Old 01-24-2018, 05:27 AM
durawhore's Avatar
durawhore durawhore is offline
Default Low oil chime
Fixing a few issues on a buddys truck. I can't seem to get this low oil chime to go away dash reads low psi replaced oil pressure sensor along with wiring harness to the sensor still no chang. only comes on when truck is warm and rpms are under 1800 trucks been drove like this for awhile so it' obviously has psi. any other thoughts? going to to a gauge on it to check it
Old 01-24-2018, 11:08 AM
PACougar's Avatar
PACougar PACougar is offline
I certainly wouldn't just assume you don't have low oil pressure because you've been driving it around like that. Have you checked the pressure with a scanner or EFI Live? If that reads low, I'd recommend you get a mechanical guage and check the pressure.
2004 LB7 EC/LB 2WD Dropped 6" in the front on coil overs and 7" in the rear on 18"s, Hellwig front and rear sway bars. Caltracs traction bars.
Socal Diesel built bottom end, FI S480 Billet wheel and race cover, RDL Headers and pipes,
Dual Cp3(1 modded and 1 stock), Exergy 100% over injectors,
Socal Diesel injector clamps, Socal Stage 2 Heads/ARP Head Studs
Suncoast GMAX-5 plus some billet built by my best friend Dave(He's a Badass like that), 1058 converter, MikeL Cooler
Mag-Hytec pans on Tranny(Scraping a little) and Diff
Custom modified MBRP exhaust i.e. it dumps in front of the rear tire(Also by Dave). Never had a cat
Labonte Motorsports water/meth, AirDog II 200
Custom 5" Intake Pipe w/AFE Filter, BD Cool It Intercooler,
EFI Live DSP5
Torsen limited slip(POSI), Gauges
DON'T PURCHASE FROM INDUSTRIAL INJECTION UNLESS YOU ENJOY GETTING SCREWED!
Old 01-24-2018, 11:22 AM
Chevy1925's Avatar
^^exactly. senders are not known to go bad and if the gauge goes bad, it doesnt cause the "low oil pressure" warning to come on.
ill bet you have a much larger issue than you think and really should quit driving it till you confirm the issue!
James
best time to date: 12.39
Tailgate Crew Member #4
Old 01-24-2018, 01:49 PM
durawhore's Avatar
Its not being drove. Until i get a mechanical gauge put on it. Like i said its a buddies truck not mine. motor was just built not long ago
Old 01-24-2018, 03:01 PM
Chevy1925's Avatar
bet either an oil galley plug got missed or the pump spun on the shaft...
James
Old 01-24-2018, 02:25 PM
oscyjack's Avatar
oscyjack oscyjack is offline
I was gonna say sounds like it's time for a compression check
'08 LMM CCSB
Limitless trans
EFIlive - PPEI
Built front end
All the bolt ons
33x11.5 on 17x9 -12
HB/brake upgrades
oscyjack's Avatar
Who built the motor
'08 LMM CCSB
Limitless trans
EFIlive - PPEI
Built front end
All the bolt ons
33x11.5 on 17x9 -12
HB/brake upgrades
Old 01-24-2018, 04:06 PM
durawhore's Avatar
Originally Posted by oscyjack View Post
Who built the motor
Not even gonna open that can of worms
  #9
Old 01-24-2018, 02:27 PM
PACougar's Avatar
Knowing that the motor was just built is a pretty good indication that you have a real problem on your hands.
EFI Live DSP5
  #10
Old 01-24-2018, 04:44 PM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
Who built the trans
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #11
Old 01-29-2018, 04:52 PM
durawhore's Avatar
Hooked up a gauge today cold its reading 80psi then after it runs for a few minutes and warms up it slowly drop to about 15psi im sure it'd drop more after getting warmer i just shut it off at that point.....
Where to start now with this nightmare?
  #12
Old 01-29-2018, 04:56 PM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
15 PSI at what RPM and what coolant temperature? My LB7 idles at about that when warm.
If it is that low above idle, the problem is somewhere in the build. Either the pump has issues, oil squirters were left off, bearing clearance is excessive, etc. Sadly, all of these require taking it out and opening up the bottom end. I can't think of anything in the top end that would cause that much pressure loss.
  #13
Old 01-29-2018, 05:07 PM
durawhore's Avatar
15psi while idling at around 190 degrees .
@2000rmps oil pressure is @ 45psi.
As it gets hotter pressure drops low enough to signal the low oil pressure light
  #14
Old 01-29-2018, 05:10 PM
DAVe3283's Avatar
@2000rmps phlogiston pressure is @ 45psi.
As it gets hotter pressure drops low enough to signal the low phlogiston pressure light
How much hotter does it get? I rarely see 210° when towing, 180-190 is what it runs normally. But if it hits the low oil light, it has a problem for sure.
Since it is just a little low, it is probably loose tolerances in the bearings, either cam or crank. Only way to tell is open it up and measure. Unless you see something obvious on the way to removing the crank / cam.
  #15
Old 01-29-2018, 06:01 PM
durawhore's Avatar
Well fack guess its coming back out guess we will find out whats really inside it..
