  #16
Old 09-01-2017, 07:39 AM
Frogman1's Avatar
Frogman1 Frogman1 is offline
FROGMAN1
So pin holes are a real thing! Was your engine bored over and was it a daily driver or high performance? Did they have to sleeve it or just fix the spots? Thanks.
  #17
Old 09-01-2017, 08:50 AM
04jimc's Avatar
04jimc 04jimc is offline
Oughta Know Better
Stock bore, stock engine in a 4500. Sleeved both
Isaac Griffith
03 Chev CC SB ZF6-Gone
04 GMC CC SB SLT LLY
597/1096 Batmostocker-Gone
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #18
Old 09-07-2017, 07:12 AM
04jimc's Avatar
Oughta Know Better
Sleeved cyl
Isaac Griffith
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #19
Old 09-07-2017, 08:35 AM
Chevy1925's Avatar
if you are going a max of 800hp, there is no need for main studs but if you want to run them, line hone/bore the mains. it would be a good idea to have it done anyhow to open up oil clearance a smidge and make sure you have 0 issues with out-of-round and taper from the bores. if the machine shop knows what they are doing, they will know there is no over sized bearings for the engine and to be very careful not to take too much out.
personally, i would run fingers pistons as well. the extra cost is worth the piece of mind. if you are not willing to switch, make sure you run a turbo setup that will get you to the 800hp mark with a fueling pulse width that is not very high. this will help the pistons live longer. that 4088 wont be enough, you will need a twin on top of it or something else all together.
i would have the block/crank fluxed and checked over but if it was not burning coolant before or gave signs of it, i wouldnt worry about having it pressure checked. they heads should be pressure checked and gone over well though.
make sure you have the 42160 ring set for the pistons, the 41909 do not use the correct metals to be used in a truck looking for longevity out of them.
Run Clevite H bearings, they will be plenty for you. you can get away with stock or P bearings for the cam if the cam is stock or mild. be sure to key the cam and crank shafts.
who will be assembling it?
James
best time to date: 12.39
Tailgate Crew Member #4
  #20
Old 09-07-2017, 09:49 AM
Awenta's Avatar
Awenta Awenta is offline
Sleeved cyl
What did they change for that
Arek
2003 CCSB LT LB7 deleted
EFI by Kory
  #21
Old 09-07-2017, 09:53 AM
04jimc's Avatar
Oughta Know Better
$130 for the 2 sleeves and $300 for the specific machine work and then an additional $200 to torque plate finish hone all 8
Isaac Griffith
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #22
Old 09-07-2017, 10:24 AM
Chevy1925's Avatar
whats piston to wall clearance now? ive always been concerned with pressing old sleeves out, pressing new ones in and not distorting the cyl next to it to teh point even with a hone, PTW clearance becomes too large. if it needs a sleeve, i usually have the block bored over so everything comes out nice.
James
  #23
Old 09-07-2017, 10:58 AM
04jimc's Avatar
Oughta Know Better
.0048
Isaac Griffith
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #24
Old 09-07-2017, 12:02 PM
Chevy1925's Avatar
I see
James
  #25
Old 09-07-2017, 01:20 PM
FROGMAN524's Avatar
FROGMAN524 FROGMAN524 is offline
Are there downsides to fingers pistons besides sound and fuel economy or are those both myths as well? Hasn't Mark Broviak pushed them past 1,500HP or something like that?
2016 Sierra 3500HD Denali CCSB
MotorOps on Spade Tuner/AirDog 165 II-4G/S&B CAI/FloPro 5" SS Turbo Back W/Muffler/30" FTE Resonator/MBRP 6" SS Tip/CTS2 Insight/EDGE EGT Probe/GMC-Kicker Soundgate Sub
SOLD2015.5 GMC Sierra 3500HD Denali CCSB
SOLD2007.5 GMC Sierra 2500HD SLT CCSB Graystone/Ebony
Z71 4x4 DuraAlli EFILive by ATP Air Dog II 165 G2 Diff Cover Alli Deep Pan TranSynd Cognito Boxed UCAs
Kryptonite Tie Rods Cognito PISK Bilstein 5100s Bilstein Stabilizer PPE Race Valve/Ported fitting MBRP 5" DP Back RBP 6x18" Tip AutoMeter Cobalt Boost & Pyro Advent OGM-1 Nav Method 16x8 Machined BFG KO2 286/75R16 Mike L Suncoast/Goerend
SDP Twins PPE Race Up-Pipes/Manifolds
If wishes were horses, beggars would ride.
  #26
Old 09-07-2017, 01:44 PM
04jimc's Avatar
Oughta Know Better
We're going on 2 seasons on our forgd fingers. We run at either 1250 or 1510, depending on which org we pull with.
Isaac Griffith
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #27
Old 09-07-2017, 02:46 PM
FROGMAN524's Avatar
Cast for daily driving correct Forged for dedicated race or pulling truck?
  #28
Old 09-07-2017, 02:50 PM
04jimc's Avatar
Oughta Know Better
Yes. Although both could do either. Cast will hold up very well in most applications
Isaac Griffith
06 GMC CC DRW-Gone
08 GMC CC DRW-Gone
'Oughta K
  #29
Old 09-07-2017, 03:29 PM
M.A.M.'s Avatar
M.A.M. M.A.M. is offline
There is a slight difference in sound, not much... you will notice a drop in fuel economy..... I don't know if you'll notice it as much if your trucks a DD, I've only ever pulled trailer with mine...
  #30
Old 09-09-2017, 05:42 PM
WolfLLY's Avatar
WolfLLY WolfLLY is offline
Making Chips
They also smoke more.... good tuning does take care of most of it though. I'm happy I went with cast ovals.
LMM CCSB LTZ Z71. SoCal motor, s485/68r, 1078 Limitless converter, S&S 200s.
LB7 ECSB 4X4
Thanks to Evan@Limitless, Mark@Danville Performance, Josh Harris@Top Notch, and Corbin(crussel)
