Old 02-25-2012, 07:49 PM
Blaine's Avatar
Blaine Blaine is offline
FNG
Default SW Florida
Who around here has a Dyno? Also looking for someone with a Tech 2. Thanks.
04 LLY
GMAX/ML by me. Tuned by Rob.
Old 03-27-2012, 08:16 PM
SoSlo07 SoSlo07 is offline
FNG
Im just south of you down 31. what are you lookin to do with the Tech 2? I might have a scanner that will work for what you need. and there is a dyno day comming up ill have to find out the date and location but isn't gona be far away ill get back to you on that.
Old 04-19-2012, 09:47 AM
Blaine's Avatar
FNG
I need my taps reset on my trans. Let me know if you could figure something out. Thanks!
04 LLY
Old 08-23-2012, 06:08 PM
Blaine's Avatar
FNG
Bump, does anyone around here have a tech 2?
04 LLY
Old 08-23-2012, 06:27 PM
THEFERMANATOR's Avatar
LEGALLY INSANE
I'm about an hour and a half away. I don't have a TECH2, but I do have EFILIVE which can reset the TAPS(I just can't do a fast learn on it). Why do you need the TAPS reset?
Old 08-23-2012, 06:41 PM
Houser04lly's Avatar
Houser04lly Houser04lly is offline
I live in Cape Coral and Have a V2 im sure someone can walk us through resetting the taps as I have never done this. Im sure we could work something out if you are in need.
04.5 LLY EFI ARP Studs Grade Cs Airdog 150 Race Valve EGR Gone RareParts Tie Rods Braces Solid Centerlink Caltracs Double Adjustable QA1s with Coilovers Front T Bars gone Single QA1s Rear PPE Stage 5 Trans BT Lockup Controller
Best 1/8 so Far 8.17 1.81 60 @ 83 mph
Old 08-24-2012, 08:34 PM
Blaine's Avatar
FNG
I have a V2. The main reason I want help with a V2 now is i'm trying to diagnose an injector issue. My balance rates are good but I know I have a bad injector and I don't know which one cuz the DVT controls on the LLY aren't in order..........
04 LLY
Old 08-29-2012, 04:26 PM
Blaine's Avatar
FNG
Anybody have access to a Tech 2?
04 LLY
  #9
Old 09-16-2015, 02:17 PM
sschevyfreak's Avatar
sschevyfreak sschevyfreak is offline
FNG
Sorry to barge in I live on pine island .what is a tec 2?
I need someone to set my transmission for my 40s and 456 gears . ABS all screwed up .
