  #1
Old 11-14-2017, 09:19 PM
Nickracer9 Nickracer9 is offline
Gearhead
Default 09 Lmm recent upgrades and now white smoke.
Getting a lot of white smoke at startup with some light engine shaking until it warms up a bit. Sitting in my driveway it can smoke for quite a bit but if I start driving it, it clears up within a couple minutes. Recently added 100 over injectors, 68stg2r and an exergy 12mm pump. Once itís up around 130 degrees balance rates are all under 1 percent but at start up #2 is giving me a +7. Changed out the glow plug but still the same issue. Whatís my next step guys? I did notice after I shut the truck off rail pressure goes down to nothing within 20 seconds but it does start right up. Truck is a beast when warm and runs like it should after itís reached temp but man it can puff some smoke until then. Any help is appreciated, Thanks!
  #2
Old 11-15-2017, 03:57 AM
ZeroGravity58's Avatar
ZeroGravity58 ZeroGravity58 is online now
Default
Sounds like you need to work on the tuning some. you can't drop in 100 over injectors and expect it to act like stock without alittle bit of leg work...
__________________
09 lmm ccsb ltz, mpi s480 over stocker, big dipper trans, 60 overs, 10mm stroker pump, ppe up pipes and manifold, banks intercooler & exhaust, airdog165, traction bars, the list goes on
01 lb7 red RC/LB 11.58@119 MPH, SOLD
01 lb7 Black CC/LB, SOLD
  #3
Old 11-15-2017, 04:07 AM
Yngdmax92's Avatar
Yngdmax92 Yngdmax92 is offline
Default
Compression check?
__________________
2003 2500 hd cc/sb (leftovers) MPS 63.5 ihi, built trans, airdog 150, 30 overs..... Sold
New and improved! 2007 classis lbz LS ec/sb
Egr delete, pcv re-route, PIPED, airdog 4g 165,
Danville performance tunes.
  #4
Old 11-15-2017, 05:38 AM
Lmmbrad33's Avatar
Lmmbrad33 Lmmbrad33 is offline
IBEW 15
Default
Quote:
This^^ & make sure that power is getting from the glow plug control module to the glow plugs and that something wasn't left unhooked. You didn't mention any codes, but prior tuning may have had GP codes disabled?
__________________
'08 GMC CCSB
3794 II/60% INJ/2X CP3
'04.5 GMC RC
All Stock Rust Free
  #5
Old 11-15-2017, 07:05 AM
Gearhead
Default
Iím working on getting a compression tester to check #2 and what kind of tuning changes do you suggest so I can let Mark know?
  #6
Old 11-15-2017, 07:06 AM
Gearhead
Default
Quote:
Should I just use a test light and have someone key it on?
  #7
Old 11-15-2017, 11:12 AM
Default
When you changed the glow plugs did you use ac delco plugs? Call Mark and tell him what you have and see what he suggests. I'm sure he run into this kind of stuff before if it is the tuning
__________________
  #8
Old 11-15-2017, 11:37 AM
Gearhead
Default
Yes I used an ac Delco glow plug in cylinder 2. Just talked with Danville and he mentioned I might need to reserialize the new injectors with a tech 2.
  #9
Old 12-04-2017, 06:05 PM
Gearhead
Default
Update, Mark noticed my map sensor isn’t reading properly in one of my logs, got a new one on order. Hope this is it!
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
