  #31
Old 05-20-2017, 08:00 PM
830king's Avatar
830king 830king is offline
Originally Posted by Ridin'GMC View Post
Just directly above the lower valence under the radiator support.
I believe I found them, drivers side was tucked under radiator and passenger side was tucked around the horn. I gotta pull the dash cover off and look to see ig I have a harness going to back og where the switch would be.
Sent from my SM-G930V using Tapatalk
2005 2500hd ccsb 4x4 automatic, atp trans safe tuning, cts insight with egt probe, arp head studs, welded water pump, lml drivers side exhaust manifold, manga flow down pipe, silver line 5" exhaust, s&b cai, s&b turbo mouthpiece, fass titanium 150, beans sump, profab egr delete, MA pump rub plate, alligator trans lines, Kryptonite ss centerlink/tie rods, Kryptonite lower ball joints, Kryptonite sway bar end links, rare parts idler and pitman arms, dhd steering brace, 285/75r16 duratracs on stock py0's, b&w turnover gooseneck rancho 9000 shocks
  #32
Old 05-20-2017, 08:30 PM
830king's Avatar
Originally Posted by WVRigrat05 View Post
Yep, there's little tabs to clip them back out of the way. I had to buy the little harness from the fuse panel to the switch, but double check first.
My cargo switch has 6 wires coming out of it. Does that sound like I already have the correct harness for the fogs switch? Or does the switch for the fogs have it's own harness?
HTML code is On
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
