  #31
Old 05-04-2018, 09:10 AM
Chevy1925's Avatar
Chevy1925 Chevy1925 is online now
Default
Go down to Larry's Engine and Marine in Tucson. Larry machines all the engines i do. its a drive but he wont bull shit you and knows what those heads need to be fixed properly. Ive seen way too many shops in phx badger duramax stuff or take 5 times as long as they should on a parts.
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #32
Old 05-04-2018, 12:51 PM
Diesel Joe Diesel Joe is offline
Gearhead
Default
Thanks James, appreciate that.
__________________
02 Silverado, Ex Cab Long Bed, LB7 cali, CAT delete with MBRP 4" and muffler, PPE Boost valve, Superchips Flashpaq
  #33
Old 05-04-2018, 01:06 PM
zakkb787's Avatar
zakkb787 zakkb787 is online now
<thatís not me...
Default
Well I’ll be damned, I wasn’t the only one this happened to
__________________
Without a duramax... hopefully not for long.
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s. And itís currently broke
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
  #34
Old 05-04-2018, 02:49 PM
Gearhead
Default
Quote:
Originally Posted by zakkb787 View Post
Well Iíll be damned, I wasnít the only one this happened to
But the question remains, WHY. I set all valves to .012, I have read where many set there's to .010. I checked the lifter thinking maybe the roller got egg shaped somehow, looks perfect. Oh well, guess at 350k it probably was time for head work and gaskets anyway. Just hope it doesnt happen again.
__________________
  #35
Old 05-04-2018, 05:33 PM
zakkb787's Avatar
<thatís not me...
Default
Same thing with mine. Freak thing. Went together perfect. But pulled apart and push rod was bent bad. Valves stamped into the piston. But no cracks and valves weren’t bent either.
__________________
Other toys:
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
  #36
Old 05-04-2018, 08:29 PM
duramax on fire duramax on fire is online now
Default
Quote:
Just currious which method did you use to set the valves? I always use the ICEO method. Intake closing and exhaust opening. (Set exhaust whenintake just starts to close and set intake when exhaust just starts to open) And I start with one and work my way down the bank. We did this on all our 14:1 race motors and never had an issue. Someone correct me if I'm wrong but should work on a diesel the same. I've seen some methods where they set 2 or 3 at the same time with out rotation of motor. Works for many but I never liked it. Using the ICEO method and doing one at a time you know your on the bottom of the cam lobe. Sorry to here about your motor.
Also would look at the adjusters when done and make sure the same number of threads was sticking up each. Just to see if one looked funny.
  #37
Old 05-05-2018, 09:55 AM
ikeG's Avatar
ikeG ikeG is online now
Oughta Know Better
Default
I wouldn't trust that method 100% because of possible valve overlap. If you run stock firing order, print out merchant automotive's cheat sheet in color. It tells you which valves you can set on just two revolutions. On a AF engine I use a piece of stiff wire down thru the injector bore to keep track of tdc on the compression stroke and set each cylinder one at a time.
Sent from my XT1585 using Tapatalk
__________________
Isaac Griffith, formerly 04jimc
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
New DD/Beater: Beat up 06 GMC CCSB w/ 252,000 miles
Current Tow Rig-12 Ram 4500 Crew
'Oughta K
now Better'- PPL Lim Pro Stock 05 3500 Crew Cab 158" WB 2014 PPP 2.6 Champions
Thanks to Blackout Performance
  #38
Old 05-05-2018, 09:57 AM
ikeG's Avatar
Oughta Know Better
Default
https://www.merchant-automotive.com/...x#productTabs1
__________________
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
