  #5581
Old 11-07-2017, 02:35 PM
Chevy1925's Avatar
Chevy1925 Chevy1925 is offline
Default
Trans died today. kinda out of the blue and by no means a simple fix.... gunna have to actually tow it out to mikes.
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #5582
Old 11-07-2017, 02:52 PM
IOWA LLY's Avatar
IOWA LLY IOWA LLY is offline
Yes, its really me
Default
Any idea what's wrong?
__________________
2003 GMC CCSB LLY
Built by me, tuned by me.
2009 ECI Diesel Truck Points Champion
2010 ECI Diesel Truck Points Champion
2011 ECI Diesel Truck Points Champion
2012 ECI Diesel Truck Points Champion
Big thanks to everyone who helps me.
Best 1/8th, 7.29, 98.6MPH (Street tires, fuel only, single Journal bearing GT42 charger) (2010)
Best 1/8th, 6.93, 104.24MPH (Street tires, fuel only, single HX60 turbo) (2016)
Best 1/8th, 6.60, 106.6MPH (Street tires, fuel only, single HX60 turbo) (2017)
  #5583
Old 11-07-2017, 03:06 PM
Chevy1925's Avatar
Default
nope but i have a feeling the sump filter is packed now. just before my big trip over labor day, i did a full check up on the truck (fluid levels and smells, oil change, lube, check over suspension and steering) and the fluid looked great and she shifted great. parked it till oct 21st with some drives to work here and there, no issues on a day trip to the dunes and back (400 miles). parked till today and horrible tie ups when up shifting or down shifting, converter stayed locked even at a stop (almost killed teh engine then unlocked), limped about a mile from work, reverse clunks and shutters, first gear shutters and nuetral trys to move the truck, pump whines bad and there are some not so good noises going on. P0776 and P0742 when it limped. checked fluid level at work and it was 1/2" below the hot cross hatches but burnt to hell. If i get time, i may drop the pan but im not planning on it. its not good either way
__________________
James
  #5584
Old 11-07-2017, 03:25 PM
IOWA LLY's Avatar
Yes, its really me
Default
Oh wow. Yeah definitely no need to try and diagnose. Time for a tear down unfortunately. Sorry to hear that man.
__________________
2003 GMC CCSB LLY
  #5585
Old 11-07-2017, 03:26 PM
SoCalMike's Avatar
SoCalMike SoCalMike is offline
Default
Quote:
That sucks man. Wonder what happened? Could you pull the trans and take it to him? Do you have a means to flush the coolers at home if you did that?
__________________
  #5586
Old 11-07-2017, 03:35 PM
Chevy1925's Avatar
Default
i was pissed at first but ya know, im hard on the old girl. i have to expect these things.
Quote:
na ill just take the whole thing out there. i dont have the time to R&R it. i could take it to my buddies shop here that has the machine but just more time i dont have. Get it done at mikes, swap the tow rig i use to get it out there for mine on the way back and get the tcm learned for my Thanks Giving trip .
this is assuming the truck can be fixed that day
__________________
James
  #5587
Old 11-07-2017, 03:39 PM
IOWA LLY's Avatar
Yes, its really me
Default
It kinda sounds like converter failure. I'll bet it failed first and the debris it sent everywhere is wreaking havoc on everything.
__________________
2003 GMC CCSB LLY
  #5588
Old 11-07-2017, 03:49 PM
Mike L.'s Avatar
Mike L. Mike L. is offline
Default
Sounds like converter.
__________________
Shop 714 870 7300
Cell 310 918 9678
Tuned by Idaho Rob.
  #5589
Old 11-07-2017, 05:59 PM
Chevy1925's Avatar
Default
Well that explains that. See what else it killed soon enough!
__________________
James
  #5590
Old 11-14-2017, 07:04 PM
Chevy1925's Avatar
Default
Loaded up and ready to head out tomorrow after work. I really donít like this look....
__________________
James
  #5591
Old 11-14-2017, 07:51 PM
minerigger's Avatar
minerigger minerigger is offline
Default
I waxed mine 10 days ago. Bout all that's happened besides fuel it up and drive to and from work.
Sent from my SM-G930V using Tapatalk
__________________
Brock
06 LBZ ECLB
Gauges, Danville Tunes, 5" Dumped, Trans by Evan, DP Stg2r, Sleeved/Braced and some other odds and ends crap that we all have
  #5592
Old 11-14-2017, 08:36 PM
chevor's Avatar
chevor chevor is offline
Highway hauler.
Default
Pulling with my new white one, down route 66
__________________
2010 Gmc 2500 Duramax over 845,000 Odometer miles
50% towing miles,Counteract balancing beads,Rancho 9000 shocks,89 Gallon RDS in box tank, 1 ton rear leaf springs,Curt 20k Fifth Wheel,Curt 18K Rear Mount hitch,Firestone ride-rite air bags,NUC Motorsports Bypass oil Filtration,Edge Insight CTS,Fass 95HD
New 2013 LT CCSB bought with 508,000 miles
2013 LT CC & Chassis with 9' Hillsboro Aluminum flatbed - over 80,000 miles
chevor-2010-gmc-2500-maintenance-log
Dually Flatbed
Favorite book : The Richest Man in Babylon
  #5593
Old 11-14-2017, 08:58 PM
lutzjk913's Avatar
lutzjk913 lutzjk913 is offline
Default
Pulled the bed off of it
__________________
Joe
2008 CCLB LT2 DURAMAX LMM
13.44 @ 98.69
  #5594
Old 11-14-2017, 10:16 PM
Dvierra86's Avatar
Dvierra86 Dvierra86 is offline
Default
Blew it up again. Thatís all pcv blowby along the side of the truck.
2006 CCLB DRW 6"fabtech 35"s 4.11 w/arb sdp 475 over stock 30% ii nozzles fass150 built trans
  #5595
Old 11-15-2017, 04:11 AM
Yngdmax92's Avatar
Yngdmax92 Yngdmax92 is offline
Default
Who does your tuning??
__________________
2003 2500 hd cc/sb (leftovers) MPS 63.5 ihi, built trans, airdog 150, 30 overs..... Sold
New and improved! 2007 classis lbz LS ec/sb
Egr delete, pcv re-route, PIPED, airdog 4g 165,
Danville performance tunes.
Reply
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
vB.Sponsors
