  #1
Old 05-24-2018, 09:27 PM
Chevy1925's Avatar
Chevy1925 Chevy1925 is offline
Default Adding tension to your dayco tensioner
So I needed to add more tension to my belt setup since I’m running 149” belt and 02-05 use a different idler pulley setup than the 06-up that doesn’t really let you get all the slack out of the belt. This is only an issue if you are like me and have a van thermostat housing and dual fueler
That said, I have a dayco tensioner from autozone that I know a lot of guys run as well to keep the belt on their truck. The two Allen head bolts on the back of the tensioner that set into the recesses of the accessory bracket to “key it” can be unbolted without anything coming apart. Figure out how much you want to add for tension and redrill holes clockwise from the original holes. I went 3/8” from original. You can go farther than this just by sanding off the stop that keeps you from going too far. Made a significant difference in tension from before
As you can see, I have 4 open holes. First time I added new holes in the wrong direction lol (counterclockwise, don’t go that way unless you want less tension)
May not be many guys needing this mod but think this will help those that still have jumping belt issues at high rpm or can’t get pulley alignment perfect
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #2
Old 05-24-2018, 10:34 PM
WisconsinHick1's Avatar
WisconsinHick1 WisconsinHick1 is offline
Default
Hey James does that Dayco have a metal pulley? If so what's the part number by chance? Also great mood I might need this in the future for my setup!
__________________
Green Bean Out
The Rag In
  #3
Old 05-25-2018, 04:36 AM
NC-smokinlmm's Avatar
NC-smokinlmm NC-smokinlmm is offline
<<<Future tuna killer
Default
Why not go manual like I did with my LS? My belt is tight as fuk!
__________________
2010 GMC 1500 SCSB Denali Clone < lifted 22's/33's, Kooks, Magnaflow, 5.3, 6l80, TVS1900, lots of boost, Mayhem tuned, etc...
2015 Corvette Stingray Z 51 < Stock...
2016 LML CCSB Denali < Lifted 22's/35's, Fox 2.0 < I officially need help.
  #4
Old 05-25-2018, 05:28 AM
Noreaster's Avatar
Noreaster Noreaster is offline
Default
Quote:
Yep metal pulley
#89259
__________________
02 GMC 2500HD RC/LB "No Shuckin Luck" Totaled 12.26 @ 109
Ridge Runner Diesel Performance, Big Dipper tranny, Profab Performance, Super Diesel, Creatures of the Night, AirDog, BD
02 GMC 2500HD EC/SB WCFab twins
Bay State Diesels
  #5
Old 05-25-2018, 05:45 AM
prostreeter600's Avatar
prostreeter600 prostreeter600 is offline
Street rodder
Default
What part brand and # did you use on your LS ? Where did you get it if you don’t mind . My brother’s turbo LS is chunking the belt .
__________________
06! GMC Sierra RC Full built motor, carillos, 14/1 Arias W/total seal rings, 9100 AF, SCalTit retainers,SCalsprings,ported heads, SCal pushrods, ARP 625 head studs, O-ringed block, keyed oil pump ,Billet Aluminum Lifters, Harland Sharp Aluminum roller rockers, studded rocker shafts, studded & girdled mains, socal balancer, socal flywheel, PPE Dual Fuelers with twin Fleece 10 mm CP3s , FASS Titanium 260 , 3" bridge, , TrRIPLES----2---S369SXEs .88ARs over a Hybrid GTX 4202R--72mm/87mm 1.0 AR ,coilovers at 4 corners, 36" ladder bars, BD cooler, Exergys w/185% MS 8 hole nozzles ,FF Dynamics fans, PPE mans & ups , MA mounts & TC Brace ,NOS, Full Billet Trans, Suncoast 10531-3D , 3.42 Gears, BT lockup box, 18x9 Raceline Assualts Hooiser Drag Radials 325/45/18s . TUNED by MARK@DANVILLE. Engine by Jason Walker San Marcus Tx Best 60'---1.44. Best 1/8---6.39@105.92. Best 1/4---9.978@136.39
  #6
Old 05-25-2018, 06:03 AM
Default
Quote:
I'll have to go back and look. It's a heafty piece, I love it, minimal loss of boost with standard belt...
I'm about to overdrive it by 10% and go 8 rib so it maybe for sale as its for a 6 rib but it may work, I'll have to see...
Has he gone to an electric water pump? How much rwhp? Most of my friends went to the e water pump to lessen belt strain and keep from cavitatating it at high rpm...
__________________
  #7
Old 05-25-2018, 06:18 AM
Street rodder
Default
He just purchased it . Trying to get the bugs worked out of it . It’s a 6.0 built 6.0 with a single 83 Bullseye.
__________________
  #8
Old 05-25-2018, 07:46 AM
Chevy1925's Avatar
Default
Quote:
Don’t believe it will work well on such a long belt. The 149” only comes in a normal belt and it stretches quite a bit when hot. Do they even make a manual setup for a dmax?
And yeah Eric, it’s metal. The pulley you see on mine is metal. If not, I think you can punch the bearing out of the plastic one and put it in the factory steel one so it’s “new”
__________________
James
  #9
Old 05-26-2018, 06:38 AM
rcr1978's Avatar
rcr1978 rcr1978 is offline
Default
Thanks for taking the time to post pics, mines run the same way. It seems ok now but I have not drove it yet since there is no down pipe on it and exhaust will blow on the firewall until I finish building my twin piping. Did you hear your belt squeal under a good load James?
__________________
04 LB7 ECSB Built motor, Wagler billet narrowed Rods, Callies billet crank, Mahle Race Cast pistons, Randy's Girdle, Wagler/Callies Stage 1 alterfire cam, Exergy 100% SAC's, dual CP3's, Randy's race ported heads, Profab cast flow/up pipes, and S475 over stock twins for now more later.
2010 LMM CCLB-Tuning/Exhaust
2015 LML Cab and chassis- Tuning/Exhaust
  #10
Old 05-26-2018, 04:57 PM
Chevy1925's Avatar
Quote:
I never did but with me running a solid fan hub now, I wanted to be damn sure it wasn’t an issue. I do know it holds less tension before the mod than the original dual fueler belt routing cause it was real close to the relaxed stop when running and hot
__________________
James
  #11
Old 05-27-2018, 07:03 PM
mike diesel's Avatar
mike diesel mike diesel is offline
I'm alright.
Default
After tossing and shredding literally 20+ belts last season on the StarLite truck, we built a mechanical (solid) tensioner while utilizing the 149" belt. Haven't lost a single belt yet. And this belt that's been on it since day 1 with the solid tensioner still looks brand new. We tried 15 different factory style tensioners and added several more idler pulley to no avail. Solid tensioner solved every single problem.
__________________
'89 s10 daily driver
  #12
Old 05-27-2018, 08:14 PM
TheBac's Avatar
TheBac TheBac is offline
Default
Alright guys, you're using old-skool V-belt technology for a serpentine-belt problem tension problem, which I think is brilliant....so would one of you please give us the low-down on just HOW you built the parts to solve this dilemma?
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 12.14@111.15
"Flyin' Brick" -- 1999 Chevy 1500 RC/SB 2wd -- stalled out, no motivation
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the fun little DD
"The Bigger Boat" -- 2011 Workhorse P700 - 6.0LS/Allison - what I drive at work
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
  #13
Old 06-28-2018, 12:27 PM
Bbuchanan11's Avatar
Bbuchanan11 Bbuchanan11 is offline
Gearhead
Default
Katech engines makes a lot of nice billet manual tensioners not one specifically for a duramax but might be able to get one to work... I used one on my supercharged Silverado and it stopped the belt from slipping.
__________________
06 Silverado lbz 11.77 @115 sold
17 Silverado L5P ltz custom sport stock
06 gmc built motor/ trans dual fuelers 60 overs 75 over 66, 5600lbs... track times coming soon
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
