  #106
Old 04-27-2012, 05:06 PM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
Default
Finely had to do mine they lasted 115k great write up. Funny I got everything buttoned up went to pull my truck out of the garage and I got a CEL and burned up a glow plug. Damn it luckily I had one on hand took me longer to get everything back out then to do the work.
My CV splines where stuck in there good. I was fighting to get the hub off and just about to go get the BFH and a wood block when she came lose.
__________________
06 GMC 2500 CCSB SLT LBZ 4X4
These views expressed on this post are not my own, but rather randomly generated computer gibberish, and in no way should be used to judge the author's IQ or mental health.
  #107
Old 05-22-2012, 07:28 AM
Warman Warman is offline
FNG
Default
Thank you for taking the time to assist everyone with the nice tutorial.
You make mention of the "captive" nature of the assembly. Both of my front wheels (120,000 miles) have about 1/4" of play in them. What is the likelihood that one is going to fly off the truck while I drive down the highway?
I know they need to be replaced but do I have a little bit of time?
  #108
Old 07-11-2012, 06:31 PM
gassux gassux is offline
Default
just finished up my 07, feels like i did 5 rounds with tyson. One tool i really needed and i forgot to pick up was the slide hammer. Aside from a couple of harbor freight tool casualties, swap didnt go too bad. Both rotors wouldnt come off the hub so i ended up taking them off with the hub. Put some cheapo carquest rotors on until i can order a new set of gm rotors and pads. This calcium chloride they put down in the winter is just lethal.
__________________
07 2500HD CC LBZ For Sale 92k 29,000neg
"Young man, I'm gonna twist off your head and spike it onto the floors of a nightmare you can't even imagine! I will dance with you inside the six-sided ring of fire, unless you move from this area, far and fast, NOW!"
Quote:
Originally Posted by RPM Motorsports View Post
That would suck getting nailed for dyed fuel ..., "But officer it's the Koolaid, call McRat!!"
  #109
Old 07-11-2012, 06:33 PM
Default
oh and i was quoted 575.00 for a set of rotors and pads from the stealership shoppin around online right now...
__________________
  #110
Old 07-11-2012, 08:53 PM
JD4440's Avatar
JD4440 JD4440 is offline
<< Lo-Carb Monster
Default
Just to clarify; Is ANY slack in the assembly acceptable ? My pass side has more slack than the drivers did when I replaced it and I didn't notice any difference in vibration or brake wear when I replaced it. I bought my first from DMAXstore and will this one too.
__________________
Chris
EFILive(Tuned by JoshH),SC IV,PPE,TTS,Big Dipper,Ect.
O.S. 6128--508hp/12.26@107.4 so far.......Thanks Josh
Quote:
Originally Posted by Trentnell :
Politicians are the only people in the world who create problems and then campaign against them.
  #111
Old 07-12-2012, 01:30 AM
Hot COCOAL Hot COCOAL is offline
May the farce be with you
Default
No not on my truck
no movement that feels like it originates from the center of the wheel is acceptable
I dont even like the tiny bit of play found in the steering box
Summit has timkin and 2 others
orilies/shucks or whatever has precision and one other
Both sources i got for under 170
perfect fit on both
The job can be done in 30 minutes, give or take, with a jack in your own garage, if you are good
The stealership quoted me 750 parts and labor for one side
  #112
Old 07-12-2012, 01:34 AM
Default
The directions in this thread are spot on, nice job btw
The tool layout in the begining was a professional touch
  #113
Old 07-12-2012, 05:53 PM
Default
My bearings had absolutely no play when I jacked the truck up and pulled on the top of the tire. The only indication I had was the unbearable howl at highway speeds.
__________________
  #114
Old 08-15-2012, 12:00 PM
Lennart's Avatar
Lennart Lennart is offline
Not from here !
Default
Last week I lost my drivers side cv axle and yesterday the wheel bearing went. I drove a few days without the cv axle since I assumed it would not be needed.....but now I am not so sure anymore.
More than likely the loose cv axle put some abnormal stress on the wheel bearing which
caused the damage.
I was planning to drive some time without the cv axles for some time before making up my mind on what to replace them with.
__________________
2005 GMC 2500HD REGULAR CAB SHORT BED
Mike L. SC IV with 1057 McRat converter
  #115
Old 08-17-2012, 08:19 PM
JD4440's Avatar
<< Lo-Carb Monster
Default
It's my understanding the OE bearings have to have the CV in place but the newer design does not.
__________________
Chris
  #116
Old 08-17-2012, 09:04 PM
McRat's Avatar
McRat McRat is offline
Diesel Hotrodder
Default
I've went about 200mph without the front axles.
The P/N for the 4x4 is the same as the 2wd AFAIK. Both have axle splines, but only one has axles.
__________________
2005 GMC 2500HD LLY "Casper"- LLY O/S 8758. 10.59 @ 129. EFILive "2CP3" Tuning, Mike L Suncoast Trans. PPE Dual CP3's, GT4202R.
2004.5 GMC 3500 SRW LLY "Big Blue" - LLY O/S 1668. 13.12@103. Powered by PPE/VA with Mike L Suncoast Trans.
2006 GMC 2500HD CC/SB LBZ "Wendy"- LBZ O/S 6128. 12.50 @ 107.x. EFILive tuning, Mike L trans.
Pat and Kat McSwain
"Casper" - Record Holder, Bonneville & El Mirage. Best Clocked Speed 197mph, Bonneville '09.
"World's Fastest Production Diesel Pickup - 174.586mph"
  #117
Old 08-18-2012, 02:09 AM
05chevy's Avatar
05chevy 05chevy is offline
Default
Quote:
I removed my axles after blowing the front diff and the right hub bearing didnt last 20 mile. Now I have timbken bearings. All is good now
__________________
05 lly, s475, 40% nozzles, stock cp3. 11.69 @115
685hp/1100ftlb
97 12valve
  #118
Old 07-03-2013, 11:54 AM
Dragonsfireloki Dragonsfireloki is offline
Default
I don't get it, the truck that i have lifted, modified and i play around in with 153k on it, no problems with the bearings. The truck that has been stock its whole life with 143k on it lost the bearing recently. Should be the other way around, will be doing mine when the timken until shows up.
__________________
06 ECSB- My toy- lots of PPE goods, ARP, lifted, TDK grill guard, stock bottom end
07 CCLB- Work truck- stock so far
EFI and Fabtech traction bars coming soon
  #119
Old 07-03-2013, 01:41 PM
D-MAX Mafia's Avatar
D-MAX Mafia D-MAX Mafia is offline
Hood down, smoke up!
Default
The new Timken bearings are the same for 2wd and 4x4. The stock wheel bearings up to an 07 Classic (maybe higher) 4x4 will need a CV to keep the bearing together.
Timken redesigned their hub a few years ago to work with both. This makes it nice if you lose a CV, it can be removed until you get a new one without worrying about the bearing coming apart.
For those wondering, I wouldn't run anything but a Timken. They are the best!
__________________
Ben
2007 Classic LBZ CCSB LT3 4x4 "Nightmare"
Low and clean on factory LML 20's, CF wrapped hood and roof, PPE: GT4094R, V Trans, Manifolds/Up Pipes, Dual CP3, Lift Pump & Intercooler, DSP5 by Mark@Danville
@currey_racing on IG
  #120
Old 07-03-2013, 01:57 PM
Chevy1925's Avatar
Chevy1925 Chevy1925 is offline
Default
Quote:
lol my truck went something like that. LF went out 10k after putting my lift and 37s on, truck had 95k at the time. RF lasted till 165k and it finally started giving play. LF now has 80k on it and still tight as can be!
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
