  #1
Old 08-12-2017, 08:31 AM
Badheartbull Badheartbull is offline
Gearhead
Default P0088. Fuel rail pressure will hit 29,000 at times
So p0088 code. Replaced both fpr. Took it for a drive and it did it again 20 mile later. Cleared code drove home fine. Don't know what to do next.
__________________
"Charlize the Goldigger"
05 ccsb lly
Mostly stock
Efi live thanks Rob
MA motor mounts
07.5 ccsb lmm
Not stock
  #2
Old 08-12-2017, 08:32 AM
Gearhead
Default
Lmm built engine, ppe duel fueler, Danville tunes about 20,000 miles on setup
__________________
05 ccsb lly
Mostly stock
Efi live thanks Rob
MA motor mounts
07.5 ccsb lmm
Not stock
  #3
Old 08-12-2017, 09:00 AM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
Default
Have you talked to your tuner to see how the tune setup?
__________________
06 GMC 2500 CCSB SLT LBZ 4X4
These views expressed on this post are not my own, but rather randomly generated computer gibberish, and in no way should be used to judge the author's IQ or mental health.
  #4
Old 08-12-2017, 09:14 AM
Gearhead
Default
No. But same tunes for 20,000 miles
__________________
05 ccsb lly
Mostly stock
Efi live thanks Rob
MA motor mounts
07.5 ccsb lmm
Not stock
  #5
Old 08-12-2017, 10:27 AM
Gearhead
Default
I let my truck idle for 3 minutes it was fine then fuel rail pressure jumped to 29,000
__________________
05 ccsb lly
Mostly stock
Efi live thanks Rob
MA motor mounts
07.5 ccsb lmm
Not stock
  #6
Old 08-12-2017, 10:31 AM
IOWA LLY's Avatar
IOWA LLY IOWA LLY is offline
Yes, its really me
Default
Quote:
Check your supply side pressure.
Also make sure your return isn't restricted.
__________________
2003 GMC CCSB LLY
Built by me, tuned by me.
2009 ECI Diesel Truck Points Champion
2010 ECI Diesel Truck Points Champion
2011 ECI Diesel Truck Points Champion
2012 ECI Diesel Truck Points Champion
Big thanks to everyone who helps me.
Best 1/8th, 7.29, 98.6MPH (Street tires, fuel only, single Journal bearing GT42 charger) (2010)
Best 1/8th, 6.93, 104.24MPH (Street tires, fuel only, single HX60 turbo) (2016)
Best 1/8th, 6.60, 106.6MPH (Street tires, fuel only, single HX60 turbo) (2017)
  #7
Old 08-12-2017, 11:00 AM
2004LB7's Avatar
2004LB7 2004LB7 is offline
Default
Maybe a loose wire / bad connection at the regulator?
Can you hear the engine noise or knocking when it does it?
__________________
2008 Chevrolet 3500HD DRW LTZ
285/75/17 Nitto Dura Grapplers, 4.56 gears, Front and rear ARB lockers, Efi Live tuning by me, Raptor 160 LP, Cognito 4-6 NTB Lift, 4" Exhaust, Built Trans by Mike L.
  #8
Old 08-12-2017, 11:09 AM
Gearhead
Default
Yes sounds like a ford
__________________
05 ccsb lly
Mostly stock
Efi live thanks Rob
MA motor mounts
07.5 ccsb lmm
Not stock
  #9
Old 08-12-2017, 11:11 AM
Gearhead
Default
Pressure at lift pump is at 8 psi
__________________
05 ccsb lly
Mostly stock
Efi live thanks Rob
MA motor mounts
07.5 ccsb lmm
Not stock
  #10
Old 08-12-2017, 11:12 AM
Gearhead
Default
Was at 9psi before. I adjusted it
__________________
05 ccsb lly
Mostly stock
Efi live thanks Rob
MA motor mounts
07.5 ccsb lmm
Not stock
  #11
Old 08-12-2017, 11:37 AM
ZeroGravity58's Avatar
ZeroGravity58 ZeroGravity58 is offline
Default
Could the dual fueler box be bad?
__________________
09 lmm ccsb ltz, ATP tuning, mpi s480 over stocker, big dipper trans, 60 overs, 10mm stroker pump, ppe up pipes and manifold, banks intercooler & exhaust, airdog165, isspro guages, traction bars, the list goes on
01 lb7 red RC/LB 11.58@119 MPH, SOLD
01 lb7 Black CC/LB, SOLD
  #12
Old 08-12-2017, 12:02 PM
Gearhead
Default
Quote:
I'm going to try this next thanks
__________________
05 ccsb lly
Mostly stock
Efi live thanks Rob
MA motor mounts
07.5 ccsb lmm
Not stock
  #13
Old 08-18-2017, 06:23 PM
Gearhead
Default
I just put the new controller on 25 miles so far so good.
__________________
05 ccsb lly
Mostly stock
Efi live thanks Rob
MA motor mounts
07.5 ccsb lmm
Not stock
  #14
Old 08-18-2017, 06:33 PM
quinton's Avatar
quinton quinton is offline
Default
If it happens again check your ground and positive connections. I had my ground wire loose and it was maxing out every now and then.
__________________
EFIlive dsp5 by me, Built trans by me, 68 danville, stock fuel, lifted. died 6/20/2013 Cracked piston. Best time 12.75 on fuel
Alive 11/15/13: lowered, Built motor, s475, plenty of fuel, plenty of spray. Tune 3 fuel only 11.84 @114, Tune 5 little bit of spray 11.45 @ 121. Both times with melted turbine wheel, loose turbo from pedestal with blown out flange gasket. .
  #15
Old 08-18-2017, 08:17 PM
Gearhead
Default
Quote:
On the controller?
__________________
05 ccsb lly
Mostly stock
Efi live thanks Rob
MA motor mounts
07.5 ccsb lmm
Not stock
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
