  #61
Old 02-07-2018, 08:22 AM
dordtrecht5's Avatar
dordtrecht5 dordtrecht5 is offline
Regular Cabs Rock
Default
Quote:
Originally Posted by ikeG View Post
The distance between the centerlines of each cylinder bore. If it wasnt stock, you would also have to manufacture your own crankshaft, heads and rocker shafts etc for it to work. Stock bore spacing is required in all pulling classes.
If you look at big, big cubic inch gasoline stuff, like Sonny's, they change the bore spacing so the bore size can be humungous and still have material between the cylinders.
Sorry, maybe I worded it badly. I know the definition of "bored spacing."
I am asking what the spec is for the bore spacing on the block in the OP.
Sent from my Moto Z (2) using Tapatalk
__________________
'06 LBZ RC/LB 4x4
EFI by TDT
Super High Flow EGR delete kit and Centerlink support by AllSeason
GMAX6 & ML-G HD
BT DieselWorks Lock-up
12.59 @ 105
SOLD
02 CCSB LB7 EFI Big tie rods/PacBrake bags/DVD Pioneer head unit Rockford Fosgate speakers/110-120voltAC inverter/Mastercraft MTR
Thanks go out to 770JOHNNYW and blk smoke lb7
International Association of Bridge, Structural, Reinforcing and Ornamental Ironworkers Local 21 Omaha, NE
United Steel Workers Local 1343 South Milwaukee, WI
  #62
Old 02-07-2018, 09:36 AM
RPM Motorsports's Avatar
RPM Motorsports RPM Motorsports is offline
smokinum
Default
Factory bore spacing, so factory parts will be a direct bolt on.
__________________
(Russ)
17 CC/SB L5P 4x4 High Country
73 RC/NB LBZ Nova Grocery getter
  #63
Old 05-01-2018, 06:24 PM
ctodd36 ctodd36 is offline
Gearhead
Default
Where can a guy inquire about this?
__________________
04 ECSB 2.5 puller
15 CC Dually
  #64
Old 05-01-2018, 09:50 PM
smokinum
Default
Quote:
Going to be a while before we will even be close. There is so much involved, and I’m in no hurry to rush a block to be done. Still in the process of making molds, and will need to tool up the CNC once we have cores ready to machine. On a good note.., I got a call from Gale Banks today, he’s going to be sending us specs on including the L5P rear reluctor and sensor, so we can make one block work for any combination 01+ ����.
__________________
(Russ)
  #65
Old 05-02-2018, 02:59 AM
Gearhead
Default
Quote:
Originally Posted by RPM Motorsports View Post
Going to be a while before we will even be close. There is so much involved, and Im in no hurry to rush a block to be done. Still in the process of making molds, and will need to tool up the CNC once we have cores ready to machine. On a good note.., I got a call from Gale Banks today, hes going to be sending us specs on including the L5P rear reluctor and sensor, so we can make one block work for any combination 01+ ����.
Very nice! Ok I will keep in tune with this!
__________________
04 ECSB 2.5 puller
15 CC Dually
  #66
Old 05-02-2018, 04:42 AM
PureHybrid's Avatar
PureHybrid PureHybrid is offline
Isuzu Shakes IT
Default
You know you've made it big when Gale Banks calls you with good info
__________________
04 GMC ECSB LLY - Mix breed trans/SC1056 - Profab - PPE - Kennedy twin pumps/pickup - Danville tuning: 531/944
I can't complain, but sometimes I still do
Jesse
  #67
Old 05-02-2018, 04:53 AM
NC-smokinlmm's Avatar
NC-smokinlmm NC-smokinlmm is offline
<<<Future tuna killer
Default
So are you making l5p crank fit older blocks?
__________________
2010 GMC 1500 SCSB Denali Clone < lifted 22's/33's, Kooks, Magnaflow, 5.3, 6l80, TVS1900, lots of boost, Mayhem tuned, etc...
2015 Corvette Stingray Z 51 < Stock...
2016 LML CCSB Denali < Lifted 22's/35's, Fox 2.0 < I officially need help.
  #68
Old 05-02-2018, 09:01 AM
smokinum
Default
Quote:
No, talking about being able to use old style crank or new style crank in the blocks we are doing up.., not using an L5P crank in an old style block. Gale said I would have to add a sensor hole to the block, waiting to see the file of the rear of the L5P and will go from there.
__________________
(Russ)
  #69
Old 05-02-2018, 09:16 AM
smokinum
Default
Quote:
Nah, he’s a gear head just like all of us, very humble guy and always a wrath of great info. I hadn’t talked to him directly in a few years. We spent about 20min BS’ing about racing and a house he’s building up in the mountains by me. He just bought an L5P truck for himself, that’s awesome for the derringer advancement. I’ll be trying one out in my L5P at the track, comparing current time slips vs derringer, and reporting everything back to him. Would be awesome to see better than a 14.3 ET like Scortcher is capable of, we saw 14.9 stock.
__________________
(Russ)
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
