  #16
Old 09-22-2017, 09:23 PM
malibu795's Avatar
malibu795 malibu795 is offline
Default
I broke the OEM twist lock version long time ago..
Hopkins also make 4 bolts version that's plug in play to the OEM connector.. used it for a while till I started having issues with the OEM side of the connector then cut everything off..
I've put some serious tongue weight on this super hitch, upwards of 3500lbs, not to mention sled pulling with it.. LMM has yet to be hooked to a sled... Maybe next year
__________________
Adam
mispeeling wrods n a thraed nere u
07.5 3500hd RCLB LMM GT4088R, 4.56 gears 225/70/19.5 efi live 478k broke block
99 FL60 8.3 12v 13sp
Quote:
smooth seas never made a skillfull salior
  #17
Old 09-22-2017, 09:32 PM
torqued2dmax's Avatar
torqued2dmax torqued2dmax is offline
Default
Now thats a hitch , nice mods and thanks for pics !
__________________
05 CC/LB DRW LLY Allison
AFE Blade Runner,AFE Momentum CAI,DHD Big Air intake Y pipe, DHD fuel block,DHD pcv reroute,MBRP 4 inch exhaust,DHD 3 inch downpipe,BD driver's side manifold,DHD pass side up pipe,DHD 3 inch intercooler hot&cold pipes, ATI damper,Empire pin kit by Big Foot on & off road shop, FASS fuel system,5/8 inch pickup, FASS fuel filter delete, EFI live,V2 & lap top , 5 position switch 250 hp big tune, shimmed fprv by Crank it up , built SunCoast Allison 1078 converter aftermarket trany mount by Limitless Diesel,ARP head studs,grade C gaskets,tig-welded water pump,T stats by Blackout performance,MA t case brace , Kriptonite motor mounts,MA pump rub kit,HD drive shaft 1480joints by Greensburg machine,BDS Recoil traction bars, PPE finned deep pan , Mike L trany cooler, PSC pump, 5100s, Sulastic Shackles, Curt com 2.5 hitch
  #18
Old 09-23-2017, 05:44 AM
malibu795's Avatar
Default
Not recommend needed to move both 4 miles
__________________
Adam
  #19
Old 09-23-2017, 08:10 AM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
Default
Oh my...
__________________
06 GMC 2500 CCSB SLT LBZ 4X4
These views expressed on this post are not my own, but rather randomly generated computer gibberish, and in no way should be used to judge the author's IQ or mental health.
  #20
Old 09-23-2017, 08:39 AM
ChrisPerry's Avatar
ChrisPerry ChrisPerry is offline
Default
Why not do 1 at a time so as not to risk damaging truck or trailer?
__________________
02 GMC 2500HD, EC/LB, LB7, 2wd, 6" lift, 35" tires. ds LML manifold, PPE 260 hp tune, boost valve, race plug, Airdog 165 lift pump, CAT filter mod, mechanical egt and boost gauges, SB intake, high flow turbo horn, ported turbo exhaust housing, kbd drop in wheel, Banks Bighead wastegate, egr blocked, intake heater delete, PPE downpipe, 5 " exhaust w/ cat delete, Mike L built trans w/ Goerend R converter. Levi's heat blankets
7-6-17...New headgaskets, studs, Fed heads, and LDS replacement injectors @ 202,239 Miles
  #21
Old 09-23-2017, 08:59 AM
Hambone's Avatar
Hambone Hambone is offline
Always learning
Default
Quote:
Haha same reason we take all the groceries in the house in one trip... we are men!
Those bearings are probably shot now if you did any sort of tight turn
__________________
2017 2500 CC/LB "L5P" WT
2005 2500 CC/SB "LLY" LTZ
Typical mods for Longevity
awaiting stuff to go BooM then replace with more go fast parts!
And a few other retired Duramax's
06 360k aka Hog truck
07 320k aka Shop truck
07 340k Flatbed spare welding rig
  #22
Old 09-23-2017, 09:01 AM
malibu795's Avatar
Default
Tandem 7k Trailer.
13k on deck roughly...
Neither going to hurt my truck or that Trailer, Trailer was maxed out though
Needed both bobcats to unload another Trailer and couldn't leave one unattended
__________________
Adam
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
