Old 01-11-2018, 09:21 AM
1sgkarlthomas's Avatar
1sgkarlthomas 1sgkarlthomas is offline
FNG
Default My Monster had a stuck valve HELP okay 2013
I need a little help with my 2013 I'm getting a code for stuck C fairly certain the solenoid self isn't the problem more than likely valve is stuck I've seen several posts I've with this subject but no really answers any help would be greatly appreciated and I understand experience sometimes is Doing It Wrong repeatedly I make the assumption that everyone on here is smarter than me thanks in advance for any assistance FYI it sucks to be stuck in 4th gear
Old 01-11-2018, 09:57 AM
fast03's Avatar
fast03 fast03 is offline
Its a good thing you finished with this "FYI it sucks to be stuck in 4th gear "
or we would not have known what you are talking about. Built trans? do a search on here for stuck in 4th ... I am sure one of the tranmission guys will chime in with some help.
Good luck.
2011 LML maybe a little not stock
Previous Dmax: 2003,CCLB,4088r,mikel trans and other goodies
Steve
Old 01-11-2018, 09:58 AM
Mike L.'s Avatar
Mike L. Mike L. is online now
Need a lot more info.
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
Old 01-11-2018, 11:34 AM
FNG
Thanks
Details 2013 2500 HD. 169000 miles healthy engine no real power adders 6 inch pipe and SG intake delete kit. Allison 1000 12 Bolt pan got stuck in mud dropped pan swapped filters next day drove 50 miles did another fluid and filter change started getting code for C solenoid stuck fluid again drained both filters replaced twice with quality filters shifts OK up to 4th. Inspected pan and filter magnets dirty no chunks about what I expected for that mileage wiring harness looks fine did not check continuity. Fairly certain some form of foreign matter is culprit fluid looks clear I don't expect solenoid C is bad assume more likely the valve. So my real questions are can the valve or valves be freed some way without VB removal other than Devine intervention? If not best practices for VB removal and fixing my issue AND any suggestions or thoughts you deem helpful
Old 01-11-2018, 12:58 PM
Chevy1925's Avatar
Originally Posted by 1sgkarlthomas View Post
Thanks
Whats a intake delete kit? no tuner on it? how hard were you on it stuck in the mud and what did you do to get it un stuck? What are the actual code numbers that come up and give them ALL in the order they were shown on the scanner. what are "quality filters"?
We are not there to see the truck, we are trying to diag though braille so you have to get in depth with your descriptions.
James
best time to date: 12.39
Tailgate Crew Member #4
Old 01-11-2018, 01:54 PM
FNG
Took another truck that dragged me through the muddy water about the 20 feet and 3 foot deep broke 3 serious chains in process. It took 3 hours Sorry should have read as S&G Air intake system, and DEF delete. Quality filters and fluids Wix filters and name brand txsm fluids NOT Walmart brands Codes P0700 Transmission control system( MIL Request) and P0762 Shift Solenoid C stuck on
Old 01-12-2018, 11:42 AM
FNG
Any advice? Lol good or bad at this point
Old 01-12-2018, 12:11 PM
FNG
So I'm reaching out to the community of those transmission wizards to see if anyone had ever been able to unstuck a valve without removing the VB from the transmission I realize most likely not but gotta ask
  #9
Old 01-12-2018, 01:22 PM
ZeroGravity58's Avatar
ZeroGravity58 ZeroGravity58 is offline
Since no one else has asked....why were you in 3 foot of water?
09 lmm ltz, mpi s480 over stocker, big dipper trans, 60 overs, 10mm stroker pump, ppe up pipes and manifold, banks intercooler & exhaust, airdog165, traction bars, the list goes on
01 lb7 red RC/LB 11.58@119 MPH, SOLD
01 lb7 Black CC/LB, SOLD
  #10
Old 01-12-2018, 02:18 PM
joshd472's Avatar
joshd472 joshd472 is offline
Going by his sentence structure (or lack there of). I'm going to say he's not the brightest fella out there.
  #11
Old 01-12-2018, 02:36 PM
IOWA LLY's Avatar
IOWA LLY IOWA LLY is online now
Yes, its really me
Easy guys. Not everyone has stellar grammar.
Iím answer to the question, no you arenít gonna be successful un-sticking the valve without removing the valve body.
2003 GMC CCSB LLY
Built by me, tuned by me.
  #12
Old 01-12-2018, 05:31 PM
DAVe3283's Avatar
DAVe3283 DAVe3283 is online now
Removing the valve body isn't that bad from what I have seen. You need to be careful putting it back to torque it EXACTLY with a calibrated wrench, and get a manual before pulling the valve body apart, because little parts can go flying.
  #13
Old 01-12-2018, 06:07 PM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
X2
I don't know how different the valve body is from the 2006 models, but it was easy to remove and disassemble. The key is putting it together the right way and keeping everything the meticulously clean.
06 GMC 2500 CCSB SLT LBZ 4X4
  #14
Old 01-12-2018, 06:24 PM
Awenta's Avatar
Awenta Awenta is offline
This. Donít use the ďeh feels snugĒ approach because youíll do more harm than good.
Stick it in the freezer for a few hours and if it moves freely then youíre good to go.
Arek
2003 CCSB LT LB7 deleted
EFI by Kory
  #15
Old 01-12-2018, 09:41 PM
FNG
Wow thanks for ALL the responses. 1 Zero Gravity
The short answer for getting sunk in mud. The trail I was on collapsed under me and I slid down into a muddy pond. I was amazed that the truck didn't roll over. Had to climb up and out passenger door. 2. IOWA thank you, I have been in hospital brain damage from too many concussions while serving in the US Army. 3. Day and X2 thanks for the input, I will grab a Manuel tomorrow, and clearly understand proper torque. Spent about 30years working on Black Hawks, Cobras, and Hueys. And incase I missed anyone thanks to you all from, a not so stellar fella. LOL but I am a damn good shot at 1000ft
