  #61
Old 02-26-2017, 11:09 PM
Awenta's Avatar
Awenta Awenta is offline
Default
I'd like to see this on marks dyno measuring cylinder pressure
__________________
Arek
2003 CCSB LT LB7 deleted
Some cool stuff, some fast stuff, some slow stuff
EFI by Kory
Special thanks to Evan@Limitless
  #62
Old 02-27-2017, 08:18 AM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
Default
I think you guys are giving GM way too much credit. Having looked through a bunch of stock Duramax and LS tunes, I think GM gets it close, then phones it in once it passes emissions and makes their power target. The stock LB7 tune is a hot mess, especially the early ones.
I don't believe this was done to protect the crank. The amount of fuel is way too low to do anything meaningful. Plus, think of the shock loading the moment you step on the throttle after exhaust braking down a hill. It goes from ~0 mm3 to 40+ instantly. That first cylinder will have a huge differential loading vs the rest (which are still at 0).
I have noticed a recurring theme on stock Duramax tunes that might explain this, though. GM has had the timing for low fuel amounts (0-5 mm3) set really high since the beginning, and what this does is cause a "growl" as the transmission downshifts, especially in tow/haul. My dad (and probably lots of others) really, really like this sound on the downshift. I've played with the timing in that range, and the only thing it seems to do is change the note of the growl. I'm guessing GM did something similar on the L5P, and it isn't supposed to happen except in tow/haul.
Not that anyone asked for it, but that's my
__________________
  #63
Old 02-27-2017, 09:47 AM
2004LB7's Avatar
2004LB7 2004LB7 is offline
Default
Yeah, I doubt GM did this for a "growl". I think the best guess is what the ferm mentioned on crank harmonics. It make sense, they only need to inject just enough on random cylinders to upset the harmonics nothing more.
__________________
2008 Chevrolet 3500HD DRW LTZ
285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
  #64
Old Yesterday, 04:07 PM
JoeyD's Avatar
JoeyD JoeyD is offline
WTF
Default
My 16 van does it and was concerning but I guess not.
__________________
16 LGH Savanna
98 6.5 TD Pro Rok 60 front, ARB's front and rear, 4.56 Gears,37"KM2's
  #65
Old Yesterday, 06:10 PM
Hambone's Avatar
Hambone Hambone is online now
Always learning
Default
Well seeing as this thread popped bag up figure Iíll update it with a bit of info...my buddy and fellow coworkers Ď17 3500 dually with a flatbed and welding setup was making a weird ticking sound following rpm at idle in park/drive
Poured some sea foam in the tank and didnít notice any changes
Turned out to just be in a weird regen cycle we havenít noticed before
He also had a leaking rear differential seal that warranty fixed
__________________
2017 2500 CC/LB "L5P" WT
2005 2500 CC/SB "LLY" LTZ
Typical mods for Longevity
awaiting stuff to go BooM then replace with more go fast parts!
And a few other retired Duramax's
06 360k aka Hog truck
07 320k aka Shop truck
07 340k Flatbed spare welding rig
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
