  #1
Old 06-21-2017, 01:12 PM
Switch's Avatar
Switch Switch is offline
FNG
Default F#%$&*$@ new guy!
Sorry guy been stalking awhile haven't joined. So I did today and ill upload an avatar and pics soon.
Picked up a new too me but fairly well used LLY. Still trying to piece together what was done to it.
What I know:
EFI Live with DSP5 switch (no clue what tunes are) it will be seeing the duramax tuner soon to get it retuned.
AFE Intake
5" Straight Exhaust
6" Lift
37" Tires (modded fenders to fit)
Steel driveshaft
Has a banks 6 gun (not hooked up thankfully) sitting in it.
Issues so far
Headlights distorted - replaced with projection
Grill painted black - Replaced
CV boots ripped - Have Two new axles that are going in tonight
God Awful brake rattle - Have new hardware that will go in tonight
Surging issue around 1400 rpms - I assume im looking at an FPR soon
Vibration around 50mph - I think I have narrowed this down to an unbalanced rear driveshaft (tires are getting balanced tonight)
So far I have done oil, Fuel filter, Tranny fluid, Transfer case service, rear diff service, replaced headlights and grill and drove
Thanks for all of the knowledge (that I stole) and look forward to learning more!
  #2
Old 06-21-2017, 04:36 PM
zakkb787's Avatar
zakkb787 zakkb787 is offline
<thatís not me...
Default
Welcome. Looks like you're headed in the right direction. Just make sure you contribute to the forum as well.
__________________
Without a duramax... hopefully not for long.
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s. And itís currently broke
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
  #3
Old 06-21-2017, 05:40 PM
torqued2dmax's Avatar
torqued2dmax torqued2dmax is offline
Default
I hope your tune is not locked , and dont forget to check for a pump rub kit ! Good luck and welcome !
__________________
05 CC/LB DRW LLY Allison
AFE Blade Runner,AFE Momentum CAI,DHD Big Air intake Y pipe, DHD fuel block,DHD pcv reroute,MBRP 4 inch exhaust,DHD 3 inch downpipe,BD driver's side manifold,DHD pass side up pipe,DHD 3 inch intercooler hot&cold pipes, ATI damper,Empire pin kit by Big Foot on & off road shop, FASS fuel system,5/8 inch pickup, FASS fuel filter delete, EFI live,V2 & lap top , 5 position switch 250 hp big tune, shimmed fprv by Crank it up , built SunCoast Allison 1078 converter aftermarket trany mount by Limitless Diesel,ARP head studs,grade C gaskets,tig-welded water pump,T stats by Blackout performance,MA t case brace , Kriptonite motor mounts,MA pump rub kit,HD drive shaft 1480joints by Greensburg machine,BDS Recoil traction bars, PPE finned deep pan , Mike L trany cooler, PSC pump, 5100s, Sulastic Shackles, Curt com 2.5 hitch
  #4
Old 06-21-2017, 08:53 PM
PureHybrid's Avatar
PureHybrid PureHybrid is offline
Isuzu Shakes IT
Default
Welcome!
Danville Performance is going to be a lot closer than Duramaxtuner
__________________
04 GMC ECSB LLY - Mix breed trans/SC1056 - Profab - PPE - Kennedy twin pumps/pickup - Danville tuning: 531/944
I can't complain, but sometimes I still do
Jesse
  #5
Old 06-21-2017, 10:50 PM
Budneeds2beers's Avatar
Budneeds2beers Budneeds2beers is offline
Aka Mike Honcho....
Default
Injector #2/7 harness rub and connections. Also ignition switch.... i learn something new once a month. Welcome
  #6
Old 06-28-2017, 11:36 AM
1ATony's Avatar
1ATony 1ATony is offline
Default
Welcome to the site it's great to have you here
Tony
  #7
Old 11-09-2017, 06:00 AM
Switch's Avatar
FNG
Default
Quote:
Originally Posted by PureHybrid View Post
Welcome!
Just wanted to update you this is where i ended up going.... great people there. More than happy. Ther tune made great dyno numbers...
Sent from my SAMSUNG-SM-G891A using Tapatalk
  #8
Old 11-09-2017, 07:52 AM
Mike L.'s Avatar
Mike L. Mike L. is online now
Default
Welcome
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #9
Old 11-09-2017, 11:25 AM
Hambone's Avatar
Hambone Hambone is offline
Always learning
Default
Welcome
__________________
2017 2500 CC/LB "L5P" WT
2005 2500 CC/SB "LLY" LTZ
Typical mods for Longevity
awaiting stuff to go BooM then replace with more go fast parts!
And a few other retired Duramax's
06 360k aka Hog truck
07 320k aka Shop truck
07 340k Flatbed spare welding rig
  #10
Old 11-09-2017, 12:27 PM
Chevy1925's Avatar
Chevy1925 Chevy1925 is online now
Default
Welcome! pics of current CV angles please. adding new axles may not stop you from tearing those if the angles are severe.
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #11
Old 11-14-2017, 06:38 PM
ShawnR ShawnR is offline
FNG
Default
Did you end up finding the vibration cause?
  #12
Old 11-14-2017, 07:30 PM
Switch's Avatar
FNG
Default
Quote:
Sorry i missed this, ill get some pics... but the boots were old and neglected.. the new axles are holding up nicely.
  #13
Old 11-14-2017, 07:32 PM
Switch's Avatar
FNG
Default
Quote:
So i balanced the tires, had the transfer case, and transmission flushed and the vibration was gone. However its starting to come back again...i think its a tire balance problem again.... one tire was pretty far off last time.
  #14
Old 11-15-2017, 12:49 PM
Switch's Avatar
FNG
Default
Here is a pic of the angle its really not that bad
  #15
Old 11-15-2017, 01:55 PM
Chevy1925's Avatar
Default
10-4, Yeah thats not bad at all. did you keep the old axles? if they didnt run completely dry, you can buy a boot kit and fix them up. they are stronger than the replacment stuff out there, plus the boots dont last as long on the aftermarket stuff. even the replacement boots dont last as long as stock.
__________________
James
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
