  #1
Old 07-17-2017, 07:25 AM
J697 J697 is offline
FNG
Default OK, I installed the extension housing in the truck....
So please dont give me too much hell because I was told it would be fine and taking the trans out was a waste of time. Truck is a 2006 LBZ, bought as a project.
I recently replaced my U joints, and transfer case. Driveshaft was balanced at the same time. Here are my current codes: PO700, PO762, P2771.
Im worried because upon initial takeoff (Shift to D), the truck moves fine and then hits a "wall" HARD! And makes a violent noise. Almost everytime and after that it seems to drive fine until you take it out of drive again.
I would suspect U joints or rearend but im afraid it may have to do with my screwing with the extension housing? If so is it maybe salvageable?? Im more than willing to pull the tranny to save it.
Other than that the truck seems to drive normal enough, couldnt get it to shift into 6th gear the other day also...
I have yet to pull the pan to check for metal shavings but unless yall say otherwise, this is my next course of action.
  #2
Old 07-17-2017, 07:29 AM
Chevy1925's Avatar
Chevy1925 Chevy1925 is online now
Default
ya dun f*cked up A-A-ron, pretty much all there is.
do a search on here about replacing the extension housing. You never do it with the trans in the truck.
pull the pan, show us all the pretty parts in the pan, then pull the trans and take it to someone who know how to work on these (not the guy who told you to pull the housing in the truck)
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #3
Old 07-17-2017, 07:36 AM
FNG
Default
More or less what Im expecting unfortunately, I'll probably pull it later today. Shop work isn't in the budget so it's a DIY effort till she's down the road...
General consensus is that a stock rebuild isn't worth it? I may just pick up a used trans if I have to.
Yeah putting the extension housing on was a b*tch and I was extremely careful.. ugh wish I found these forums earlier.
  #4
Old 07-17-2017, 07:45 AM
Mike L.'s Avatar
Mike L. Mike L. is offline
Default
So, aside from the trans feeling like it's hitting a wall violently and making a nasty noise, and not shifting into 6th gear; it drives pretty good?
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #5
Old 07-17-2017, 07:51 AM
FNG
Default
Thats correct, Ive only drove it maybe 30 miles since installing transfer case/drive line. Seems fine besides those issues.
And to clarify when I say violent noise I mean a clunk or bang, not a grinding. Still can be very loud, also my truck has the single piece driveshaft.
  #6
Old 07-17-2017, 08:29 AM
Chevy1925's Avatar
Default
this isnt a simple fix nor is rebuilding one simple for someone who knows nothing about the trans. if you get it back together and it works correctly for another 100k, it will be a miracle.
you are better off buying a used trans and taking your chances with that
__________________
James
  #7
Old 07-17-2017, 08:34 AM
JoshH's Avatar
JoshH JoshH is offline
Default
Who told you pulling the trans was not necessary and a waste of time?
__________________
06 Silverado 4x4 CC/SB
06 Express 2500 Duramax Van "The Dumpster"
  #8
Old 07-17-2017, 09:41 AM
FNG
Default
Just some local mechanic who's usually given pretty decent advice before. But he certainly must not specialize in Allison transmissions. Now im not blaming him because i still should've researched more.
I just want to get this truck on the road, so Im just gonna need to find the easiest/most effective solution to my current problems.
Whether thats a rebuild or a decently priced used trans. I have plenty of tools and ambition to fix whatever I **** up, so thats a non issue. Even though I agree with you Chevy1925, used would likely be easier and more cost effective.
  #9
Old 07-17-2017, 09:49 AM
Awenta's Avatar
Awenta Awenta is offline
Default
Quote:
Minor details. Don't sweat the small stuff
__________________
Arek
2003 CCSB LT LB7 deleted
Some cool stuff, some fast stuff, some slow stuff
EFI by Kory
Special thanks to Evan@Limitless
  #10
Old 07-17-2017, 10:19 AM
greendury's Avatar
greendury greendury is offline
Default
Quote:
I also thought that post was great.
__________________
02 GMC Reg cab lb7 2.6 puller sold
03 GMC Ext cab lb7 WS puller.
03 GMC Crew dually lb7 sold
  #11
Old 07-17-2017, 10:23 AM
IOWA LLY's Avatar
IOWA LLY IOWA LLY is offline
Yes, its really me
Default
Find a used one.
__________________
2003 GMC CCSB LLY
Built by me, tuned by me.
2009 ECI Diesel Truck Points Champion
2010 ECI Diesel Truck Points Champion
2011 ECI Diesel Truck Points Champion
2012 ECI Diesel Truck Points Champion
Big thanks to everyone who helps me.
Best 1/8th, 7.29, 98.6MPH (Street tires, fuel only, single Journal bearing GT42 charger) (2010)
Best 1/8th, 6.93, 104.24MPH (Street tires, fuel only, single HX60 turbo) (2016)
Best 1/8th, 6.60, 106.6MPH (Street tires, fuel only, single HX60 turbo) (2017)
  #12
Old 07-17-2017, 10:26 AM
FNG
Default
Well really the whole point of this post was to see if what Im experiencing is typical of a transmission f*cked up by incorrectly installing the extension housing.
I dont really know if the noise is coming from the transmission although it seems likely based on the circumstances.
  #13
Old 07-17-2017, 10:32 AM
ZeroGravity58's Avatar
ZeroGravity58 ZeroGravity58 is offline
Default
Where are you located?
__________________
09 lmm ccsb ltz, ATP tuning, mpi s480 over stocker, big dipper trans, 60 overs, 10mm stroker pump, ppe up pipes and manifold, banks intercooler & exhaust, airdog165, isspro guages, traction bars, the list goes on
01 lb7 red RC/LB 11.58@119 MPH, SOLD
01 lb7 Black CC/LB, SOLD
  #14
Old 07-17-2017, 10:33 AM
PureHybrid's Avatar
PureHybrid PureHybrid is offline
Isuzu Shakes IT
Default
Where are you located? Trans needs to come out, maybe someone is close enough to help.
__________________
04 GMC ECSB LLY - Mix breed trans/SC1056 - Profab - PPE - Kennedy twin pumps/pickup - Danville tuning: 531/944
I can't complain, but sometimes I still do
Jesse
  #15
Old 07-17-2017, 10:34 AM
FNG
Default
East Texas, and unless they accept beer as payment I can do it alone lol. Just really wanted someone to say "Nooo your trans is A-okay".
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
