  #1
Old 03-24-2017, 07:14 PM
02ilduramax's Avatar
02ilduramax 02ilduramax is offline
Default dry sump
is anyone running a dry sump oiling system? just curious how big of a oil tank you run or how to determine tank size
__________________
build it til it breaks
2002 lb7 cc/sb afe stage 2 intake, MBRP 5in exhaust, airdog-165, efi live tuned by dans diesel performance, tie rod sleeves, stage 4 trans by mike l
  #2
Old 03-25-2017, 03:54 AM
ikeG's Avatar
ikeG ikeG is offline
Oughta Know Better
Default
This is a good question. We have yet to bite the bullet and go to dry sump, but the benefits to it in our situation our huge. What will your application be? CompD might be the place to ask that general question, in the sled pulling section.
__________________
Isaac Griffith, formerly 04jimc
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
New DD/Beater: Beat up 06 GMC CCSB w/ 252,000 miles
Current Tow Rig-12 Ram 4500 Crew
'Oughta K
now Better'- PPL Lim Pro Stock 05 3500 Crew Cab 158" WB 2014 PPP 2.6 Champions
Thanks to Blackout Performance
  #3
Old 03-25-2017, 05:07 AM
Default
mine will be drag racing and since i put an 88 s10 i have the motor set as low as i cocan in the frame and will have to run the dry sump and i will be strictly drag racing
__________________
  #4
Old 03-25-2017, 08:58 AM
Yellow Jacket's Avatar
Yellow Jacket Yellow Jacket is offline
WannaBe Sled Puller
Default
I'd have to measure for sure, I think we have a 3.5 gallon tank.... But you only fill it just over half full, we run about 2 gallons of oil in it.
My tank, mandrel, and pulley's came from Jones Racing Products.... I run a large billet filter head that uses Motorcraft 7.3 filters...
We ran a dry block, so I wanted more oil to carry & dissipate heat, you can run as much or little as you are comfortable with to my knowledge.
__________________
2005 Yellow DMAX CC/SB, Fleece 63.5 VGT, 100% Exergy's, Goerend Trans, Burkhardt Spool/Axles, FASS 150
3.0 Pull Truck: 2003 CC/SB Tilt Body, ProFab Dropbox/Reverser, Crower 4 Disc Clutch, FDS75 front /Aluminum Meritor 20-145 Sheet Metal Housing, Hart's HC5A, Product Engineering 460 gph
  #5
Old 03-25-2017, 08:59 AM
duramaxzak's Avatar
duramaxzak duramaxzak is offline
Wanna be puller!
Default
Do you use a oil preheater?
__________________
- ZAK
2011 CHEVY 2500HD CCSB Duramax/Allison LTZ
2005 CHEVY 2500HD RCLB 2WD Duramax/Allison
2002 GMC 2500HD RCLB Duramax/allison 2.6 puller
Special thanks to:
- Danville performance, Mark.
- Suncoast transmission's, Andrew.
- Wehrli custom fab, Jason.
- Profab, Rick
- Turbo performance, Levi.
- HSP, Joe and Dave.
- SoCal diesel.
- Wagler competition, Jeramy.
  #6
Old 03-25-2017, 09:13 AM
WannaBe Sled Puller
Default
Quote:
Nope, we start the truck a few trucks before we pull, usually right after rolling off the scale....The oil tank will be warm/hot before we wind 'er up
__________________
  #7
Old 03-25-2017, 10:07 AM
ikeG's Avatar
Oughta Know Better
Default
This is what we do. Filled block & solid heads with stock wet sump. Just have to be careful because with the oil trapped in the engine still, oil temp rises quick and takes eternity to cool off after runs. Need good batteries cuz you end up starting, shutting off bunch of times prior to pulling. Have yet to have a problem​, but I'm sure it's a lot easier with dry sump.
Sent from my XT1585 using Tapatalk
__________________
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #8
Old 03-28-2017, 06:49 PM
Default
how many stage pump are you guys using and where are your stages pulling oil from. pan? heads? turbo drain backs?
__________________
  #9
Old 04-04-2017, 10:55 AM
WannaBe Sled Puller
Default
Quote:
Somehow I missed this question sooner.....
5 stage, 4 stages sumping from PPE oil pan and 1 pressure stage from reservoir to oil cooler block off plate for engine supply
__________________
  #10
Old 04-17-2017, 07:24 PM
Default
sorry for all the questions but what size pulleys do you USD how fast or slow should i be turning the pump? And how do you have it attached to the motor?
__________________
  #11
Old 04-17-2017, 08:01 PM
moparkxracer's Avatar
moparkxracer moparkxracer is offline
Default
They make an adaptor the mounts to the front of the crank, you have to remove some of the damper bolts and they get replaced. You come off the side of the engine with the mounts for the pump. You can mount driver or pass side. You have to let them know what side when ordering the pump the mounts are not the same. You can play with the pulley sizing to get the oil pressure where you want it to be. Jones racing sold me the adaptors and vac pump setup for mine. They are very helpful with their products
__________________
Thank you to:
Engine build: Burkett racing
Transmission: be in Evans hands soon
Turbo spec: Shane (S Phinney on here)
Turbo kit built: myself and Landon at Shade tree triples
Tuning: Mark at Danville performance
Fueling: Exergy
And everyone else who made this possible, Thank you!!
  #12
Old 04-19-2017, 06:00 PM
Default
What size line are you guys using on the scavenge side. And are you feeding oil in where the oil coolee usually is???
__________________
  #13
Old 04-20-2017, 02:48 PM
WannaBe Sled Puller
Default
I made my own right-hand side block mount....
-16 from tank to a washable SS filter/prescreen to keep debri out of pressure love of pump, then -12 to a billet filter head & 7.3 diesel filter and -12 to SoCal oil cooler delete plate...
__________________
  #14
Old 05-09-2017, 05:17 PM
Default
Yellowjacket thank you for all the info what size are your scavenge lines from the pan?
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
