  #46
Old 11-02-2017, 01:52 PM
tsd_billy tsd_billy is offline
Default
Your not wrong for asking it here. Just dont ask facebook :lmao:
__________________
Vgt swapped lb7, street block built by bobby at Mikes performance engine
  #47
Old 11-02-2017, 01:58 PM
MarkBroviak's Avatar
MarkBroviak MarkBroviak is offline
DMax Junkie
Default
Quote:
Originally Posted by Yngdmax92 View Post
So the difference in price between a stg2 r 3794 68mm wheel vs the stg2r 68 that comes with vanes and standard 68 is very minimal. So in a case if someone had Interest in the choice of them two turbos, has a goal of 600hp-700hp, horsepower goal before I crack a piston and in the future for after lol. I don't want to have to upgrade, but I still want to be able to tow, but want a top end pull as well. (Don't want twins) love a strong turbo brake
What would be the best choice. Lol I know this seems ridiculous because it's probably coming off like I want it all, I'm trying to understand better on my future purchases.
Like others said, seriously enjoying this help and info
In that power goal range and what your doing with it the 68mmStg2Reman http://www.danvilleperformance.com/d...mm-stg2-reman/ or the 3794 68mm upgrade http://www.danvilleperformance.com/d...e-2-new-turbo/ if you wanted it to be a brand new cart.
__________________
06 LBZ "White Lightning" 2wd rclb DP built motor Carillo, 15.25:1 "Finger" Oval Pistons w/reliefs, Socal Titanium upgraded springs on Stock heads w/Socal Billet injector holddowns,ARP, head-main-rocker studs,Soca Billet mains& Dampner, Chromoly pushrds, DP B72mmstg2R1VGT/StainlessDiesel S472/87 1.0SS triples, DHD Cast SuperHighflow intake, Exergy 14mmCP3 & 250%inj,Fass, PPE Race Valve PPE Manifolds, Banks Technicooler, AFE Boost tube, SC GMax6 Goerend "G" Grizzly Locker 3.42 gears, 1198+++hp 2k+ftlbs
Current fastest pass 1.520 60ft 6.705@108.95mph 1/8th 10.242@140.11mph
Current Standing 1/2Mile record holder for Diesel Pickup @ 159.8mph
Made it on fastest DMax list with Single VGT and single cp3 fuel only! 1.589 60ft 6.9291@103mph 1/8th 10.96@127.76mph
Stock motor best 11.277@119mph B68mmStg2R 250%inj 12mmcp3
Wife's tow rig-08 LMM SierraHD SLT2 "Stormy" CCSB murdered out TCTStg2 Exergy 12mmcp3 1/8th 9.11@77.51 1/4-14.174@96.8mph
06 GP GXP 5.3L StealthGray Metallic
http://www.youtube.com/markbroviakdp
http://www.youtube.com/channel/UCV6K...?feature=watch
Mark@DanvillePerformance.com
  #48
Old 11-02-2017, 05:29 PM
Yngdmax92's Avatar
Yngdmax92 Yngdmax92 is offline
Default
Wow, totally different then what I was even looking at, cheaper too! Haha thanks Mark, way better understanding now.... Again thank you!
__________________
2003 2500 hd cc/sb (leftovers) MPS 63.5 ihi, built trans, airdog 150, 30 overs..... Sold
New and improved! 2007 classis lbz LS ec/sb
Egr delete, pcv re-route, PIPED, airdog 4g 165,
Danville performance tunes.
  #49
Old 11-02-2017, 05:33 PM
Yngdmax92's Avatar
Default
Quote:
Ahhh Facebook... Such garbage I tell you. Majority of the diesel "gods" on Facebook need it to keep their buisness going, because I have found out that there work doesn't speak loud enough.... But being a Facebook warrior will back them up.
__________________
  #50
Old 11-04-2017, 06:34 PM
Robby Avery's Avatar
Robby Avery Robby Avery is offline
GM TECH @ FENDER GMC
Default
Not to high jack but Mark, what would a 72mm tct wheel flow vs a 72mm batmowheel flow in a vgt? Say modded stock vgt charger, 3794 vgt, 4094 vgt, for comparison? Just looking for flow rate and spool times information mainly. Thanks
__________________
2006 Chevy 2500HD LBZ Duramax Summit White CCSB Tan (neutral) leather LT3 pkg w/sunroof OEM bra 4x4, ISSPRO EV, ATS Twin CP3's, Built Allison, Eaton E-locker front stock G80 rear, Kennedy Twin pump filter combo kit, Snow Perf Stage 2 w/m injection, 4in to 5in banks tip, HM Big K&N, Mickey Thompson Baja Claw TTC 315/75/16 on stock rims, Rancho RS9000XL, Fabtech HD TR, Cognito P&I Brace kit, DD/Puller/Work Truck
2002 Chevy 2500HD LB7 Duramax Summit White CCSB Grey (neutral) leather LT3 pkg OEM bra 4x4, Kennedy Twin Pump Filter Combo Kit, ISSPRO EV, PPE Boost Valve, DTS Built Allison, MikeL Cooler, ATS Billet Flexplate, DTS 3in DS IC pipe, Bill's 5in CAI (White), Big K&N, 4in to 7in black stack, Mickey Thompson Baja Claw TTC 315/75/16 on stock rims, Cognito P&I Brace kit, Sleeves, Energy Sway bar Kit, DD/Puller/Work truck
Special Thanks: (David) DTS, (Guy) Socal Diesel, (Nick & crew) DuramaxTuner, (Dan) PPE, (John) Kennedy Diesel, (Tony) All Season
  #51
Old 11-04-2017, 09:15 PM
DMax Junkie
Default
Quote:
Well, since Bullseye Manufactures my Billet 72mm vgt wheels they can't and won't produce a BMW or TCT version of it and same goes for the 68mm Billet wheel I have. The 72mm is for the guys looking for 1000++hp in compounds or triple setups. I do NOT recommend them for stock motor guys or to run as a single because it is designed to be force fed. All the fastest VGT powered trucks ran my 72mm VGT in their twin and triple setups. Hope this helps.
__________________
  #52
Old 11-05-2017, 07:16 AM
onebaddmaxxx onebaddmaxxx is offline
Default
OP
You cant really go wrong with a 3794 or marks 68stg2r. My shop has the fastest 3794 turbo record with only a 65mm bmw. It drives 100% like stock, spools faster than stock, and will shred tires at 50mph with no issues. the 68stg2r is fun also, but more important to have a proper converter that wont blow through with how fast the power comes in.
If your more or less looking for a nice drop in upgrade, id go 3794
__________________
2005 lly
Lots of thanks to Diesels Unlimited, Evan@limitless & Mark@danville
  #53
Old 11-14-2017, 07:57 PM
Woodster's Avatar
Woodster Woodster is offline
Computer Nerd
Default
Hey Mark, where does your new 68/71 vgt fall in comparison to the 3794 and the 68stg2r?
__________________
2006 LBZ S.B.C.C. LT 4X4
EFI LIVE Thanks Mark
Danville BMW GT3794 Stg. 2 Thanks Mark
PPE Uppipes/Manifolds Thanks Rob
5" TB Magnaflow
FASS Titanium Thanks Henry
GMAX w/ ML converter Thanks Trent
  #54
Old 11-15-2017, 06:44 AM
DMax Junkie
Default
Quote:
It's a touch bigger than the 68stg2R so the spool up depending on fuel will be a touch slower but it is capable of around 40hp more on top end than the stg2R making it a an 820hp capable turbo with the correct fueling and parts combination.
__________________
  #55
Old 11-15-2017, 07:23 AM
Nickracer9 Nickracer9 is offline
Gearhead
Default
Is it still a 68mm but with a bigger turbine?
  #56
Old 11-15-2017, 11:18 AM
Yngdmax92's Avatar
Default
Quote:
Yes it is, the turbine is 71 which is larger then the 4094 stg2 r but it's also equipped with the lbz vane configuration. Made to be more of the big single of vgts, because like what mark said. The 72 was designed more for twin applications or triples.
__________________
  #57
Old 11-15-2017, 07:49 PM
Josh154's Avatar
Josh154 Josh154 is offline
Default
Quote:
Interesting. What size is the turbine on a stock lly charger?
__________________
08 CCSB LMM - HSP 369sxe kit, 10mm S&S cp3, built trans with suncoast 1058, supporting mods and Danville tuned
Best 1/4 mile
12.86 - 104.92mph
  #58
Old 11-16-2017, 06:59 AM
DMax Junkie
Default
It is just barely a 66mm turbine on the exducer. 4094 is a 68mm turbine.
__________________
  #59
Old 11-16-2017, 07:04 AM
Josh154's Avatar
Default
That 68/71 sounds like it would be fun one to try. I liked my tct 63.5 but it had no where near the top end this 369sxe has. Although I’m sure had I switched to your tuning on the vgt I would have liked it more.
__________________
Best 1/4 mile
12.86 - 104.92mph
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
