  #61
Old 03-30-2018, 11:27 AM
zakkb787's Avatar
zakkb787 zakkb787 is offline
<thatís not me...
Default
Go ahead and bypass the fuel in the FICM. One less restriction.
__________________
2006 LLY CC/SB LT3 mostly stock
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s. And itís currently broke
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
  #62
Old 03-30-2018, 01:01 PM
torqued2dmax's Avatar
torqued2dmax torqued2dmax is offline
Default
chowpay what state do you live in , is the truck a daily driver , Im asking to find out whether the truck is going to be used regularly in sub O weather !
__________________
05 CC/LB DRW LLY Allison
AFE Blade Runner,AFE Momentum CAI,DHD Big Air intake Y pipe, DHD fuel block,DHD pcv reroute,MBRP 4 inch exhaust,DHD 3 inch downpipe,BD driver's side manifold,DHD pass side up pipe,DHD 3 inch intercooler hot&cold pipes, ATI damper,Empire pin kit by Big Foot on & off road shop, FASS fuel system,5/8 inch pickup, FASS fuel filter delete, EFI live,V2 & lap top , 5 position switch 250 hp big tune, shimmed fprv by Crank it up , built SunCoast Allison 1078 converter aftermarket trany mount by Limitless Diesel,ARP head studs,grade C gaskets,tig-welded water pump,T stats by Blackout performance,MA t case brace , Kriptonite motor mounts,MA pump rub kit,HD drive shaft 1480joints by Greensburg machine,BDS Recoil traction bars, PPE finned deep pan , Mike L trany cooler, PSC pump, 5100s, Sulastic Shackles, Curt com 2.5 hitch
  #63
Old 03-30-2018, 04:45 PM
TheBac's Avatar
TheBac TheBac is offline
Default
This has to be the longest injector thread Ive ever seen....
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 12.14@111.15
"Flyin' Brick" -- 1999 Chevy 1500 RC/SB 2wd -- stalled out, no motivation
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the fun little DD
"The Bigger Boat" -- 2011 Workhorse P700 - 6.0LS/Allison - what I drive at work
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
  #64
Old 04-03-2018, 11:38 AM
chowpay chowpay is offline
Gearhead
Default
Quote:
CA, its warm here and its less of a daily just need something to pull or haul on trips
  #65
Old 04-03-2018, 12:04 PM
Gearhead
Default
Quote:
I know.. im just so slow, the only time I have is on the weekends and usually a just one day on the weekends.. and its my first time doing this so trying to get all the tools and do things correctly is challenging. But so far so good =D
BUT progress slow and steady..
Got the covers and the injectors off. I used everyones advise and bought a pry bar put it against the rail and it too so little effort I was amazed.
Took someone elses advise on youtube and glued a torx on the end of a 1/4 ratchet. This gave me just enough space to get to the furthest bolt on the lower valve cover next to the driver side firewall:
Each injector I pulled out was nastier than the last:
So turns out some of the injectors are stupid stuck. Here's a bent injector tool:
Since I didnt want to break the tool, still good for any not-so-stuck injector, got this other tip on youtube and it worked so well. Take the end of an air hammer bit and stick it in the hold down, grab your 3lb hammer and give it a tap. It'll pop right out:
Doing the general things while im in here, I looked up how to clean a ERG cooler. Boy did it work. If anyone else is doing this , get your self small tub and a gallon of purple cleaner and just leave it there overnight, worked so good I put the valve covers in a tub and I'll get to it next weekend:
Before:
After:
Questions for ya'll
1. What is this and where do I get a cap for it :
One of the cups came out with the injector.
2. How do i get this cup off the injector its stuck pretty good:
3. Do you guys recommend I work on pulling all the other cups out too, I got a blind puller and a mac tools p99 steering wheel puller kit, I read that combined I should be able to use pieces of each to make something that will pull them out. Just want to see if this is necessary or recommend?
.. now just waiting on my new injector lines to arrive before I can start putting things back together
  #66
Old 04-03-2018, 12:17 PM
zakkb787's Avatar
<thatís not me...
Default
Absolutely pull every cup and reseal them. You can use a 1/2 I believe concrete anchor.
__________________
Other toys:
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
  #67
Old 04-03-2018, 02:04 PM
duramax on fire duramax on fire is offline
Default
X2 on pulling all cups. You don't want one lifting and have to do this all over again. The 1/2" anchor bolt works good. Plus let that loctite set 24hrs before starting or adding coolant.
  #68
Old 07-12-2018, 03:21 PM
Gearhead
Default weld'n water pumps and stuffs
Yes its taking forever (had to move my ex-gf out of my house and finish building this for a client). So back to being single and finally getting shit done
.. no I'm not done.. But working a little every night has been helping .
So far completed these:
1- injectors installed (replaced all the related hardware for covers too)
2- took everyones advise and reinstalled all the cups/seals << buy the damn tool. Don't mess with the anchor bs. this cost me at least a night or two dicking with the anchors. New tool cost 90 bucks and did all the cups in 5mins.
3- New HP fuel lines + New hardware
4- New Water pump + New Housing
5- New Thermostats
6- 2 New idler pulleys
Once the valve covers and HP Lines were installed I switched focus to the water pump.
This was not as bad as I thought it would be you just really need a long f'n cheater bar.
While searching around on forms I noticed that people are buying welded version of the water pump. I read up on it and it sounded like a good idea.
So I TIG'd mine too, couldn't find pics of anyone doing this and didn't want to return the one I bought and pay 2x as much for a new one that had a couple of beads on it. Hopefully this helps anyone wondering how to do it. This works for me:
The pump itself actually looks pretty good before I cleaned it. The pump housing had a little bit of erosion but nothing too bad that it needs to be replaced. But I don't want to deal with it and replaced it anyways.
I know that the shaft has some seals in there that are heat sensitive. From what I read its ok up to 250-280 deg. So I put the whole setup into a water bath and watched and welded little at a time, using a wet towel to really suck up the heat even more:
On the weld and the shaft itself about 1sec after the weld is complete. Never even got close to 200:
Did the same for the prop side:
Questions:
- Where I'm stuck now is here:
- Where does this ball of crap mount to.. its the one pre-install picture I forgot to take
Couldn't find it in any diagram on line. Partially because I'm not sure what this is called. I KNOW it goes in the back somewhere as it has the pig tail for the rear injector wiring plug.
- Also when pulling off the 1-bolt pipe onto of the thermostat housing, I noticed besides the O-ring that there is RTV on it. But I couldn't find any instructions about re-installation including the RTV. what do you guys do?
Keep in mind this is a Cali truck
  #69
Old 07-12-2018, 03:42 PM
2004LB7's Avatar
2004LB7 2004LB7 is online now
Default
All that crap with the solenoids and little tubing is for the EGR and vacuum pump. It mounts over the valve cover back by the firewall
File Type: jpg vacuum-diagram-02-chevy-duramax-6-6-0kqf51sbiqejqonuiyp3fmoa-5-0.jpg (12.9 KB, 7 views)
__________________
2008 Chevrolet 3500HD DRW LTZ
285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
  #70
Old 07-12-2018, 04:27 PM
Gearhead
Default
Quote:
Thanks, I'll find where this bastard goes tonight.
As for the thermostat cover pipe. Do you guys put RTV on top of that oring?
  #71
Old 07-12-2018, 05:17 PM
2004LB7's Avatar
Default
No RTV. Just make sure everything is cleaned up nice and have good/new o-rings
__________________
  #72
Old 07-14-2018, 02:51 AM
Gearhead
Default
I need to replace this gasket , where the studs are pink next to the large turbo pipe.
Any idea what part number this is? thanks
  #73
Old 07-14-2018, 02:12 PM
2004LB7's Avatar
Default
Whats wrong with the gasket?
I think this is the one
https://shop.advanceautoparts.com/p/...E&gclsrc=aw.ds
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
