Old 07-09-2018, 03:14 PM
DOINSND's Avatar
DOINSND DOINSND is offline
FNG
Default 2005 LLY Swap into 2003 LB7 Cold Intake Problem
I have a 2003 Lb7 Duramax. I put a 2005 LLY engine in it. And I installed a 2006 LBZ mouthpiece on it.
My question is I need to install a Cold air intake box and tubing into the 2003 truck. So the MAF is from a 2003 -2005 uses the the same MAF. The only problem is the 2006 MAF is different style bolt up. So all the after market 2006 intakes tubes won't work with the 2005 MAF.
Can I run the 2006 MAF with my 2005 wiring.
Thank you
I have EFI live in the truck
Old 07-09-2018, 04:12 PM
Burn Down's Avatar
I don’t know on the maf being able to be made to work, I doubt it. The only piece guys use is the lbz mouthpiece with an lly air tube and lly air box. The mouthpiece and tube don’t line up super well but it works.
04.5 CCSB ole blue, built trans, mpi twins
03 Reg Cab ZF 6
05 CCSB ole crappy, built eng, built trans, mpi twins
Old 07-09-2018, 06:43 PM
RPM Motorsports's Avatar
smokinum
01-07 MAF “bolt up” the same, but LBZ MAF is not the same internally. 07.5 LMM was a change in MAF style visually and bolt pattern
(Russ)
17 CC/SB L5P 4x4 High Country
73 RC/NB LBZ Nova Grocery getter
Old 07-09-2018, 09:11 PM
frankenstien's Avatar
frankenstien frankenstien is offline
If I'm reading that correctly, you might have a completely different MAF?
I have a 2005 LLY, with a LBZ mp, and a LBZ S&B intake, I don't remember there being any issues with it bolting up, I didn't have to buy a different MAF, how ever, it did have to be rescaled for the larger intake tube.
I can grab a pic of the intake if you want
2005 ECSB LLY
Danville Tuned
5'' exhuast
Fass 150
Built Trans w/SC1058
Bumpers built by me
Old 07-10-2018, 08:59 AM
Budneeds2beers's Avatar
Budneeds2beers Budneeds2beers is offline
Aka Mike Honcho....
^ thats how ive read it on here. I also have a 04.5 lly and wanted to do an intake. Everything I read said go lbz and have it calibrated for that maf.
Old 07-10-2018, 06:30 PM
DOINSND's Avatar
FNG
I thought it was a different MAF, it looks like they changed it after 2007 so it should work. MY BAD
Old 07-11-2018, 05:24 AM
LCAC_Man LCAC_Man is offline
Gearhead
You will probably have to change your MAF voltage table, the difference is usually enough to kick a CEL.
Len Barron
2000 Express 155"wb Passenger Hightop
Old 07-11-2018, 10:21 AM
THEFERMANATOR's Avatar
LEGALLY INSANE
You do have to modify the tune, but an lbz intake WILL work on an lly after the tune changes. It's one of the 1st upgrades I reccomend to lly owners. Even GM installed LBZ intake system's on lly overheater's, hence the factory tune file being available for the round air filter.
  #9
Old 07-12-2018, 04:18 PM
DOINSND's Avatar
FNG
I put a LBZ intake in and it worked fine. I did not change my MAF or tune. No codes yet
