  #16
Old 02-06-2018, 09:17 AM
SAC owner SAC owner is offline
Gearhead
Originally Posted by IOWA LLY View Post
Beep Beep Beep...... WRONG. Only the LML uses Piezo injectors. LB7-LMM are all solenoid injectors.
Well damn you are correct I have miss spoke
  #17
Old 02-06-2018, 09:43 AM
Hoser Hoser is offline
Gearhead
Originally Posted by RPM Motorsports View Post
Incorrect... The L5p WILL bolt onto earlier generations, they just added two extra bolts to the L5P
I was referring to it being a “bolt on” part, meaning you can remove the old part and bolt the new part in place with no modifications. The new head is completely different. Having to change to an L5P intake as well as several other modifications to me doesn’t qualify it as a bolt on head, but yes, it will bolt onto a previous gen block, even though all the bolt holes won’t be filled. . . . . Even still, looking at the bottom sides of those heads in the pic that I posted, it doesn’t look like a lot of the passages even line up.
  #18
Old 02-06-2018, 10:15 AM
RPM Motorsports's Avatar
smokinum
What passages are you referring to, the pic you posted is not the bottom side of the head, unless I missed a pic somewhere. The pic you posted is the intake runner area. The L5P block does have a raised deck height, but the heads are the same height. The intake runner is slightly different yes. All of the main 12mm head bolts are the same, they just added two of the small 8mm head bolts to the top corners.
(Russ)
17 CC/SB L5P 4x4 High Country
73 RC/NB LBZ Nova Grocery getter
  #19
Old 02-06-2018, 01:31 PM
Yngdmax92's Avatar
Yngdmax92 Yngdmax92 is offline
Drill an tap
2003 2500 hd cc/sb (leftovers) MPS 63.5 ihi, built trans, airdog 150, 30 overs..... Sold
New and improved! 2007 classis lbz LS ec/sb
Egr delete, pcv re-route, PIPED, airdog 4g 165,
Danville performance tunes.
  #20
Old 02-06-2018, 02:50 PM
SSchmi5519's Avatar
SSchmi5519 SSchmi5519 is offline
Pro Tuner Wannabe
Originally Posted by Yngdmax92 View Post
Drill an tap
Shit I would just leave them out
-Steve- 2005 LLY Inglewood Transmission, EFI Live, PPE, ARP, Crower, BT Diesel, T&B Fab
Email: ASK.SSDT@GMAIL.com
