  #1
Old 08-12-2017, 12:53 PM
prostreeter600's Avatar
prostreeter600 prostreeter600 is offline
Street rodder
Default Will 60' improve with 3.42s
Question to those that have gone from 3.73s to 3.42s . Did your 60' improve or did it get worse ?
__________________
06! GMC Sierra RC Full built motor, carillos, 14/1 Arias W/total seal rings, 9100 AF, SCalTit retainers,SCalsprings,ported heads, SCal pushrods, ARP 625 head studs, O-ringed block, keyed oil pump ,Billet Aluminum Lifters, Harland Sharp Aluminum roller rockers, studded rocker shafts, studded & girdled mains, socal balancer, socal flywheel, PPE Dual Fuelers with twin Fleece 10 mm CP3s , FASS Titanium 260 , 3" bridge, , TrRIPLES----2---S369SXEs .88ARs over a Hybrid GTX 4202R--72mm/87mm 1.0 AR ,coilovers at 4 corners, 36" ladder bars, BD cooler, Exergys w/185% MS 8 hole nozzles ,FF Dynamics fans, PPE mans & ups , MA mounts & TC Brace ,NOS, Full Billet Trans, Suncoast 10531-3D , 3.42 Gears, BT lockup box, 18x9 Raceline Assualts Hooiser Drag Radials 325/45/18s . TUNED by MARK@DANVILLE. Engine by Jason Walker San Marcus Tx Best 60'---1.44. Best 1/8---6.39@105.92. Best 1/4---9.978@136.39
  #2
Old 08-12-2017, 02:10 PM
OregonDMAX's Avatar
OregonDMAX OregonDMAX is offline
NOT IN OREGON
Default
I'm no expert but I would assume it would get worse, taller gears equals less torque multiplication.
__________________
Sean
02 CCSB
Moonshine tunes, MikeL trans, Exergy Sportsman, 4/6 drop, LML 20's/420's
  #3
Old 08-12-2017, 02:33 PM
Street rodder
Default
I halfway agree with you . Less torque multiplication will be less likely to spin the tires out of the hole which should move propel and move the truck on out of there instead of spinning . Currently my best 60' and 1/8 has been in tune 3 . Tune 4 has netted the best 1/4 mile but it still spun a little with a 60' of 1.503 versus a 1.44 in tune 3 . Tune 5 just spun way too much . I'm hoping that by going to 3.42s it will allow me to launch in tune 5 and increase my MPH and lower my 60' and ET. I was wondering what kind of luck others have had with the gear change
__________________
  #4
Old 08-12-2017, 03:30 PM
hondarider552's Avatar
hondarider552 hondarider552 is offline
Getting faster
Default
With 1600hp at the ground we haven't seen any change in 60' or 330' running 9.00's and 3.42's. 60 remains the same 1.41-1.45
__________________
"OldManTan"
04 SC/SB 1500 big fuel, big SXE turbo, TH400 10.12 @140 815rwhp
06 Cummins cc/sb EFI by Hardway.
Tailgate Member #1 I prefer the backdoor
  #5
Old 08-12-2017, 03:58 PM
Street rodder
Default
Good to know . Did your MPH and ET improve ?
__________________
  #6
Old 08-12-2017, 04:00 PM
Getting faster
Default
Quote:
Cant say. changed turbo setups at the same time. went from 9.25 to 9.04 and 148-153
__________________
"OldManTan"
  #7
Old 08-12-2017, 04:16 PM
Street rodder
Default
Yea near impossible to tell when you changed turbo setups and gears at all the same time . I'm planning on doing 3.42s everything else is staying the same with exception to a large Derale tranny cooler with fan . I'm guessing your MPH definitely picked up with that much difference in ET .
__________________
  #8
Old 08-12-2017, 04:17 PM
Street rodder
Default
I guess I missed the 148---153
__________________
  #9
Old 08-12-2017, 04:45 PM
Getting faster
Default
Whats your end RPM through the traps? Need to see where you make peak power and then compare it to RPM and see where your setup starts to run past its peak. I want to say 3.73 to 3.42 lowered top gear RPM by about 300rpm.
__________________
"OldManTan"
  #10
Old 08-12-2017, 05:19 PM
Street rodder
Default
I'm at about 4200 crossing the finish line with the 3.73s and 30" tall DRs , keep in mind that was in tune 4 . I haven't had the truck on a dyno so I don't know where peak power is . It comes alive right away and pulls super hard all the way thru . Even when I leave under desired Boost/RPM it comes alive right away . If you look at my videos on my Brag and Drag thread you'll see what I'm talking about .
__________________
  #11
Old 08-12-2017, 07:43 PM
MarkBroviak's Avatar
MarkBroviak MarkBroviak is offline
DMax Junkie
Default
My fastest pass and intervals is with 3.42's. The more power and torque you have the lower you will want the ratios. I wish I had 3.00's!
__________________
06 LBZ "White Lightning" 2wd rclb DP built motor Carillo, 15.25:1 "Finger" Oval Pistons w/reliefs, Socal Titanium upgraded springs on Stock heads w/Socal Billet injector holddowns,ARP, head-main-rocker studs,Soca Billet mains& Dampner, Chromoly pushrds, DP B72mmstg2R1VGT/StainlessDiesel S472/87 1.0SS triples, DHD Cast SuperHighflow intake, Exergy 14mmCP3 & 250%inj,Fass, PPE Race Valve PPE Manifolds, Banks Technicooler, AFE Boost tube, SC GMax6 Goerend "G" Grizzly Locker 3.42 gears, 1198+++hp 2k+ftlbs
Current fastest pass 1.520 60ft 6.705@108.95mph 1/8th 10.242@140.11mph
Current Standing 1/2Mile record holder for Diesel Pickup @ 159.8mph
Made it on fastest DMax list with Single VGT and single cp3 fuel only! 1.589 60ft 6.9291@103mph 1/8th 10.96@127.76mph
Stock motor best 11.277@119mph B68mmStg2R 250%inj 12mmcp3
Wife's tow rig-08 LMM SierraHD SLT2 "Stormy" CCSB murdered out B68mm Stg2R
06 GP GXP 5.3L StealthGray Metallic
http://www.danvilleperformance.com
http://www.youtube.com/markbroviakdp
http://www.youtube.com/channel/UCV6K...?feature=watch
Mark@DanvillePerformance.com
  #12
Old 08-12-2017, 08:06 PM
Street rodder
Default
Mark all my common sense tells me the truck should 60' better , MPH higher and lower the ET just because of the power and torque my setup is making . Hopefully my common sense is spot on . Gears will be in in the next month then it's off to the races
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
