  #1
Old 10-19-2007, 12:28 PM
sweetdiesel's Avatar
sweetdiesel sweetdiesel is offline
That's better
Default PCV reroute
these are pics from my LLY, i will post pics next week from doing a LBZ
Basicly, if you do not want you intercooler boots and lines coated in oil or your turbo DO THIS MOD you can do this for under 10 bucks and a 1/2 hour of you time
1 thing if you want to return it to stock Dont do it like i did and simply install a 90* on the bottom of the hose going into the turbo intake and cap your intake
as for the cap on the intake i used a bar stool leg cap ( floorsaver) came in a pack of 4 and cost about 3.00
i did have a 90* on the bottom of my vent hose,but it would always leak a bit of oil so i just cut both sides of the hose coming off the valve covers and installed a couple push on nipples and a "T", I then bought a chunk of hose long enough to reach the bottom of the truck and cut the bottom at a angle
kinda like are old dirt bikes so it cant get plugged or freeze up
hope these pics help, and i will continue to add to this post
__________________
2017 2.5L D-Max Trail Blazer
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
Abby 01 RC/LB 10.28@144mph
SOLD
  #2
Old 10-19-2007, 12:38 PM
LarryJewell's Avatar
LarryJewell LarryJewell is offline
Back with his honey :)
Default
Thanks for the info Simon, i'll do mine tomorrow and post up some additional before and after pics. I do have a little oil leak on the passenger side intercooler boot. Glad to know there is a fix for this, the dealer basically told me to live with it, its a normal problem and deosnt hurt anything.
__________________
2004 LLY
Cheetah & MPI Twins
PPE Duel Fuelers
Member # 270
  #3
Old 10-19-2007, 12:43 PM
That's better
Default
Quote:
IMHO this should be done the day the truck leaves the dealer for the first time it will also help to prevent your intercooler boots from coming off under high boost and help keep the underhood looking good
__________________
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
SOLD
  #4
Old 10-19-2007, 04:46 PM
That's better
Default
parts list:
1- barstool leg cap as seen in the previous post that goes onto the LLY stock intake
you do not need a hose clamp for this
3- 5/8"s pushon king nipples or barbed nipples
3- hose clamps for 5/8" hose
1- 5/8" T
1- 6' piece of 5/8" heater hose
teflon tape is optional
beer is optional, but highly recomended
5/16" socket and ratchet or flat screwdriver for the hose clamps
razor blade or sharp knife
couple zip ties again optional
this is if you want to do it my way and there will be no returning to stock, But i have never had GM say anything about this mod! the LB7 is allready set up similar to this
and no i do not get oil dripping on the driveway from doing this mod
here is a picture of the stock set up and the barstool plastic cap and the barbed nipples i was refering to
__________________
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
SOLD
  #5
Old 10-20-2007, 01:11 PM
Default Larry's Install, Part 1
All Parts bought at Home Depot and/or Auto Zone
Parts used were:
1 Watts A-808, PBC101 1/2" Cast Female Pipe Tee
3 Watts A-493 225 Hose Barb Adapter 5/8" Barb x 1/2" MIP
3 5/8" hose clamps
7' 5/8" heater hose
1 Leg Tips Puntas "rubber bar stool leg cap" package of 4 size 7/8" or 22mm
teflon tape & zip ties not shown
Tools used were:
Flat tip screwdriver
Razor Knife
Stool "for the vertically challenged"
6 Pack Miller Lite "very important"
2 Ribeye Steaks for later
Now wait for motor to cool off, drink 1st beer while seasoning steaks...
__________________
2004 LLY
Cheetah & MPI Twins
PPE Duel Fuelers
Member # 270
  #6
Old 10-20-2007, 01:26 PM
Default Part 2
Cut factory hose, remove cap from turbo inlet, and install 7/8" barstool cap.
The 1" cap would probably work, but I used a rubber mallet to tap the 7/8" cap in place.
Notice oil residue around inlet?
__________________
2004 LLY
Cheetah & MPI Twins
PPE Duel Fuelers
Member # 270
  #7
Old 10-20-2007, 01:49 PM
Default Part 3
1st Beer finished
Wrap threads in teflon tape, then insert into Tee adaptor. Put hose clamps on hoses and insert hoses into barbed ends. Now figure where to route long piece of heater hose, but first cut bottom of hose at an angle as Simon posted in the original thread.
__________________
2004 LLY
Cheetah & MPI Twins
PPE Duel Fuelers
Member # 270
  #8
Old 10-20-2007, 02:55 PM
Default Part 4
Project finished, turned out to be a 2 beer mod with less than $15.00 in parts.
__________________
2004 LLY
Cheetah & MPI Twins
PPE Duel Fuelers
Member # 270
  #9
Old 10-20-2007, 03:08 PM
Default Oil Build-up
Here's some pics of my old boost tubes and intake riser, with oil build-up.
__________________
2004 LLY
Cheetah & MPI Twins
PPE Duel Fuelers
Member # 270
  #10
Old 10-21-2007, 06:13 AM
bullfrogjohnson's Avatar
bullfrogjohnson bullfrogjohnson is offline
Big Girl!
Default
there is no reason to do this to a lb7 correct?
Larry and Simon, great write ups, i have already emailed them to my lilly buddies, i wish everyhting was that easy
__________________
Travis
03 CCSB lb7
06 2500hd ECLB 6.0 gasser
2010 Straight Diesel 2.8 Points Champion
special thanks:
B&B Pulling and Greene's Diesel Performance, Fully Spooled Motorsports, Johnboy, Simon, Ed, ProFab Performance, Hamilton Cams, Extreme Prejudice Racing, Ridge Runner Diesel
  #11
Old 10-21-2007, 08:39 AM
Diesel Pilot's Avatar
Diesel Pilot Diesel Pilot is offline
Hat√ Suitcase√ 50 BMG√
Default
Thanks Larry and Simon.
  #12
Old 10-21-2007, 10:32 AM
That's better
Default
the lb7 does not need this mod,Atleast the ones that ive seen
i wish everything was this easy too
we will be doing the LBZ next week
__________________
Stock
07 RC/LB 2wd
SOLD
05 CC/LB 4X4
SOLD
SOLD
  #13
Old 10-21-2007, 07:05 PM
mvnvltn's Avatar
mvnvltn mvnvltn is offline
Part's Limit Tester
Default
Larry has the enemy parked in his garage.
__________________
2002 C/C Dually LB7
It has some (broken) stuff
  #14
Old 10-21-2007, 07:42 PM
Default
Enemy?
__________________
2004 LLY
Cheetah & MPI Twins
PPE Duel Fuelers
Member # 270
  #15
Old 10-21-2007, 08:07 PM
Mike Mike is offline
hmmm....
Default
Enemy?
The Mustang...... lol
__________________
2004 lb7 2500 cclb 4x4 <- Wrecked / repairing for daughters ride.
2005 LLY 3500 cc 4x4 <- Gone
2007 lmm excb 4x4 dually GMC <- Gone
2015 LML cclb 4x4 dually GMC Tow hog
2015 LML ccsb 4x4 GMC Denali ( wife's ride ) Needs a " this is not my husbands ride " sticker.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
