Old 07-11-2018, 03:36 PM
RobsDmax's Avatar
RobsDmax RobsDmax is offline
Default Looking For Opinions On Just How ****ed I Got
Bought a used short block from a guy up here in Canada. Heads from another fella in up here as well but a different guy. Please see attached. One is the piston from one cylinder. 2 more have marks on the inner bowl. Other pictures are the injector bore on the So Cal stage 1s that were supposed to be stage 2s. Just looking for opinions on whether it is a good coffee table or mildly useable.
Thanks.
2003 Chevy LB7 RC/LB
EFI By Kory
2003 Chevy LB7 CC/SB "Cheap Hooker"
EFI By Kory - S400 HSP Kit - 2.5" Billet Charger - 2.8" Puller
2008 GMC LMM CC/SB
EFI By Kory - Magnaflow Exhaust
Old 07-11-2018, 03:37 PM
RobsDmax's Avatar
Worst piston picture will not load. If anyone would have a look I’ll gladly text it. Thanks.
EFI By Kory
2008 GMC LMM CC/SB
Old 07-11-2018, 03:57 PM
2004LB7's Avatar
2004LB7 2004LB7 is offline
Reduce the file size first and see if it loads
2008 Chevrolet 3500HD DRW LTZ
Old 07-11-2018, 04:00 PM
RobsDmax's Avatar
Trying as a screenshot. Says it worked. One has touched a valve. Just looking for opinions as to wether I attempt to return this. Bought both wrapped up “good to go”
File Type: jpg D1D47250-0B45-4A9F-BC84-DB6083C8DB36.jpg (52.0 KB, 117 views)
EFI By Kory
2008 GMC LMM CC/SB
Old 07-12-2018, 05:50 AM
Bdsankey Bdsankey is offline
The head concerns me and looks like it lifted and started to torch the bore a little bit.
The short block could be ran if you needed to. Like above, depends on what you paid and what else is in the short block.
Current Rides:
-820hp/1748ft-lbs @ Duramax Tuner (6/25/18)
-Built Motor, Bullseye Batmowheel S475/87/1.0 "Comp R75", Exergy 250% overs with "Redman" internal mods, Exergy 14mm street pump w/AN feed, Goerend "J" Converter, Built Trans, AD2 165, Beans Sump, E-Locker, TrueTrac, Yukon 4340 Shafts, Traction Bars, DHD Center Link Brace, DHD Lower Crossmember Support
Past Rides:
1) 2002 LB7 CCSB, Leather, Loaded
-New Bosch Reman Injectors, New LBZ CP3, FASS 150, RCD Sump, 3" MBRP Downpipe, 4" Downpipe Back w/ Muffler, Sleeves, DHD Centerlink Brace, DHD Lower Crossmember Support, Steering Wheel Radio Control Swap
Old 07-11-2018, 03:56 PM
2004LB7's Avatar
Looks like it dropped a valve or made contact with one
Have you measured the Piston protrusion yet?
Old 07-11-2018, 04:03 PM
RobsDmax's Avatar
Have not measured the protrusion. Was told it was good to have heads put on and ran.
EFI By Kory
2008 GMC LMM CC/SB
Old 07-11-2018, 04:10 PM
SSchmi5519's Avatar
SSchmi5519 SSchmi5519 is offline
Pro Tuner Wannabe
Looks more like melt to me
-Steve- 2005 LLY Inglewood Transmission, EFI Live, PPE, ARP, Crower, BT Diesel, T&B Fab
Email: ASK.SSDT@GMAIL.com
  #9
Old 07-11-2018, 04:20 PM
2004LB7's Avatar
Yeah, that last photo looks like it is eating through the Piston from excessive heat.
  #10
Old 07-11-2018, 04:34 PM
MarkBroviak's Avatar
MarkBroviak MarkBroviak is offline
DMax Junkie
It's definitely melted/eroded on the last picture. Not a good thing at all. Also got a valve contact pretty good on the other. Could you use it if you had too, yes.
06 LBZ "White Lightning" 2wd rclb DP built motor Carillo, 15.25:1 "Finger" Oval Pistons w/reliefs, Socal Titanium upgraded springs on Stock heads w/Socal Billet injector holddowns,ARP, head-main-rocker studs,Soca Billet mains& Dampner, Chromoly pushrds, DP B72mmstg2R1VGT/StainlessDiesel S472/87 1.0SS triples, DHD Cast SuperHighflow intake, Exergy 14mmCP3 & 250%inj,Fass, PPE Race Valve PPE Manifolds, Banks Technicooler, AFE Boost tube, SC GMax6 Goerend "G" Grizzly Locker 3.42 gears, 1198+++hp 2k+ftlbs
Current fastest pass 1.520 60ft 6.705@108.95mph 1/8th 10.242@140.11mph
Current Standing 1/2Mile record holder for Diesel Pickup @ 159.8mph
Made it on fastest DMax list with Single VGT and single cp3 fuel only! 1.589 60ft 6.9291@103mph 1/8th 10.96@127.76mph
Stock motor best 11.277@119mph B68mmStg2R 250%inj 12mmcp3
Wife's tow rig-08 LMM SierraHD SLT2 "Stormy" CCSB murdered out 68mmSTG2R Exergy 12mmcp3 1/8th 7.93@88mph 1/4-12.408@109.18mph
06 GP GXP 5.3L StealthGray Metallic
http://www.danvilleperformance.com
http://www.youtube.com/markbroviakdp
http://www.youtube.com/channel/UCV6K...?feature=watch
Mark@DanvillePerformance.com
  #11
Old 07-11-2018, 04:36 PM
NC-smokinlmm's Avatar
<<<Future tuna killer
Yep, eroded piston your ****ed...
  #12
Old 07-12-2018, 02:55 AM
PureHybrid's Avatar
Isuzu Shakes IT
Depends on how much you paid, and what other parts are in the short block. Cylinder walls in decent shape?
Jesse
  #13
Old 07-12-2018, 05:37 AM
RobsDmax's Avatar
To give you a rough idea, 10k. Included the fingers, carillos, cam, welded water pump, merchant mounts, head studs, super damper. Stock mains and bolts though. Heads were another purchase that I know I got screwed on as I paid for stg2s and they are 1s. Yes the walls are decent and the block is clean as far as condition goes.
EFI By Kory
2008 GMC LMM CC/SB
  #14
Old 07-12-2018, 07:12 AM
Chevy1925's Avatar
imho, you paid too much for the issues at hand.
i wouldnt use that short block, those issues would bug the shit out of me knowing they are there and could potentially kill the block
James
best time to date: 12.39
Tailgate Crew Member #4
  #15
Old 07-12-2018, 07:43 AM
RobsDmax's Avatar
Unfortunately I agree. Really bad that you cannot trust anyone these days. I am at the same point however neither seller is doing anything for me unless I send the pistons back, so I will likely end up running it. Will not see many miles however thats probably a null point now.
EFI By Kory
2008 GMC LMM CC/SB
