  #1
Old 03-19-2018, 08:23 PM
firefighter13's Avatar
firefighter13 firefighter13 is offline
I'm Batman!
Default Where’d you mount your sump on an LML?
Hey all, I did search but couldn’t find much for some reason. I’m sure it’s been beaten to death.... but where did you mount your sump? I’ve got a 15.5 LML and really want to get it right. Anyone have any pics of theirs? Thanks in advance
__________________
2015 Denali 3500hd CC/SB
Sold: 2004 GMC LB7, Magnaflow 4" turbo back, Autometer Boost and Pyro, PPE High Idle Kit, Custom IHI, SDP Twins , LBZ CP3, EFI LIVE DSP5, Mike L. Stage IV Allison and Precision Industries M.L. Converter - Thanks Mike! , Mike L. trans cooler, Airdog II 165, Lots of PPE goodies thanks to Dan! 7" BDS High clearance lift with Fox Shocks and 35" Toyo MT's
70 SS 454 Chevelle, Big Block LS-7 Soon to be home to a 650hp 502!
Big thanks to "Hangenouthere" Dan for helping make it what it is!
  #2
Old 03-19-2018, 09:07 PM
I'm Batman!
Default
I’ve seen the ones under the sending unit but from what I’ve read it seems that at the back of the tank behind the rear strap might be a better option. Any input from experience would be appreciated
__________________
  #3
Old 03-19-2018, 11:38 PM
2004LB7's Avatar
2004LB7 2004LB7 is offline
Default
I don't have one but the back of the tank is where I think it would be best
Going up hill and having the fuel run to the back where it can get to the sump. This is where you would need it the most. When headed down hill you use little fuel so if you are running low it won't be as likely to suck air.
My take
__________________
2008 Chevrolet 3500HD DRW LTZ
285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
  #4
Old 03-20-2018, 03:08 AM
036.6turbo 036.6turbo is offline
Default
Mine's all the way forward. Lowest portion of the tank. Been running it like this since last spring, zero issues.
http://www.duramaxdiesels.com/forum/...25&postcount=4
__________________
2003 GMC Sierra CCSB.
LBZ / Six speed / EGR Delete / DSP5 with tuning from Idaho Rob @ ATP Trucks / Bilstein 5100s / Air Ride 5000 bags / Merchant Reman Tcase / TNR head unit.
2015.5 Denali. Dmax Allison, under construction.
  #5
Old 03-20-2018, 03:13 PM
Vmyrhaug Vmyrhaug is offline
Gearhead
Default
my is mounted in the center of tank. working fine for me... never under 1/4 tank anyway...
  #6
Old 03-20-2018, 04:35 PM
clrussell's Avatar
clrussell clrussell is offline
pro-procrastinator
Default
Every sump I've ever installed is always under the sending unit.
Only reason I would put at the rear is if you race with literally no fuel in the tank then I could see it.
Average person center of the tank is fine
__________________
17 GMC all terrain L5P, stock with dark windows
07 crew long classic- stolen
  #7
Old 03-20-2018, 05:18 PM
Whitetail Addict's Avatar
Whitetail Addict Whitetail Addict is offline
Rockin' the stock tune
Default
Mine is right under the sending unit centered in the "circular" area on the bottom of the tank.
__________________
Brandon
'12 LML
'03 LB7
If you feel like everything is under control, you're not going fast enough - Mario Andretti
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
