  #1
Old 10-15-2006, 12:28 PM
Kat's Avatar
Kat Kat is offline
Wicked Witch of the West
Default LLY P1093 Shim Mod Instructions:
First I'd like to thank Tim at Midwest, and &^%$, as well as *&&^%$, and #@$%^ too for all their help. Some of the helpers wish to remain anonymous as they are waiting for a bowl of soup.
I was going to do a deluxe tutorial, but time didn't allow it. This is the best I can do for today. Sorry.
You will need:
20x1.5 metric nut (20mm fine thread metric)
4mm washers (9.0-8.0 OD) that will make a stack that is .75mm thick
fuel line removal tool
18mm 6pt wrench or socket
Vise and some aluminum strips, or softjaw vise.
crescent wrench
First you need to remove your Pressure Relief Valve from the driver's side fuel rail in the rear. It is an 18mm hex head that was tightened by the hand of God. You may need an impact wrench to remove it, or worse case, remove the entire rail. You will have to remove the glow plug controller and a fuel line or two to give you enough room.
Once you have removed it, you will need to disassemble it. This is where the vise and 20mm nut come in:
You put the valve in a vice with the 18mm hex pointed up, and the 20mm nut threaded onto the body threads. If the vice has steel jaws, use a couple of brass or aluminum shims to grip it. You will grip it on the GRAY needle housing, not the gold spring housing.
Turn the 20mm nut clockwise and it will pull the valve apart.
Now you will put the shims into the bottom of the gold spring housing.
Replace the spring and put the housing/spring back on the needle valve housing.
The needle housing and spring housing are swaged together, so you will not be able to reassemble with your hands completely, for this you use the vise:
__________________
Blue Meanie 02 Z06 11.36 @ 120.67 448 rwhp/411 tq AFR H/C
Wendy 06 GMC LBZ CC/SB EFI "Rat Posion", Sun Coast trans, SC 1057 & Transgo JR by MikeL, true downpipe, Banks Ram-Air SD sleeves 12.50 @ 107.51
Big Blue04 GMC LLY 3500 SRW CC LB 4x4 DA Big Blue 13.12 @ 103.93 466RWHP/928TQ. PPE LLY extreme tune, VA Box, SC III by Inglewood Trans, 4" straight pipe, Super Diesel Tie Rod supports and Manifold, Trippin Pickup, Cognito Braces, FuzzyDice.
McRat's toy-2005 GMC "Casper 2" 2500HD 4wd Xcab SB Mike L. LLY 2 trans, McRat tuning 10.59 @ 128.9
  #2
Old 03-08-2008, 03:52 PM
LarryJewell's Avatar
LarryJewell LarryJewell is offline
Back with his honey :)
Default
sticky too
__________________
2004 LLY
Cheetah & MPI Twins
PPE Duel Fuelers
Member # 270
  #3
Old 12-09-2008, 09:20 AM
stacks04's Avatar
stacks04 stacks04 is offline
Default
i'd like to add one bit here. i learned this by having to do it twice. the valve has 5 pieces all total. the housing (gold piece) the spring, the gray valve(which contains 2 more pieces) a plate with 3 holes and the actual valve needle. when disassembling the grey piece be careful not to lose the needle. it is very tiny and if it falls out you will literally be looking for a needle in a hay stack. i wish i took pics to give you a visual. i would assume with out this needle the pressure will just bleed off as this is what seals the valve.
if some one has one laying around willing to take pics that would be great. dont ask why i know this info
__________________
2004 CHEVY CREW CAB
  #4
Old 12-09-2008, 09:38 AM
McRat's Avatar
McRat McRat is offline
Diesel Hotrodder
Default
I made that tutorial in just a few minutes while getting ready for a race. It would really be nice if someone who is doing another shim mod would do a more professional version.
__________________
2005 GMC 2500HD LLY "Casper"- LLY O/S 8758. 10.59 @ 129. EFILive "2CP3" Tuning, Mike L Suncoast Trans. PPE Dual CP3's, GT4202R.
2004.5 GMC 3500 SRW LLY "Big Blue" - LLY O/S 1668. 13.12@103. Powered by PPE/VA with Mike L Suncoast Trans.
2006 GMC 2500HD CC/SB LBZ "Wendy"- LBZ O/S 6128. 12.50 @ 107.x. EFILive tuning, Mike L trans.
Pat and Kat McSwain
"Casper" - Record Holder, Bonneville & El Mirage. Best Clocked Speed 197mph, Bonneville '09.
"World's Fastest Production Diesel Pickup - 174.586mph"
  #5
Old 12-09-2008, 09:41 AM
stacks04's Avatar
Default
i wish i had another to do it with. if anyone has a spare or a bad one send it to me and i will make a nice write up pics included.
__________________
2004 CHEVY CREW CAB
  #6
Old 12-09-2008, 03:02 PM
TYREBOYZ_DEMAXIN's Avatar
TYREBOYZ_DEMAXIN TYREBOYZ_DEMAXIN is offline
The Tire Frier
Default
if the truck doesn't start after sevaral attempts chances are you dropped the little pin..ask me no questions i will tell you no lies
i tried to find it but it was useless so in went a race valve
__________________
Project Truck
1995 Dodge Ram 2500 RC LB 12V/NV4500,lots of fuel w a 3.0 Turbo with Billet 2.6 Wheel
Sponsored Trucks
2004.5 Dodge Ram 3500 CR 5.9HO/NV5600,S300 2.6 SSR Tuned,Hopefully doing a Custom 06 ECM Swap
2007 Chevrolet Silverado 2500HD LBZ/Allison, 2.6 VVT EFILive Tuning
  #7
Old 04-08-2009, 04:14 PM
z79outlaw's Avatar
z79outlaw z79outlaw is offline
Default
Does it matter if the washers are galavinized or aluminum? Also are there any tolerances +/- on the .75 mm?
__________________
-Nick
Sold 08 GMC 4X4 CC/SB 6" Fabtech, BMF's
09.5 Last of the brand G8 GXP
98 Silverado 3500 Cummin On Strong- 12v cummins p-pumped nv4500
  #8
Old 04-08-2009, 07:12 PM
Kat's Avatar
Kat Kat is offline
Default
Quote:
Pat says they are usually steel and you want to end up with approx. .75
__________________
  #9
Old 04-08-2009, 07:24 PM
z79outlaw's Avatar
Default
well Im glad I asked then I thought the total height of the washer combined was to be around .75mm saved me from having to do it twice.
__________________
-Nick
  #10
Old 04-08-2009, 08:04 PM
Kat's Avatar
Kat Kat is offline
Default
Wait.... Let me double check with Pat... You might want a total of .75 not sure he was paying attention when i asked Now that I reread the directions.
__________________
  #11
Old 04-08-2009, 08:07 PM
TIM Z's Avatar
TIM Z TIM Z is offline
Screwed by 0087s
Default
Good info, im getting ready to install a shimmed FPRV that Dustin did for me.
Hope " The hand of God" didnt tighten mine!! LOL!!
__________________
2007 CCSB 4x4 Duramax LT3 LBZ
M A STG III Allison- S.C. T-Case brace/Pump rub Fix
Precision Industries M L Race Converter
EFI LIVE V2 DSP5 ACID Tune by DIESEL ADDICTION
Twin Lift Pumps/ Race Valve
6'' T.C. Strong kit/Cognito Braces/SD sleeves.
some other goodies.
2000 ECSB Z71 -6.0 LQ4 BLOWN -TVS 1900 10 psi - Comp 226*-224*/ Dyno Tuned By TJ @ Baker Engineering/SS LT Headers/ RPM LVL VI 4L70E Billet output/ Precision 2600 Vigilante Stall. Hauls Ass
  #12
Old 04-08-2009, 08:26 PM
Kat's Avatar
Kat Kat is offline
Default
Edited my post. He did misunderstand me. Yes, combined should be .75 thick. I would lean more to the plus side then the minus side.
__________________
  #13
Old 09-24-2009, 11:43 PM
LBZ's Avatar
LBZ LBZ is offline
Default
Quote:
It's actually dimpled in 3 places and when you disassemble it, it can expand the end where it is dimpled so what I did to hold it all together untill I got it back in is I re-dimpled the same three spots with a small punch before removing it from the vice-just to ensure I wouldn't be looking for pieces later!!
  #14
Old 03-03-2011, 01:04 PM
chrissheerman chrissheerman is offline
FNG
Default
please dont be cross with me guys for asking I bought my furst duramax like 3 weeks ago. until the 24k warrenty runs out i'm gonna stay stock but i'm just trying to understand the purpose of shimming this valve. this is on the fuel rail??? i'm also new to not have a pos hpop system running my motor
  #15
Old 03-03-2011, 02:44 PM
McRat's Avatar
Diesel Hotrodder
Default
When you turn up the HP on a LLY, it will often throw a P1093 engine code, and go into reduced power mode, limiting you to 2000rpm.
It's caused by the PRV popping off it's seat and draining the rail. This even happened on stock LLY, but rarely. It always happened after you passed 450rwhp.
For LBZ/LMM, I wouldn't worry much about it. Do it for insurance if racing, but otherwise most trucks won't have a problem at 500rwhp.
__________________
Pat and Kat McSwain
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Thread Thread Starter Forum Replies Last Post
Lly p1093 05Supersmoker Duramax Tuning, Logging, and Gauges 8 06-16-2010 02:59 PM
LLY DSP instructions? NemesisDP EFILive 1 12-26-2009 12:44 PM
Shim Mod, Race Valve/ Ported fitting TIM Z Duramax Hard Parts 5 01-18-2009 07:41 PM
vB.Sponsors
