  #16
Old 11-17-2011, 06:57 AM
bigbopper bigbopper is offline
Gearhead
Smile bigbopper
good show george smolen
  #17
Old 11-17-2011, 07:15 AM
02greysixer's Avatar
02greysixer 02greysixer is offline
I followed this when I did mine, very good breakdown! I would like to add though if the truck is a ZF6 like mine you either need to pull the trans first or take the lower oil pan off. If not the oil pan hits the front diff before the input shaft is free.
Sint frum tha orijinul smert fone
2010 LMM CCSB LT
4" Flo-Pro
FASS 150
Beans Sump
Leveled w/ drop shackles
RidgeRunner Tunes
More to come
Rip zf6 swapped lly
  #18
Old 11-17-2011, 08:07 AM
Dirtymaxx03's Avatar
Dirtymaxx03 Dirtymaxx03 is offline
subbd
Sean
2003 Lb7
Efi Live
The Rabbit-build in progress
1984 2wd SB c10
Originally Posted by hondarider552 View Post
big balls if you measure in seconds of duration
  #19
Old 11-29-2011, 06:41 PM
Bill H's Avatar
Bill H Bill H is offline
Street Toy
I agree w Durally, Take it all off will make it much easier gettiting at the rest of it.
05 LLY CCSB
Big Thanks to Larry, Mark at Danville Performance
Also Thanks to Evan, Limitless Diesel, & Steve Bailey of Roanoke VA
  #20
Old 12-01-2011, 12:20 PM
kenny's Avatar
kenny kenny is offline
kennydiesel
I noticed you didn't include removing the fan. What is the size of the fan nut? Thanks and great write up.
2006 Chevy 4X4, CCSB, 2500HD, 6" Fabtech lift, traction bars, wireless air ride with semi bags, 20" WCC Wheels, 35" Toyo's, Custom Twins; GT40, GT47, Exergy 100%, Dual CP3, ARP headstuds, 5" downpipe to straight pipe, BD manifold, RDL up pipes, Wehrli ped and bridge, Airdog 150, Tial BOV, Synapse wastegates, EFI, Triple Billet converter, built trans, Mag Hytec pan, Mag Hytec cover, pcv bypass, EGR delete, ported rails, 3" boost tubes, 7 Autometer guages, carbon fiber lined interior, full audio sound system with woofers, monitors, navigation, and back-up camera, and I own this truck just to pull the toys around.
My weekend warrior toy with 500HP LS1 to stand out from all others on the trail
Yes, those are 40" tires too...
  #21
Old 12-15-2011, 02:36 PM
Wyo Wyo is offline
FNG
Easiest way to remove the fan is with a air chisels, comes off in a few rattles and works great.
Just a FYI,
Easiest way to remove it is to remove the front clip, after you do it once you will never do it any other way, it comes off quick if you have ever done it.
Also if you pull the hood, fenders and bumper first, you can then remove the entire radiator support fully intact, wiring and all.
When going back together though you have to install the support, fenders, hood and align before tightening down. If you have a friend that knows about body work they can help. But like I said do it once and you will know.
  #22
Old 12-16-2011, 08:34 AM
durallymax's Avatar
durallymax durallymax is offline
You dont have to remove the fan to pull the engine it can stay on it. the nut is a 47mm. You will need a hold tool though as well. You can buy a complete kit for around a hundred bucks that services many fan clutchs or use air chisels.
I guess i dont see the advantage to remove the hood and fenders but to each their own. i understand it giving you more room to work, but there isnt much you need to work on. I dont feel its worth the extra hassle. You can remove the radiator stack as a big chuck with the upper support intact leaving the rest of the support there.
Again, 1000 ways to skin a cat, but completely stripping the front of the truck down to remove the engine seems like a lot of extra unnecessary work, and in that amount of time you could just pull the cab off to remove the engine and still be time ahead. Again still unnecessary and would also tie up a lift for awhile.
But still, to each their own. Many ways to do it, glad you found a way you like.
Wife:2010 Jetta TDI "Cup Edition" Thunderbunny. Stg 2 Malone, Rawtek Straightpipe
Me:2000 Jetta TDI/5spd VNT-17, DXD S2 Clutch
Sis:2006 Jetta TDI/DSG
Puller:2003 LB7 GMC
Toy:1973 Kenworth W923
Farm:02,11,13 Duramax/Allisons
  #23
Old 01-07-2012, 01:13 AM
DeMax LB7's Avatar
DeMax LB7 DeMax LB7 is offline
Bowtie Child
Thats a awesome write up man! damn well done! gonna keep this handy.
2002 Chevy 2500HD
The Night Train
EFI Live Tuning
Exhaust
CAI
Recon Lighting
Rollpan
HID 8K
And more...
  #24
Old 02-14-2012, 06:58 PM
cafryer's Avatar
cafryer cafryer is offline
sub
Chavis, 2001 rc/lb Lots of air, Lots of fuel, Lots of spray.
2003 rc/lb zf6 South bend dual disk 64/75 compounds 30% injectors
  #25
Old 02-14-2012, 07:59 PM
Springer415's Avatar
Springer415 Springer415 is offline
slowly gettin' nowhere
Subbed
edge juice with attitude, 4" mbrp turbo back with muffler, pretty much stock other than that
  #26
Old 02-19-2012, 09:08 PM
james13's Avatar
james13 james13 is offline
big black
sub
02cc/lbd lb7 only the best
ppe boost increase valve
19.5x6.75 rickson truck wheels
245/70/19.5 kumho krd02 {33"}
frontier gear bumper front and rear
trans flow 98gl. in bed tank with trax monitoring system
airdog 2 165
268hp/539ft-lb {not bad for stock}
  #27
Old 02-19-2012, 09:15 PM
AubleAK's Avatar
AubleAK AubleAK is offline
Originally Posted by COWBOYTRUUUU View Post
i have a 08 durmax and the battary ran down so i was jumping it off and got the leads on the wrong terminals, pos was on neg.... now it will not do anything at all, now i have put 2 new batterys in it still not a thing ,,whats the box on the pass,side mounted on the firewall? any help out there????
Thanks,
Craig
this is the wrong section to post in. fill out your SIGnature, then go repost in the duramax hard parts section.
Nice write up!
2001 Chevy Ext. Cab Short Bed
EFI Live by SS Diesel Tuning -
thanks Steve!
LBZ rods, ARP Head Studs, 475 over stock twins
4 Inch Turbo Back Straight Pipe
3 inch Downpipe
20" XD Monsters
Suncoast Gmax and Precision ML Converter - Built By Me
Airdog 165
Died 9/13/12 - broken valve
Born Again 12/16/12
Died again 1/9/13
2011 GMC Sierra SLT LML
stock- and staying that way
  #28
Old 12-16-2015, 07:46 PM
Justinsaine Justinsaine is offline
FNG
Default Excellent Job!!
Thank You for the Info.
Would you do anything different if you were going in with another engine going from a 01 to an 03 both LB7 but different years.
Thanks a bunch
  #29
Old 10-21-2016, 04:30 AM
WVRigrat05's Avatar
Wound for sound
Wow, that took some patience, good write up.
Reger
100k miles-FOR SALE/Waiting on a new motor
  #30
Old 03-14-2018, 04:59 PM
rickcdewitt rickcdewitt is offline
FNG
I can vouch for this if you don't have a lift that drops the diff a bunch.same for install
