  #31
Old 07-20-2009, 08:44 PM
05lly2500hd's Avatar
05lly2500hd 05lly2500hd is offline
(903)293-6026
Default
and there's 5 avail.
http://cgi.ebay.com/ebaymotors/1999-...ayphotohosting
__________________
MAD AMERICAN DIESEL PERFORMANCE, LLC
Amsoil lubricants, S&B intakes, AFE, EFILive, MBRP, Suncoast, MPI twins, EFILive tunes and more...
website will be up soon...stay tuned..
(903)293-6026
  #32
Old 07-25-2009, 07:22 PM
(903)293-6026
Default
well I tackled this today, and I rounded two of the bolts and one I cannot get to back out
__________________
(903)293-6026
  #33
Old 07-25-2009, 07:36 PM
maine04max's Avatar
maine04max maine04max is offline
Default
I found out today that I have a drivers side hub issue . I picked up a timken hub at a local parts place for just under $200 . the plan is to install this in a week or so after my ebc brakes show up
__________________
9/26/09 450 rwhp & 869
4/01/10 mild built motor
05/23/10 656rwhp 1190 trq 12.06 @113
07/20/10 Homebuilt 366 /480 twins
10/23/10 11.74 @121 soft launch
9/11/11 11.39 @120
  #34
Old 07-25-2009, 08:30 PM
(903)293-6026
Default
anyone have the part number for the 4 bolts that bolt assembly to knuckle? 15mm ones.
__________________
(903)293-6026
  #35
Old 10-27-2009, 02:57 PM
JMK777's Avatar
JMK777 JMK777 is offline
16's, but i keep em clean
Default
Do both pass/driver bearings tend to go at the same time? and is it possible to just press a new bearing in the old hub or is it intergrated in the hub? i have to change the driver side so I only ordered one unit.
__________________
2001 lb7, suncoast IV-1057 by Inglewood, JMK hidden traction bars and bump stop relocate kit, JMK S/S tie rod sleeves,QA1's, modded waste gate, EFI live ,JMK stinger exhaust, Aeromotive tsunami fuel pump , stock charger 12.71 @ 107mph
2005 lly ccsb 4x4 white all stock with a small tune.soo fresh and soo clean clean
2002 lb7 ecsb 4x4 white needs injectors and fix trans
sheet metal workers local 104
  #36
Old 10-27-2009, 03:02 PM
McRat's Avatar
McRat McRat is offline
Diesel Hotrodder
Default
The hub is a sealed unit. Often when you replace just one, the other will go out shortly thereafter, at least with my trucks.
__________________
2005 GMC 2500HD LLY "Casper"- LLY O/S 8758. 10.59 @ 129. EFILive "2CP3" Tuning, Mike L Suncoast Trans. PPE Dual CP3's, GT4202R.
2004.5 GMC 3500 SRW LLY "Big Blue" - LLY O/S 1668. 13.12@103. Powered by PPE/VA with Mike L Suncoast Trans.
2006 GMC 2500HD CC/SB LBZ "Wendy"- LBZ O/S 6128. 12.50 @ 107.x. EFILive tuning, Mike L trans.
Pat and Kat McSwain
"Casper" - Record Holder, Bonneville & El Mirage. Best Clocked Speed 197mph, Bonneville '09.
"World's Fastest Production Diesel Pickup - 174.586mph"
  #37
Old 10-27-2009, 03:17 PM
JMK777's Avatar
Default
Quote:
could a locking front end be making both go close to the same time. only reason i ask is these things are expensive but you got to pay to play
__________________
  #38
Old 11-15-2009, 12:07 PM
JMDuramaxLB7's Avatar
JMDuramaxLB7 JMDuramaxLB7 is offline
YOU SAID MEMBER!!!
Default
I replaced one of mine at around 115k and the other one went out about 3k later, my truck must be like Pats. I used the Oreilly house brand and have put about 8k on the first replacement with no truoble. They came with a 1 year replacement warranty also.
__________________
04 CHEVY EC/SB 2500HD
LB7, ALLISON, 4X4
MBRP 4" TURBO BACK
AUTOMETER PILLAR MOUNT BOOST/PYRO
EFI LIVE W/DSP5
BCI COLD AIR INTAKE W/ AEM DRY FILTER
BUILT TRANNY BY SMOKIN DIESEL PERFORMANCE (MIKE BODINE) W/ ML CONVERTER
MOTO METAL CHROME 955's W/ 305/65/17 DC CRUSHERS SUMMER
PYO'S AND 285 NITTOS WINTER
ALL ON HEADLIGHT MOD
COOTER TIE ROD SLEEVES/TRACTION BARS
GOODMARK 2 INCH COWL HOOD
  #39
Old 11-15-2009, 02:50 PM
JD4440's Avatar
JD4440 JD4440 is offline
<< Lo-Carb Monster
Default
Subscribing for links. Need to check mine I guess
__________________
Chris
EFILive(Tuned by JoshH),SC IV,PPE,TTS,Big Dipper,Ect.
O.S. 6128--508hp/12.26@107.4 so far.......Thanks Josh
Quote:
Originally Posted by Trentnell :
Politicians are the only people in the world who create problems and then campaign against them.
  #40
Old 11-15-2009, 02:53 PM
8100 Power 8100 Power is offline
FNG
Default
I hate a bad noise from my driver side. I originally thought the wheel bearing was my problem, so I put a new one one. Same sound. Maybe a tire? But I've never heard a tire sound like this though.
__________________
Jeff
SOLD
06 LBZ
11 LML
  #41
Old 11-16-2009, 10:33 AM
mmangels22's Avatar
mmangels22 mmangels22 is offline
Monty Python Rules.
Default
Can you use an impact wrench or gun on the caliper bolt? There should be enough room right to get it in there?
__________________
Matt
2005 LLY
6 inch fabtech lift
PPE standard xcelerator
35 inch Toyo Open Country AT
17 inch BMF M80 Death Metal Black
I'm thinking of wiping my ass with it, then mailing it back. They should be able to determine everything they need to know by the poopstain. They see the stain, examine it closely, then check the tax records for the information they seek...[/QUOTE]
Good stuff
  #42
Old 01-14-2010, 05:28 PM
Rikter's Avatar
Rikter Rikter is offline
Grumpy, old, farty, funny
Default Can't see pictures
I cannot see the pictures posted (just an "X"). Is there a site that gives exploded view (Not Blowed up real good) just expanded view. When I had a job I had Kal tire do the right front for $1100 that was a rip off!
I need to do this soon it is really growling.
  #43
Old 01-14-2010, 05:45 PM
x MadMAX DIESEL's Avatar
x MadMAX DIESEL x MadMAX DIESEL is offline
<<<< No Horsepower
Default
http://mcratracing.com/wheel_bearing.html
__________________
Ben
LBZ Stock Charger
12.26@108.8
7.78@87.7
2.5 puller in the Mecca!!
Manual Mafia
Quote:
Originally Posted by BgBlDodge View Post
Al gore invented driving the turbo.
  #44
Old 01-14-2010, 07:22 PM
Kat's Avatar
Kat Kat is offline
Wicked Witch of the West
Default
Quote:
Originally Posted by x MadMAX DIESEL View Post
Thanks Rob also fixed the broken links
__________________
Blue Meanie 02 Z06 11.36 @ 120.67 448 rwhp/411 tq AFR H/C
Wendy 06 GMC LBZ CC/SB EFI "Rat Posion", Sun Coast trans, SC 1057 & Transgo JR by MikeL, true downpipe, Banks Ram-Air SD sleeves 12.50 @ 107.51
Big Blue04 GMC LLY 3500 SRW CC LB 4x4 DA Big Blue 13.12 @ 103.93 466RWHP/928TQ. PPE LLY extreme tune, VA Box, SC III by Inglewood Trans, 4" straight pipe, Super Diesel Tie Rod supports and Manifold, Trippin Pickup, Cognito Braces, FuzzyDice.
McRat's toy-2005 GMC "Casper 2" 2500HD 4wd Xcab SB Mike L. LLY 2 trans, McRat tuning 10.59 @ 128.9
  #45
Old 01-14-2010, 07:28 PM
PhilsLB7's Avatar
PhilsLB7 PhilsLB7 is offline
Way Better Than Facebook
Default
Subscribing - Nice write up Kat!
__________________
Phillip
02 Chevy 2500HD CC/SB 4X4 LB7 w/Allison Trans
Just stock
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
