  #31
Old 11-11-2007, 06:37 PM
sweetdiesel's Avatar
sweetdiesel sweetdiesel is offline
That's better
Default
Quote:
Originally Posted by 02freighttrain View Post
That's what she said
__________________
2017 2.5L D-Max Trail Blazer
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
Abby 01 RC/LB 10.28@144mph
SOLD
  #32
Old 11-11-2007, 06:49 PM
TNRGreene TNRGreene is offline
Kicked to the Curb
Default
Listen here you SOB, oh wait that is what she said...nevermind
__________________
I don't carry a gun to look for or start a fight. I carry one to finish a fight I never wanted to be in.
  #33
Old 11-11-2007, 07:54 PM
That's better
Default
i found some old Pics of the previous setup that I first had
if you want to be able to return to stock DO THIS , However I did not like this method, Simply because it would leak a bit out of the 90 no matter how tight I got the clamp
__________________
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
SOLD
  #34
Old 11-12-2007, 05:18 AM
Diesel Pilot's Avatar
Diesel Pilot Diesel Pilot is offline
Hat√ Suitcase√ 50 BMG√
Default
I bet that the reason that no oil is coming out the new PCV has somehting to do with the intake that KB is talking about in the other thread. The stock PCV is under so much negative pressure from the turbo trying to pull in air that it also pulls oil from the case.
I'm going to do this mod next time I change oil.
Any ideas on how to clean the oil off the charger, or does it even make a difference?
  #35
Old 11-12-2007, 06:14 AM
LBZ's Avatar
LBZ LBZ is offline
Default
Cleaning the inside is probably pointless. You will most likely add contamination to the system in the process.
Outside a good douche with engine degreaser and it will look like brand new!!
  #36
Old 11-12-2007, 09:59 AM
That's better
Default
craig
my hose has a positive pressure on it, maybe 0.5 psi but its positive, and it increases
i never get any drips on the driveway,but you can see that there is oil in the line
This mod, coupled with the EGR blocker will help keep the inside much cleaner!
__________________
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
SOLD
  #37
Old 11-12-2007, 08:38 PM
LBZ's Avatar
LBZ LBZ is offline
Default
On a side note, you may want to route your hose so that it doesn't come out into your D/S fender well or under the door.
Mine stinks whenever I'm at a drive thru window!!
  #38
Old 11-28-2007, 09:55 AM
LarryJewell's Avatar
LarryJewell LarryJewell is offline
Back with his honey :)
Default
Quote:
Originally Posted by sweetdiesel View Post
craig
When I installed the modded turbo inlet the other day I had to pull apart my pcv re-route job to get it in. I noticed that there was some oil residue in the hoses I pulled off, But I do not have any evidence of leaking in the garage or on the driveway.
__________________
2004 LLY
Cheetah & MPI Twins
PPE Duel Fuelers
Member # 270
  #39
Old 11-28-2007, 04:46 PM
WolfLLY's Avatar
WolfLLY WolfLLY is offline
Making Chips
Default
Try acetone on a rag. Its just oil so if any was able to get "free" and enter the engine you have no worrys. Becareful with the compressor it is more fragile than you would think.
__________________
LMM CCSB LTZ Z71. SoCal motor, s485/68r, 1078 Limitless converter, S&S 200s.
LB7 ECSB 4X4
Thanks to Evan@Limitless, Mark@Danville Performance, Josh Harris@Top Notch, and Corbin(crussel)
  #40
Old 11-28-2007, 05:52 PM
Mike Mike is offline
hmmm....
Default
Do you think there will be a lot of neg. pressure at the pcv hook up point? I am thinking the restriction is between compressor of the turbo and the pcv hookup point. I do realize that oil is part of the air being passed to the compressor by way of the stock pcv arrangement. I also realize that air passing through the intake creates a draw from the pcv bung. Just wondering.
__________________
2004 lb7 2500 cclb 4x4 <- Wrecked / repairing for daughters ride.
2005 LLY 3500 cc 4x4 <- Gone
2007 lmm excb 4x4 dually GMC <- Gone
2015 LML cclb 4x4 dually GMC Tow hog
2015 LML ccsb 4x4 GMC Denali ( wife's ride ) Needs a " this is not my husbands ride " sticker.
  #41
Old 11-29-2007, 05:08 AM
Default
Quote:
there is not enough oil residue present to indicate that a significnt amount is being pulled thru.
__________________
2004 LLY
Cheetah & MPI Twins
PPE Duel Fuelers
Member # 270
  #42
Old 02-18-2008, 09:17 PM
LBZ's Avatar
LBZ LBZ is offline
Default
Update-My hose does leak oil. I will post a pic when I get back to the real world. It's not much, but be aware-you may have a little oil dripping out of it after extended periods of idle such as winter warm-ups.
  #43
Old 02-18-2008, 10:05 PM
That's better
Default
Quote:
there is - press ya? is it needed? IMO no!
Lb7 dont need it it vents fien without the - pressure unless it freezes shut
__________________
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
SOLD
  #44
Old 02-18-2008, 10:08 PM
LBZ's Avatar
LBZ LBZ is offline
Default
Whats that Kurt??
  #45
Old 03-08-2008, 03:50 PM
Default
Thought this would be a good sticky too
__________________
2004 LLY
Cheetah & MPI Twins
PPE Duel Fuelers
Member # 270
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
