  #16
Old 01-02-2014, 08:31 PM
duramaxnokaoi duramaxnokaoi is offline
Gearhead
Default
Ok. with 3 feet of extensions and a big breaker bar I was able to get the converter bolts out and all but the bottom two bell housing bolts. And as far as I can tell all electrical and plumbing connections are disconnected.
So, any tips or last minute advice? I know I need to support the front of the trans and someone else said to tryn keep pushing the converter back so it doesn't fall out.
ALso, I can't find a good spot on the passenger side rear of the engine to lift from. The threaded hole in the head is blocked by the up pipe. Is it ok to lift from the driver rear and passenger front only?
Thanks for helping and putting up with the 1000 noob questions...
  #17
Old 01-02-2014, 08:39 PM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
Default
Usually the converter will stay on the input shaft when pulling the engine. As long as your supporting the engine I don't see why not to use those holes. I used a 4 point leveler on my engine when it came out and went back in
__________________
"OldManTan"
04 SC/SB 1500 big fuel, big SXE turbo, TH400 10.12 @140 815rwhp RIP 12/12/17
06 Cummins cc/sb EFI by Hardway.
Tailgate Member #1 I prefer the backdoor
  #18
Old 01-02-2014, 08:55 PM
x MadMAX DIESEL's Avatar
x MadMAX DIESEL x MadMAX DIESEL is offline
<<<< No Horsepower
Default
The tc bolts needed a breaker bar, were they that tight? Could you remove the heatsheild on the uppipeto gain access the the ps rear head holes? An engine leveler is a good idea. I might go pick one up in the next couple of days
__________________
Ben
LBZ Stock Charger
12.26@108.8
7.78@87.7
2.5 puller in the Mecca!!
Manual Mafia
Quote:
Originally Posted by BgBlDodge View Post
Al gore invented driving the turbo.
  #19
Old 01-02-2014, 08:56 PM
<<<< No Horsepower
Default
Also I jack up the trans and put a 1.5 square tube from torsion bar to torsion bar to set the bell housing on. Works great, I think I've actually used a 2x4 before. And x2, always good to be cautious but that tc most likely ain't goin nowhere
__________________
Ben
LBZ Stock Charger
12.26@108.8
7.78@87.7
Manual Mafia
  #20
Old 01-06-2014, 09:21 PM
Gearhead
Default
When you say turn the engine clockwise, is that looking at the engine from the front? What happens if you turn it ccw?
  #21
Old 01-06-2014, 09:24 PM
Harbin_22's Avatar
Harbin_22 Harbin_22 is offline
Turning it back up!
Default
You can turn it either way. But it would be clockwise if you were standing in front of the truck looking at the motor.
__________________
10' CCSB
Carrillos, Fingers 16.5:1 Cast Pistons, 3388AF Cam, PPE Dual CP3's, Exergy 200% inj, Danvile Billet 72R, HSP tripples/2-SXE369's, Limitless Diesel All Billet Comp Trans with LD TC, DHD lock up, Air Dog, Banks, RDL, CalTracs, QA1, M/A, Isspro, Novakanes/420's, 30x14 cheaters
Tuning from Mark@Danville
1,101HP/1727ftlbs
6.72@108 1/8
10.41@133 1/4
  #22
Old 01-06-2014, 09:25 PM
Gearhead
Default
A load leveler would have been awesome! It was a royal pita, but of I had either removed the turbo or hacked the cab up 2-3 inches it wouldnt't have been that bad.
My diesel mech has the engine now, ps head is off and it looks like cylinder no 7 is at least one of the culprits. Driver side comes off tomorrow.
Yes the tc bolts were that tight, but looks like they had lock tight. I under up using several wratchet straps to pull the engine cause I didn't have a load leveler. While it did work, it was still a pita. I think I could have removed the heat shield, but since I'm putting PPE manis and ups on I just hooked one of the wratchet straps to the mani/bracket.
Thanks for everyone's help!
So, what else should I be doing while the engine is out... Other than the HG's with arp's of course, water pump, glow plugs, and what else am I forgetting?
  #23
Old 01-06-2014, 09:33 PM
Harbin_22's Avatar
Turning it back up!
Default
Why are you doing a water pump and glow plugs?
__________________
10' CCSB
1,101HP/1727ftlbs
6.72@108 1/8
10.41@133 1/4
  #24
Old 01-06-2014, 10:40 PM
Gearhead
Default
Because I don't know if it's been done and it's got 198K, and I had 3 glow plug faults prior to pulling the motor.
  #25
Old 01-06-2014, 10:51 PM
Harbin_22's Avatar
Turning it back up!
Default
Good reasons then lol. Didn't relieze it had that many miles
__________________
10' CCSB
1,101HP/1727ftlbs
6.72@108 1/8
10.41@133 1/4
  #26
Old 01-12-2014, 12:57 PM
John Grav's Avatar
John Grav John Grav is offline
FNG
Default
I need a good referance guide for duramax 03 any susgestions
Sent from my HUAWEI H881C using Tapatalk
  #27
Old 01-15-2014, 06:39 PM
Kappa9012's Avatar
Kappa9012 Kappa9012 is offline
MAN.... I Broke it again.
Default
haines now has a manual out for the duramax.
__________________
07 Lmm CC/SB
Built ally w/1057
Exergy 60 overs
Dual Cp3's
Billet S480 over stock from Wehrli
The man behind the tuning is Idaho Rob
  #28
Old 01-10-2017, 10:49 PM
stibuilder's Avatar
stibuilder stibuilder is offline
Default
Any issue with lifting the motor and transmission out as a single unit if you dont have a cab in the way?
  #29
Old 01-10-2017, 11:12 PM
bmc1025 bmc1025 is offline
Default
Nothing wrong with that but it is heavy and cumbersome. a forklift or loader will be your friend obviously.
__________________
98 C3500HD 6.5TD
03 Chevy 3500 CC Dually
06 GMC 3500 CC Dually
  #30
Old 01-10-2017, 11:52 PM
stibuilder's Avatar
Default
Quote:
I planned on pulling it into the shop to use the overhead crane. Not sure on attachment points, but at least one around the tail of the transmission and other on the heads, or something like that.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
