  #1
Old 08-05-2017, 10:14 AM
coker6365's Avatar
coker6365 coker6365 is offline
Coker6303's ***** Daddy
Default LML Fan Clutches
LML fan clutches. I couldn't find this info online, but the 2015-2016 fan clutch will interchange with the 2011-2014 even though the part numbers are different.
2011-2014
Part # 25838900
2015-2016
Part # 23134137
Sent from my SM-G930V using Tapatalk
__________________
2015 Denali CC/SB LML, Farm Truck
2013 EC/SB LML, The Test Rig
2013 RC/LB LML, The Beater
2006 RC/LB LBZ, Tow Mirror Killer. Under the knife again and looking for more horsepuppies.
Big thanks to Josh Harris, Josh Chambers, and my brother Russell Coker for all the help with the LBZ.
  #2
Old 08-05-2017, 11:51 AM
malibu795's Avatar
malibu795 malibu795 is offline
Default
Through that on a LMM on a switch control like a air clutch on a big rig
__________________
Adam
mispeeling wrods n a thraed nere u
07.5 3500hd RCLB LMM GT4088R, 4.56 gears 225/70/19.5 efi live 478k broke block
99 FL60 8.3 12v 13sp
Quote:
smooth seas never made a skillfull salior
  #3
Old 08-06-2017, 08:10 PM
THEFERMANATOR's Avatar
THEFERMANATOR THEFERMANATOR is offline
LEGALLY INSANE
Default
Quote:
I have considered just this. The 09+ DURAMAX van's used a similiar EVC but still used the 21" fan blade, which would make it a near drop in for a LB7/LLY depending on height. And GM kept the same 36 mm for all the duramax fan clutches. I know somebody tried using the FORD 36mm EVC fan clutch, but it was off a 5.4l gas engine, and the fan blade just didn't move enough air at the lower RPM's.
__________________
1995 GMC 2500 SUBURBAN powered by 01 DURAMAX/ALLISON, little of this, a little of that,
DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, custom tuning by me, KENNEDY single pump and pump rub kit.
  #4
Old 08-07-2017, 05:44 AM
gmc502 gmc502 is offline
Default
what do you need to drive this?pwm or just a switched 12v?
__________________
2002 GMC 2500HD, ECSB, 4WD, LB7,300k miles and still truckin
new style gm exhaust manifold, banks big head wastegate, PPE boost valve, banks air intake,high idle switch in cruise control, stock but not for long
EFI live tuned byMe now,dps5 switch,EGT probe and autometer boost sensor,SoCal 6spd conversion
  #5
Old 08-07-2017, 07:01 AM
LEGALLY INSANE
Default
GM used a pwm, but some have found sim0ly using a toggle switch gives you an on off fan setup. If you want to vary it, you have to provide it a pwm signal. Theres a speed sensor in it to provide actual fan speed readings back to the ecm, then 2 wires that go to an electric coil. It is built exactly like a regular thermal activated fan clutch except instead of using the external thermal spring out front, it uses a small electric heated coil to turn and activate the viscous clutch. So it's not an immidiately on design as there is a small delay for the coil to be heated once power is applied.
__________________
  #6
Old 08-07-2017, 09:30 AM
zakkb787's Avatar
zakkb787 zakkb787 is offline
<thatís not me...
Default
Quote:
somebody needs to change your username to duramax wiring guru.
__________________
2006 LLY CC/SB LT3 mostly stock
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s. And itís currently broke
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
  #7
Old 08-07-2017, 09:36 AM
Chevy1925's Avatar
Chevy1925 Chevy1925 is offline
Default
so you still wouldnt get 100% lock up then. whats a stock clutch rated to? 80-90%?
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #8
Old 08-07-2017, 08:14 PM
LEGALLY INSANE
Default
Quote:
That would be Ben, aka duratothemax. I know a little about alot, he knows alot about anything electrical.
__________________
  #9
Old 08-07-2017, 08:17 PM
LEGALLY INSANE
Default
Quote:
Correct, a good tight fan clutch will achieve about 90% coupling which is the same as a evc fan clutch will get you. I know somebody working on a true on off electric clutch, but still waiting for him to finish it. Otherwise one could always retrofit in the hummer setup where it uses a hydraulic clutch that has a solenoid that sends power steering fluid to a clutch to activate it. I know some of the 6,5l guys are retrofitting them into trucks, and they use the same 36mm fan clutch spin on.
__________________
  #10
Old 08-07-2017, 09:09 PM
Chevy1925's Avatar
Default
I'm actually having a solid hub made for the truck strictly for summer time use and towing. Takes just a few min to swap them out
__________________
James
  #11
Old 08-08-2017, 12:09 AM
OregonDMAX's Avatar
OregonDMAX OregonDMAX is offline
NOT IN OREGON
Default
The number one thing I want more performance out of my fan is low speed low rpm driving and stop and go, just nowhere near enough air movement there and my truck instantly becomes a slug in anything above 100*, all the temps rise and cold A/C is non existent at that point. Freeway driving is fine I can get temps back down after just a few miles a and A/C gets colder after 10 or so minutes above 65mph. Being able to get a clutch to lock up at low/no mph would be interesting, "me sitting at a red light with high idle at 1800rpm"
__________________
Sean
02 CCSB
Moonshine tunes, Mike L trans
Mike L secret squirrel converter
Exergy Sportsman, 4/6 drop, LML 20's/420's
  #12
Old 08-08-2017, 07:10 AM
Chevy1925's Avatar
Default
Quote:
you still running the stock clutch or the 2886?
__________________
James
  #13
Old 08-08-2017, 11:20 AM
OregonDMAX's Avatar
NOT IN OREGON
Default
I picked up the 2886 after you said it was better, it helped a ton but stop and go traffic is still a killer for me
__________________
Sean
02 CCSB
  #14
Old 08-08-2017, 12:58 PM
Chevy1925's Avatar
Default
may be time to look at your refrigerant levels. once mine cools down, it stays blowing cold even in stop and go.
you might make sure your blend door is staying on recirc too. im having issues with mine randomly changing to outside air and i cant change from "vents" to defrost or anything else. even tried a new switch unit and no change so something screwy is going on. anyhow, when its on outside air, air out the vents is noticeably hotter obviously.
__________________
James
  #15
Old 08-08-2017, 11:55 PM
LEGALLY INSANE
Default
I will say my kennedy clutch locks right in sitting in traffic with the a/c on. Or oif engine temps are even near 190 sitting in traffic, it locks right in. Unlocks as soon as I take off.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
