  #1
Old 03-05-2018, 10:28 PM
turbovan turbovan is offline
Too many toys!!!
Cool Help me spend my money for better power towing!!
My truck just doesn't seem to have the get up and go I thought it would towing-first year owner of it. My brothers bone stock 09 will kill it towing the same weight or a lot more. Towing a 26 ft Prowler Toy Hauler, aprox 9-10K loaded, towing very hilly terrain, averaging 7 mpg.
Truck has 400K, previous history unknown but well maintained, starts so fast I barely have time to release the key. Fresh filters, transmission shifts fine-fluid nice and red, balance rates fairly equal, no smoke or hazing at idle.
Mods so far are 3" exhaust, Banks big head wastegate-22 psi then I gave up adjusting it, lol, custom 30hp tune by a local tuner, 3.5" turbo inlet.
Mods to do, have the parts-BD drivers manifold, 3" DP, EGT gauge-I know should have it done first. and a lift pump.
I want to turn it up another 50hp but have been advised not to so I don't kill my trans. Read about manifold and up pipes-read that huge thread on it, lol, y-bridge? Would like to port the turbo but too lazy, also want to get the tapshifter.
Any other suggestions? Buying a new truck is not happening. TIA.
Edit, have about $1200 to spend.
__________________
2002 4x4 Crew cab brown/gold 2500HD. Leveled with 275/75R17 10 ply KO2's, 3" exhaust, 3.5" turbo inlet, custom 30 hp tune. Pulling an old 26ft 1998 Prowler Toy Hauler. More mods to come!
  #2
Old 03-06-2018, 06:31 AM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
Default Help me spend my money for better power towing!!
Save up your money build the trans and get a bigger tune.
Iím not sure why you think your truck should keep up with a LMM as is. The trans is the weak point. A tune will give you more power then a lmm, but your trans wonít hold it for long.
__________________
06 GMC 2500 CCSB SLT LBZ 4X4
These views expressed on this post are not my own, but rather randomly generated computer gibberish, and in no way should be used to judge the author's IQ or mental health.
  #3
Dozerboy's Avatar
Oops
__________________
  #4
Old 03-06-2018, 07:04 AM
RickDLance's Avatar
RickDLance RickDLance is offline
Default
I would run a compression check on it first. Let's make sure the motor isn't getting weak.
Also if you already have the BD manifold then just do the TowFlow up pipes. That should get you about 20 more HP. Might as well throw a down pipe on too.
Remember too that your brothers 09 is higher rated in HP and in torque.
__________________
www.ProFabPerformance.com
Sale!! Use code dd10 for 10% off!!
We also handle S & B filters, Air Dog lift pumps, American Eagle wheels, and Kraftwerks Superchargers.
On my 20th Duramax & still Loving them!
  #5
Old 03-06-2018, 08:51 AM
Chevy1925's Avatar
Chevy1925 Chevy1925 is offline
Default
all this stuff you are doing is great for more power but it does you no good when the trans starts to slip and die and you still get beat.
make sure engine is healthy like Rick says and then put a trans in it.
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #6
Old 03-06-2018, 09:19 AM
zakkb787's Avatar
zakkb787 zakkb787 is online now
<thatís not me...
Default
X3 or 4. However many people said it before. Trans first.
__________________
Without a duramax... hopefully not for long.
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s. And itís currently broke
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
  #7
Old 03-06-2018, 09:27 AM
PACougar's Avatar
PACougar PACougar is offline
Default
I would buy 4 Fingers Pistons, never too early to start.
__________________
2004 LB7 EC/LB 2WD Dropped 6" in the front on coil overs and 7" in the rear on 18"s, Hellwig front and rear sway bars. Caltracs traction bars.
Socal Diesel built bottom end, FI S480 Billet wheel and race cover, RDL Headers and pipes,
Dual Cp3(1 modded and 1 stock), Exergy 100% over injectors,
Socal Diesel injector clamps, Socal Stage 2 Heads/ARP Head Studs
Suncoast GMAX-5 plus some billet built by my best friend Dave(He's a Badass like that), 1058 converter, MikeL Cooler
Mag-Hytec pans on Tranny(Scraping a little) and Diff
Custom modified MBRP exhaust i.e. it dumps in front of the rear tire(Also by Dave). Never had a cat
Labonte Motorsports water/meth, AirDog II 200
Custom 5" Intake Pipe w/AFE Filter, BD Cool It Intercooler,
EFI Live DSP5
Torsen limited slip(POSI), Gauges
DON'T PURCHASE FROM INDUSTRIAL INJECTION UNLESS YOU ENJOY GETTING SCREWED!
  #8
Old 03-06-2018, 09:28 AM
Pure Diesel's Avatar
Pure Diesel Pure Diesel is offline
Randsburg Drifter
Default
As everyone else has said, build the tranny. You only have $1,200.00 and that's not enough. Expect about $3k-$3600. If your only making 22lbs of boost that really needs to be fixed. Max an LB7 should be set for is 30lbs. When I had the LB7 in the truck it really woke up when I got that adjusted to 30lbs.
__________________
White GMC 2003 2500HD D/A SLE/CC/SB 4x4] Bilstein 5100~Air bags~Autometer Gauges~33 BFG's~MBRP 4" Exhaust~SD tie rod sleeves~Cognito Braces~PPE high flow pick up~Fass 95 pump~Titan 52-gal.~Prodigy~New tranny 02/12/2015 Mike L. "Baby Frankenstein " w/Goerend converter w/ Mike L. tranny cooler and pump rub fix~6 speed tap shifter~Siege Engineering Anvil train horns(Very Loud)
New injectors as of 03/12/2010 @ 80k miles
Injectors started going again at 115k. 07/01/2013
06LBZ engine transplant from Russ @ RPM Motorsports~No more Lb7 injectors to replace
  #9
Old 03-06-2018, 09:43 AM
Too many toys!!!
Default
Thanks guys, great advice.
Trans is in the works, I have a 6 speed core I am going to rebuild over the summer.
Rick, do your up pipes fit the stock manifolds? If so, I'll do those when I do the BD manifold and dp.
I'll turn the boost up too,
__________________
  #10
Old 03-06-2018, 09:44 AM
Too many toys!!!
Default
Quote:
LOL, what's that???
__________________
  #11
Old 03-06-2018, 09:58 AM
zakkb787's Avatar
<thatís not me...
Default
Uh, not sure if you can use the 6 speed core without quite a few mods? Maybe mike will chime in
__________________
Other toys:
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
  #12
Old 03-06-2018, 10:01 AM
Too many toys!!!
Default
Quote:
I have to use the 5 speed v/b, shift shaft and wiring from what I've read.
__________________
  #13
Old 03-06-2018, 10:28 AM
Chevy1925's Avatar
Default
yeah its pretty easy to change it to work in a 5 speed truck.
__________________
James
  #14
Old 03-06-2018, 10:31 AM
zakkb787's Avatar
<thatís not me...
Default
Quote:
__________________
Other toys:
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
  #15
Old 03-06-2018, 11:35 AM
RickDLance's Avatar
Default
The TowFlow's fit the OEM style manifolds.
__________________
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
