  #16
Old 02-07-2009, 05:40 PM
Alligator Alligator is offline
Default
Quote:
Originally Posted by MMLMM View Post
Why not
__________________
2006 CC/SB 4x4 LBZ Built - 900hp tow rig
2006 SC/LB LBZ Built - Caged
2002 SC/LB LB7 - 500hp parts getter
Team Borrowed Time #15
  #17
Old 02-07-2009, 09:10 PM
bullfrogjohnson's Avatar
bullfrogjohnson bullfrogjohnson is offline
Big Girl!
Default
This is the same for LB7's also?
__________________
Travis
03 CCSB lb7
06 2500hd ECLB 6.0 gasser
2010 Straight Diesel 2.8 Points Champion
special thanks:
B&B Pulling and Greene's Diesel Performance, Fully Spooled Motorsports, Johnboy, Simon, Ed, ProFab Performance, Hamilton Cams, Extreme Prejudice Racing, Ridge Runner Diesel
  #18
Old 02-08-2009, 09:41 AM
McRat's Avatar
McRat McRat is offline
Diesel Hotrodder
Default
Quote:
I dunno. I haven't done an LB7 yet, but from seeing an LB7 nozzle, I'm guessing it's the same design with different P/N's.
__________________
2005 GMC 2500HD LLY "Casper"- LLY O/S 8758. 10.59 @ 129. EFILive "2CP3" Tuning, Mike L Suncoast Trans. PPE Dual CP3's, GT4202R.
2004.5 GMC 3500 SRW LLY "Big Blue" - LLY O/S 1668. 13.12@103. Powered by PPE/VA with Mike L Suncoast Trans.
2006 GMC 2500HD CC/SB LBZ "Wendy"- LBZ O/S 6128. 12.50 @ 107.x. EFILive tuning, Mike L trans.
Pat and Kat McSwain
"Casper" - Record Holder, Bonneville & El Mirage. Best Clocked Speed 197mph, Bonneville '09.
"World's Fastest Production Diesel Pickup - 174.586mph"
  #19
Old 02-08-2009, 11:59 AM
Big Girl!
Default
Quote:
I will be doing this tomm and will report back
__________________
Travis
03 CCSB lb7
special thanks:
  #20
Old 02-08-2009, 12:55 PM
sweetdiesel's Avatar
sweetdiesel sweetdiesel is offline
That's better
Default
With pics ofcourse
__________________
2017 2.5L D-Max Trail Blazer
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
Abby 01 RC/LB 10.28@144mph
SOLD
  #21
Old 07-23-2009, 09:50 PM
That's better
Default
Well Travis? I pulled the inj tonight and need to swap the tip to the new injector. Got any advice??
__________________
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
SOLD
  #22
Old 07-24-2009, 01:15 PM
02bigstrokin's Avatar
02bigstrokin 02bigstrokin is offline
Default
he went to take them apart and got scared! j/k. we will be doing the same in about a month.
__________________
Iím Kenny Powers! And I am very upset with how I am acting right now. I just have a very hard time expressing my emotions, and I canít stop from yelling.
  #23
Old 07-25-2009, 11:40 AM
That's better
Default
Quote:
Very easy to do 50ft/lbs is the correct spec also
__________________
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
SOLD
  #24
Old 11-21-2009, 12:11 PM
JD4440's Avatar
JD4440 JD4440 is offline
<< Lo-Carb Monster
Default
Quote:
Originally Posted by Alligator View Post
What ever you do, do not lose that shim... All in all, swapping tips is a easy job, 5 out of 10 job for skill level. Make sure you have a super clean work area, a good can of carb cleaner to clean out the tip nut and do not have any distractions while you are exchanging them. We also torque to 50 ft/lbs.
Well, leave it to me I lost a shim and am still looking for it-yea right. What options do I have? Can the shim be obtained from Bosch?? If so does anyone happen to have the p/n for an LBZ? I should have known this would happen to me
__________________
Chris
EFILive(Tuned by JoshH),SC IV,PPE,TTS,Big Dipper,Ect.
O.S. 6128--508hp/12.26@107.4 so far.......Thanks Josh
Quote:
Originally Posted by Trentnell :
Politicians are the only people in the world who create problems and then campaign against them.
  #25
Old 11-21-2009, 03:30 PM
custom8726's Avatar
custom8726 custom8726 is offline
Default
Quote:
I do not believe you can buy the shim seperatly, I think you will have to find and used injector to buy unless some one here has an extra they can hook you up with???
  #26
Old 11-21-2009, 07:07 PM
JD4440's Avatar
<< Lo-Carb Monster
Default
Well, I guess all my prayers were heard. We found the shim under the bench after about 2 hours of crawling on the ground. I ran out of good o rings though, and they can't be found either. Guess I'm down till mon at least.
__________________
Chris
  #27
Old 11-21-2009, 10:24 PM
bml2200 bml2200 is offline
Default
I thought I lost the shim so I called Brayden Fleece and said he had them in stock and could get me a new one. It turned out though that it was in one of the other holes in the injector so if you think you lost a shim try holding a magnet over the injector in question, you might find it.
__________________
2007 GMC 2500HD CC/SB SLE 4x4 LBZ- 68mm Cheetah w/ HX40 DP, Profab y-bridge, headers & up pipes, Big Dipper trans w/ 1058, Duramaxtuner, Cognito 4" NTBD w/ Deavers, FASS 150
2002 GMC 1500 ECSB SLT 2wd - DD
Sold: 2007 Chevy 2500HD CC/SB LTZ Z71 LMM Built
Sold: 2008 GMC 2500HD CC/SB SLT Z71 LMM Stockish
RIP: 2006 GMC 2500HD CC/SB SLT 4x4 LBZ Mild Build
  #28
Old 11-21-2009, 11:27 PM
Burn Down's Avatar
Burn Down Burn Down is offline
Default
I know this is a tip swap thread, but thought i would mention injector bore cleanliness. I had my injectors replaced under warranty by the dealer. 1 year & about 4,000 miles later (service truck got a ton of miles) I decided to do tips.
All the tips pulled out easily by hand except for one. Borrowed a gm injector puller, broke it. Ended up having to put the fuel line back on and pry the injector back and forth in the bore holding up pressure on it with another pry bar. Took me 4 hours to get it out. The body was completely caked with carbon & soot. Took a look at the copper sealing ring and it had a large black dent in it, there had been a piece of carbon stuck under it from the previous replacement.
Cleaned the bore with gm bore brush but couldn't get the bottom of the bore clean (carbon). I used a new wire brush (bottom needs to be square) and a small piece of red scotch brite. This was mounted on a drill. USING EXTREME CAUTION remeber the heads are soft aluminum I lightly touched the scotch brite to bottom of the bore, only touch it enough times to remove the carbon.
Just a word of caution is all, stuck injectors can be a b__tch.
  #29
Old 11-24-2009, 08:30 PM
Brayden's Avatar
Brayden Brayden is offline
Default
If UPS ships on Friday I could overnight you some tomorrow and you'd receive them Friday.. Call the shop if you need them.
Got new tip seals?
  #30
Old 11-24-2009, 09:19 PM
McRat's Avatar
Diesel Hotrodder
Default
I picked up a o-ring assortment at Harbor Freight. I found a size that was REALLY tight on the body and they work fine, and the whole assortment cost less that 2 pieces at GM.
I reuse the coppers by taking a piece of 600 sandpaper, and polishing them on a flat surface with my index finger. Use a circular motion. You will see when they get flat, as the dark ring will vanish.
__________________
Pat and Kat McSwain
Closed Thread
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
vB.Sponsors
