  #31
Old 12-05-2017, 08:35 PM
tsd_billy tsd_billy is offline
Default
Quote:
Originally Posted by Codido187 View Post
I am in los Lunas New Mexico thank you for help. I went to a diesel mechanic today and they’re Fox was put 2 quarts of atf in my tank and I said no thanks.
Im located in oklahoma but i travel to west Texas often. I know some good mechanics out that way
__________________
Vgt swapped lb7, street block built by bobby at Mikes performance engine
  #32
Old 12-05-2017, 08:48 PM
Codido187 Codido187 is offline
FNG
Default
Awesome I hear Pete’s is pretty good in Belen but I was trying to fix the dang thing on my own. Who do you recommend out this way?
  #33
Old 01-04-2018, 04:40 PM
FNG
Default
Alright here is the update it was a bad fpr I replaced it with a Bosch and truck is running top top shape. Easiet way I found to get to the fuel pressure regulator was remove the coolant lines ac compressor and where the fprv is located remove the banjo bolt and force gave me plenty of room to get the fpr in and out in a breeze. It took me roughly 2 hours pulling it apart and 2 hours putting it back together.
  #34
Old 01-04-2018, 05:21 PM
ikeG's Avatar
ikeG ikeG is online now
Oughta Know Better
Default
. Good to hear. Feels good to figure a problem out!
__________________
Isaac Griffith, formerly 04jimc
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
New DD/Beater: Beat up 06 GMC CCSB w/ 252,000 miles
Current Tow Rig-12 Ram 4500 Crew
'Oughta K
now Better'- PPL Lim Pro Stock 05 3500 Crew Cab 158" WB 2014 PPP 2.6 Champions
Thanks to Blackout Performance
  #35
Old 01-04-2018, 06:20 PM
FNG
Default
Heck yeah thank you everybody for all your help next is finding a good hid kit and front and rear bumper
  #36
Old 01-04-2018, 07:15 PM
joshd472's Avatar
joshd472 joshd472 is offline
Default
Glad you got it sorted out.
  #37
Old 01-04-2018, 09:08 PM
Default
__________________
  #38
Old 04-15-2018, 03:23 PM
nwodiesel nwodiesel is offline
Gearhead
Default
Quote:
Originally Posted by IOWA LLY View Post
The fuel tables and idle rpm will vary with coolant temperature. And if the ECT sensor is disconnected it will think the coolant temp is very cold. (-40f) So the idle rpm will be raised and all sorts of other strange things will happen because the ECM is trying to compensate for the extreme cold.
Hi I'm wondering if I'm having the same problem. 200 rpm higher idle, and loud like its -30....Plus it cycles the Glow plugs every start for about 7-8 seconds just like it was -30. I have no engine lights either. I don't have a way of scanning so I have to go to a shop Thanks
  #39
Old 04-15-2018, 05:40 PM
ikeG's Avatar
Oughta Know Better
Default
Quote:
You will have to check the pids with the scan tool to see what it thinks coolant temp, ambient temperature, etc are.
Sent from my XT1585 using Tapatalk
__________________
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
