  #31
Old 09-13-2017, 08:22 PM
the_engineers the_engineers is offline
FNG
So at this point, I'm tempted to put the factory van cluster back in. I found a CAN BUS scanner that claims to display the current gear, regardless of being in D or M. Everything else I wanted to see can be monitored via a BY OBDII scanner. Time to put it up on the lift for some transmission swapping...
  #32
Old 09-14-2017, 08:36 AM
LCAC_Man LCAC_Man is offline
FNG
I've considered the same, but looking closely at the Edge Insight CTS, I like that you can add sensors and you can use it for a back up camera display. I'd sure like to find a way to get to all the DIC data though..
Len Barron
2000 Express 155"wb Passenger Hightop
  #33
Old 09-14-2017, 08:38 AM
FNG
Originally Posted by the_engineers View Post
Len, have you had any luck finding a body lift for a van?
probably just going to make one out of nylon round stock. Then extend the steering shaft as necessary.
Len Barron
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
