  #1
Old 04-09-2018, 05:28 PM
2005redlly 2005redlly is offline
Gearhead
Default Questions about balance rates
I picked up a lb7 and it has a white haze and rough idle. I had my oil tested and it came back with high copper (67). No fuel in oil.
Truck is warm and in drive
Cylinder 1- -4
2-0
3- -1
4-0
5-4
6-1
7-1
8- -1
Warm in park
1- -5
2-1
3- -2
4- 1
5-4
6-1
7-2
8- -2
Wondering if the injectors are the issue?
__________________
2005- BW FMW S467.7/83/.90 / 100% overs/ppe dual fuelers/ Efi live by DA/ DA trans/ SC1055-2/ arp headstuds/ bbp traction bars/ DHD lock box/ A.D165/ truetrac/ fleece tapshifter
stock turbo/fuel 1/4mile-13.3@103 1.9 60' @7290lbs
Stock cp3 12.01@113.50 1.66 60'
1/8mile 7.50@91 11.83 1.69 60' 113mph
1/8mile 7.41@93 11.67 1.68 60' 115mh
2004 sclb ls. Stock for now
  #2
Old 04-09-2018, 05:32 PM
Gearhead
Default
Also sounds like a lope tune sometimes to me.
__________________
  #3
Old 04-09-2018, 05:33 PM
zakkb787's Avatar
zakkb787 zakkb787 is offline
<thatís not me...
Default
You definitely have one injector reading out of spec and one right on the line. Canít speak as to the copper tho
__________________
Without a duramax... hopefully not for long.
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s. And itís currently broke
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
  #4
Old 04-09-2018, 05:38 PM
Gearhead
Default
You think it's cylinder 1 and5?
__________________
  #5
Old 04-09-2018, 05:45 PM
Ne-max's Avatar
Ne-max Ne-max is offline
I like turtles
Default
Time for a set of injectors
__________________
2006 ccsb Lbz Tow rig
2006 rclb 6.6
The fun stuff. Built motor, trans, triples
  #6
Old 04-09-2018, 06:05 PM
Gearhead
Default
Is the v2 capable of turning injectors off? I was told these injectors only have 45k on them. Would only replacing the bad ones be ok?
__________________
  #7
Old 04-09-2018, 06:11 PM
duramax on fire duramax on fire is offline
Default
I had a haze at idle balance rates where about the same as yours.
Theres no way I would do all that work for one. If you have a bank open do all 4 just me. but you need to figure out the rough idle first. make sure its not the pump or fpr causing the idle issue.
Plus when you pull the high pressure line it fills the top of the injector full of crap. Been several guys that ruined injectors 10k miles later after head gasket job
  #8
Old 04-09-2018, 06:12 PM
ZeroGravity58's Avatar
ZeroGravity58 ZeroGravity58 is offline
Default
Could also be a bad fpr causing the lope.
__________________
09 lmm ccsb ltz, ATP tuning, mpi s480 over stocker, big dipper trans, 60 overs, 10mm stroker pump, ppe up pipes and manifold, banks intercooler & exhaust, airdog165, isspro guages, traction bars, the list goes on
01 lb7 red RC/LB 11.58@119 MPH, SOLD
01 lb7 Black CC/LB, SOLD
  #9
Old 04-09-2018, 06:25 PM
Gearhead
Default
Another thing, I can let it idle for awhile and when I leave it leaves a big cloud of white smoke. So the injectors wouldn't cause the rough idle? And also a fuel leak somewhere in the valley area.
The reluctor wheel came loose, and I got the truck truck somewhat cheap. Would the reluctor wheel cause the rough idle if it wasn't exact?
Thanks for all the help
__________________
  #10
Old 05-07-2018, 11:11 AM
Philv's Avatar
Philv Philv is offline
Gearhead
Default
Mine is doing the same thing. I have already diagnosed it as bad injectors. I have noticed that when the truck lopes, it'll smoke more. Sometimes it'll run smooth and very little smoke. My injectors only have roughly 80k miles, but been smoking for a long time.
__________________
2001 GMC Sierra 2500HD SLE EC/LB 4x4
Cold air intake
4" exhaust
Wastegate trickery thingy. Lol
  #11
Old 05-07-2018, 11:38 AM
2004LB7's Avatar
2004LB7 2004LB7 is offline
Default
Should check the fuel pressure. See how stable it is and how close it matches the command pressure
__________________
2008 Chevrolet 3500HD DRW LTZ
285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
