Old 11-14-2017, 09:54 PM
Josh154's Avatar
Josh154 Josh154 is offline
Default 372sxe
Anybody see this yet? I may have to swap mine out and try this next spring.
http://www.dieselarmy.com/features/s...turbochargers/
08 CCSB LMM - HSP 369sxe kit, 10mm S&S cp3, built trans with suncoast 1058, supporting mods and Danville tuned
Best 1/4 mile
12.86 - 104.92mph
Old 11-14-2017, 10:11 PM
SickLL7Crenshaw's Avatar
SickLL7Crenshaw SickLL7Crenshaw is offline
Billy The Kid
Oh ya, been eyeing it since Borg featured it at SEMA. No part number yet that I know of.
Blake
SOLD: 05 LLY CC/SB 140k 11.18@123.7 stock/480
01 LB7 EC/SB 302k 11.61@116.8 69sxe stock motor
Tuned by Unleashed Duramax Tuning
Crenshaw Ranch, LLC. 8LB7s, 7LLYs, 1LBZ , 2LMMs, 1L5P
Thanks to Evan@Limitless, yellowchevy, and Henry@COTNP
Old 11-14-2017, 10:45 PM
1TRIKHD's Avatar
1TRIKHD 1TRIKHD is offline
Country boy Limo.
So if the 372sxe is good for 1100hp, what is the 472sxe good for?
2006 CCLB LT3 Victory Red
SDP Built Trans w/ Goerend G billet stator
S472sx-e .87/1.0ar w/ SDP Piping
Wagler street intake
Tuned by Aaron Wiebe
Custom 80" Trac Bars by MBS Diesel
ADII 165
Full Kryptonite Front end
PPE manifolds up pipes
Special Thanks to: Scott@ SDP, Aaron Wiebe @ All In Truck Performance, Lyle & Clay @ Bama Offroad, and Justin Goode @ MBS Diesel
Best time to date: 12.80 @ 110.78
Old 11-15-2017, 07:25 AM
tsd_billy tsd_billy is offline
Id be interested in the spool characteristics of a 72 mm on that small of a frame. Subd
Vgt swapped lb7, street block built by bobby at Mikes performance engine
Old 11-15-2017, 08:06 AM
Josh154's Avatar
I donít foresee 1100hp possible.. 750-800 on this 369 will be pushing it hard
Best 1/4 mile
12.86 - 104.92mph
Old 11-15-2017, 10:11 AM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
They rate turbos on gas engines
2006 ccsb Lbz Tow rig
2006 rclb 6.6
Old 11-15-2017, 10:22 AM
DAVe3283's Avatar
DAVe3283 DAVe3283 is online now
I have a S371, which is a custom modded S366 that is pretty similar to their new S372sxe, but without the fancy exhaust side turbine. I routinely blow the bearings out of it when turned up over 700HP, so I limit it to 660HP and it survives.
With their improvements to the exhaust side thrust handling and the new turbine, it can probably handle a bit more, so I am with Josh154: 750-800 HP will be the max if you want it to survive.
I am interested how the new exhaust side will spool. My S371 isn't too laggy, but if they can make this spool a bit better, that would be sweet. Really, though, I need to move to a compound setup, I can't get the power and drivability I want with a single.
The real question I have is would this hold up as the high pressure charger in a compound setup, or is it still wise to go to a S472 instead?
Old 11-15-2017, 12:25 PM
Awenta's Avatar
Awenta Awenta is offline
Thatís big for a 300 frame. No thanks.
Dave whatís your a/r? Should work good compounded. It wonít be worked as hard
Arek
2003 CCSB LT LB7 deleted
EFI by Kory
  #9
Old 11-15-2017, 12:37 PM
DAVe3283's Avatar
I think it is a 0.95 or a 1.0. I'd have to go check my records.
  #10
Old 11-15-2017, 01:13 PM
hntngkd's Avatar
hntngkd hntngkd is online now
I have a billet S371sxe from Forced inductions as my valley charger and its very responsive. My only issue is the drive pressure because I haven't had a chance to get the gate tuned in. Other than that its great.
2006 "LLY" ECLB DRW, DEAD 5/3/2015.... Alive again..... 11/30/16
Fingers cast 15.5:1, R&R rods, Callies billet crank internally balanced, Wagler AF stage 2 Cam, Main Girdle, Billet Mains, Fire ringed block,
Wagler Pushrods, Valve Springs, Ported LBZ heads
SBDDD 3600lb sintered iron
HSP Compounds SXE-371/S485 V2 by Forced Inductions, Profab castflow manifolds, Turbosmart Hyper-gate HP45, Turbosmart Race port BOV and controller, Mishimoto Intercooler
Exergy 250% injectors, Dual Fuelers, Fuelab 200
Danville tuning
FF Dynamic Fans
ARB air locker
2017 Cruze LT diesel LH7 stock
  #11
Old 11-15-2017, 01:34 PM
dirtymax36 dirtymax36 is offline
2nd place is last
Works turbochargers make an sxe374/74/1.0 and will do some serious 800+ numbers gated. They make a mean charger and have been proven in the Midwest so far this past year. Especially since Midwest workstock pulling classes limit you to s300 frame chargers
04.5 LLY CCSB Built Motor/trans. Some fast spinny things.
  #12
Old 11-15-2017, 01:45 PM
Evan@LimitlessDiesel's Avatar
Evan@LimitlessDiesel Evan@LimitlessDiesel is online now
yerp
That Work Turbocharger s374 is a beast and we beat the hell out of it with no issue's. After taking with Reed about my doubts of that big of wheel in a s300 he assured me there would be no issues and told me of the applications they were already being used in and I had 100% confidence in it and we had no issues.
Limitless Diesel Performance
413-770-3585
  #13
Old 11-15-2017, 01:50 PM
2nd place is last
Agreed. Reed knows his stuff and will build anything you'd imagine. Over 1k hp on Cummins trucks and they are proven. People have been saying the center section can't handle that big of wheel but they can prove themselves over time !
  #14
Old 12-10-2017, 06:05 PM
Ne-max's Avatar
I like turtles
Bump. Any word on these yet?
2006 rclb 6.6
  #15
Old 12-18-2017, 11:21 AM
ctodd36 ctodd36 is offline
Gearhead
Iíve got a Danville 2.5 s300 right now but if they have a 374 Iím gonna have to call Mark and have a new one built. That 374 is definitely going to outperform a 369
04 ECSB 2.6SB Puller in Progress
13 CCLB LML Daily
