  #1
Old 07-08-2017, 04:51 PM
Robby Avery's Avatar
Robby Avery Robby Avery is offline
GM TECH @ FENDER GMC
Default Engine oil cj-4 vs ck-4
My oil change light came on two days ago in the lb7 so I went today to get my usual oil and filter and found that chevron delo 400le is not on any shelf walmart AutoZone orelieys or any where what is the difference in the ck-4 vs cj-4 I don't want synthetics I want the conventional delo 400 le 15w-40 what gives with this new oil anyone else aware of this
__________________
2006 Chevy 2500HD LBZ Duramax Summit White CCSB Tan (neutral) leather LT3 pkg w/sunroof OEM bra 4x4, ISSPRO EV, ATS Twin CP3's, Built Allison, Eaton E-locker front stock G80 rear, Kennedy Twin pump filter combo kit, Snow Perf Stage 2 w/m injection, 4in to 5in banks tip, HM Big K&N, Mickey Thompson Baja Claw TTC 315/75/16 on stock rims, Rancho RS9000XL, Fabtech HD TR, Cognito P&I Brace kit, DD/Puller/Work Truck
2002 Chevy 2500HD LB7 Duramax Summit White CCSB Grey (neutral) leather LT3 pkg OEM bra 4x4, Kennedy Twin Pump Filter Combo Kit, ISSPRO EV, PPE Boost Valve, DTS Built Allison, MikeL Cooler, ATS Billet Flexplate, DTS 3in DS IC pipe, Bill's 5in CAI (White), Big K&N, 4in to 7in black stack, Mickey Thompson Baja Claw TTC 315/75/16 on stock rims, Cognito P&I Brace kit, Sleeves, Energy Sway bar Kit, DD/Puller/Work truck
Special Thanks: (David) DTS, (Guy) Socal Diesel, (Nick & crew) DuramaxTuner, (Dan) PPE, (John) Kennedy Diesel, (Tony) All Season
  #2
Old 07-08-2017, 05:02 PM
OregonDMAX's Avatar
OregonDMAX OregonDMAX is offline
NOT IN OREGON
Default
The 400le was replaced by the 400sde nothing we can do about it.
__________________
Sean
02 CCSB
Moonshine tunes, Mike L trans
Mike L secret squirrel converter
Exergy Sportsman, 4/6 drop, LML 20's/420's
  #3
Old 07-08-2017, 05:42 PM
TheBac's Avatar
TheBac TheBac is offline
Default
Fluids and Maintenance......
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 12.14@111.15
"Flyin' Brick" -- 1999 Chevy 1500 RC/SB 2wd -- stalled out, no motivation
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the fun little DD
"The Bigger Boat" -- 2011 Workhorse P700 - 6.0LS/Allison - what I drive at work
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
  #4
Old 07-08-2017, 06:06 PM
Default
Alright then it is still conventional though right not synthetic Oregon dmax? Thanks for moving the thread the bac
__________________
  #5
Old 07-08-2017, 07:50 PM
malibu795's Avatar
malibu795 malibu795 is offline
Default
Yes it still falls under conventional oil classification
__________________
Adam
mispeeling wrods n a thraed nere u
07.5 3500hd RCLB LMM GT4088R, 4.56 gears 225/70/19.5 efi live 478k broke block
99 FL60 8.3 12v 13sp
Quote:
smooth seas never made a skillfull salior
  #6
Old 07-08-2017, 07:53 PM
OregonDMAX's Avatar
NOT IN OREGON
Default
They updated the oil somehow to better deal with emissions, I dunno it's EPA govt bs
__________________
Sean
02 CCSB
  #7
Old 07-09-2017, 06:04 AM
Default
Ok good thanks
__________________
  #8
Old 07-09-2017, 06:51 AM
TheBac's Avatar
Default
Might've had something to do with GM's Dexos2 requirements, too.
__________________
Tom
  #9
Old 07-23-2017, 09:09 PM
THEFERMANATOR's Avatar
THEFERMANATOR THEFERMANATOR is offline
LEGALLY INSANE
Default
They stripped zinc and phosphourus out of the oil(the impact additives that allow oil to act as a barrier) to help with emission equipment life primarily. They also made changes to it to supposedly extend the drain intervals, but some changes to it are supposed to reduce hot oil pressure. Ford has not approved many ck-4 formulations, and is still selling cj-4 oil under the motorcraft brand. It's a similiar change to the one that occurred in 06 to s rated oils for gas engines, and it was largely attributed to rapid valve train wear and wiped out cam lobes in non roller motor engines.
__________________
1995 GMC 2500 SUBURBAN powered by 01 DURAMAX/ALLISON, little of this, a little of that,
DIAMONDEYE 4" exhaust, CORSA muffler, AFE stage 1 dry filter, custom tuning by me, KENNEDY single pump and pump rub kit.
  #10
Old 07-23-2017, 10:00 PM
PureHybrid's Avatar
PureHybrid PureHybrid is offline
Isuzu Shakes IT
Default
Time to stock up on Lucas Magnum HD
Although I was lucky enough to find some of the "older" Delvac hiding in the back shelf at Rural King last week.
__________________
04 GMC ECSB LLY - Mix breed trans/SC1056 - Profab - PPE - Kennedy twin pumps/pickup - Danville tuning: 531/944
I can't complain, but sometimes I still do
Jesse
  #11
Old 07-23-2017, 11:46 PM
OregonDMAX's Avatar
NOT IN OREGON
Default
This sounds pretty bad to me
__________________
Sean
02 CCSB
  #12
Old 07-24-2017, 05:44 AM
BoiseRob's Avatar
BoiseRob BoiseRob is online now
Default
The Dmax is VERY easy on oil compared to Ford or Dodge. Yes, the phos & zinc are now <1000ppm but that is more important for the Ford Powerstroke. Ford now has many CK4 spec'd oils on their "approved" list. If you want to learn more about lubricants, you should check out BITOG.com...
https://bobistheoilguy.com/forums/ub.../forum_summary
  #13
Old 07-24-2017, 04:37 PM
Cougar281's Avatar
Cougar281 Cougar281 is offline
Default
As Ferm basically said, more recent oil specs are geared towards emissions junk. The 2010 TDI jetta my wife had required an 'ESP' oil that cost more than the 10qts of Delvac1 5w40 for my truck, but for half the oil!
Sent from my 2PS64 using Tapatalk
__________________
'04.5 2500HD Silverado LT CC/LB, LBZ D/A Dark Grey
Metallic, 05+ HD Hood & Grille, 192k and counting
Mike L Trans built by ME.
EFILive, PPE Race Valve, KD Twin Lift Pumps & Billet Fuel Pickup, MBRP 4" "Cat-Back" T409 straight piped.
300.59' 3rd place first pull
Best 1/4 times:
Truck: 14.067 @ 96.29, weighing in at over 7200#
446.4RWHP/820.2RWTq
Car (95 Cougar 4.6L V8): 14.680 @ 94.00
"The FIRST weapon is the mind, all others are incidental."
"I'd rather be judged by twelve than carried by six."
  #14
Old 07-25-2017, 10:11 PM
LEGALLY INSANE
Default
Last I seen the ck-4 spec had it at 800/830 for zinc and phosphourus, same as the 06+ s rated oils. Cj-4 was 1200/1260 I believe for zinc and phosphourus, and prior to cj-4 in 06 it was 1400. I know Ford has shown quite a bit of concern over the ck-4 spec, but I haven't seen anything from GM and Cummins so far about it. You can also buy a bottle of zddp additive to add to your oil(lucas and comp cam both make one). I just used the last of my cj-4, and I'm not looking forward to buying oil for my next change. If I had known sooner, I would have bought a few cases of 15w40 at sams last year when it was on sale.
__________________
  #15
Old 07-26-2017, 07:39 AM
FSUwelder1212 FSUwelder1212 is offline
Gearhead
Default
Quote:
If you are worried about it, there are still some legacy CI-4, CI-4 plus oils still out there. Mobil delvac MX 15w40 is one, I'm thinking about giving it a whirl on my LML for my next oil change.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
