I've yet to see/hear of one in a 3500 duramax...you can look at your RPO label on the passenger door jam and check the codes that start with an "H" and that should tell the tale. The casting bulge just above the pinion looks just like every D70 I've seen.
__________________
Len Barron
2000 Express 155"wb Passenger Hightop
  #93
Old 04-21-2018, 07:43 AM
the_engineers the_engineers is offline
Gearhead
Default
I'm a 2500. My cover has 12 bolts, so that's added to some of my confusion.
  #94
Old 04-21-2018, 04:32 PM
Gearhead
Default
okay...that's a different story...there's a good chance that it is a D60 then...my bust...I thought you had a 3500 donor. You can for sure tell by pulling the cover and getting the part number off the ring gear...dana 50/60/70 all share a common diff cover..
__________________
Len Barron
  #95
Old 04-21-2018, 06:14 PM
JoeyD's Avatar
JoeyD JoeyD is offline
WTF
Default
All the duramax vans had the Dana 70s up until they switched back to the old 14bolt 10.5. I forget the year but maybe 12 or 13
__________________
16 LGH Savanna
98 6.5 TD Pro Rok 60 front, ARB's front and rear, 4.56 Gears,37"KM2's
  #96
Old 05-07-2018, 07:05 PM
Gearhead
Default
Moved over to work on brakes. The driver's side leaked all over the e-brake pads. The passenger side e-brake lever was frozen engaged. Replaced everything from the backing plates out. New calipers on the way to replace the rotted ones...
  #97
Old 05-20-2018, 06:20 PM
Gearhead
Default
Brakes are done. Also added the PPE Duramax oil pan. My list is getting shorter.
  #98
Old 05-21-2018, 05:13 AM
Gearhead
Default
I've got one of their older versions on my motorhome trans...they are beastly..
__________________
Len Barron
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
