  #5806
Old 04-15-2018, 05:55 PM
TheBac's Avatar
TheBac TheBac is offline
Default
Quote:
Originally Posted by Burn Down View Post
Brought Verlon’s truck home. Pulled the shot 18’s off and swapped on some 20” proxes. Pulled the broken bug shield off. Needs a bath and a good cleaning. Also has annoying up-pipe gasket leaking, but that’s for another day.
You bought his truck?
__________________
Tom
"BBT" -- 2003 GMC CC/SB 4x4 12.14@111.15
"Flyin' Brick" -- 1999 Chevy 1500 RC/SB 2wd -- stalled out, no motivation
"The Cruzer" -- 2014 Chevy Cruze Diesel -- the fun little DD
"The Bigger Boat" -- 2011 Workhorse P700 - 6.0LS/Allison - what I drive at work
Two wrongs dont make a right, but three rights do make a left.
Reality is a matter of perspective.
This forum isn't for the weak of heart.....or wallet.
"Lets build a race car they said. Itll be fun they said. I don't know who "they" are.........but they need a good punch in the face!" -- mufflerguy (yb)
  #5807
Old 04-15-2018, 06:06 PM
Burn Down's Avatar
Burn Down Burn Down is online now
Default
Quote:
Yep, I have 3 of these headaches now
__________________
04.5’ CCSB ole blue, built trans, mpi twins
03’ Reg Cab ZF 6
05’ CCSB ole crappy, built eng, built trans, mpi twins
  #5808
Old 04-15-2018, 08:58 PM
Lparrill's Avatar
Lparrill Lparrill is offline
Might as well burn money
Default
Quote:
Originally Posted by minerigger View Post
Need some info from my Colorado fellas. How are you running deleted trucks with emissions testing. Looks like we are possibly moving to Windsor area down to Ft. Lupton area and I want to know how to keep my truck
Sent from my SM-G930V using Tapatalk
Make sure truck is registered in a county without emissions. IE weld county.
__________________
Levi
04 GMC CCSB LLY l Mahle Pistons with reliefs l Carillos l ARP Studs l Socal Stg 2 Heads l Suncoast Trans with Billet Shafts l Danville 72vgt l Double Bat S483 l HSP Piping l 60% overs l II 85% over + LBZ CP3 l FASS 220 l DRP Sump l BT Lockup Box l Fabtech "Traction"/Axle wrap Bars l Mishimoto Intercooler l Zex Nitrous
Tuning by Wade at Diesel Day Dreams
  #5809
Old 04-15-2018, 09:07 PM
minerigger's Avatar
minerigger minerigger is offline
Default
Hmmm Well might have to try and get that figured out
__________________
Brock
06 LBZ ECLB
Gauges, Danville Tunes, 5" Dumped, Trans by Evan, DP Stg2r, Sleeved/Braced and some other odds and ends crap that we all have
  #5810
Old 04-16-2018, 03:10 AM
Lparrill's Avatar
Default
I work down here as a field supervisor. If you make it down this direction definitely give me a shout. Most of the rigs drilling in Northern Colorado are in Weld County.
__________________
Levi
  #5811
Old 04-16-2018, 06:40 AM
wilrob's Avatar
wilrob wilrob is offline
Back in the Motherland
Default
I moved to Texas is how
but when I was in CO I only had my DPF deleted, so I would spend an hour swapping it out.
__________________
Wil
2008 CC/SB LMM SLT
EFI by Idaho Rob | 5in Straight Pipe | Isspro Ev2 Gauges | Titan 52gal Fuel Tank | Banks Intake/Filter | DJM 3in Drop Shackles | PCV Reroute | Custom Power Steering Cooler
1983 c10/Cummins Conversion - On Hold
"I think we missed the turn..." - Somewhere in Baja
  #5812
Old 04-16-2018, 08:30 PM
minerigger's Avatar
Default
Well it's becoming more likely I'm headed that way. So short of finding all my emissions parts under the hood, what's my options for this truck or am I just screwed and be doing swaps come time for smog and whatnot
__________________
Brock
06 LBZ ECLB
  #5813
Old 04-17-2018, 06:36 AM
wilrob's Avatar
Default
To be honest I think you are SOL. There was a member on here that worked at a shop in Loveland that said he could pass you but idk if he is still around. (cant remember his name either). Everyone I know in CO registers out of state if they are deleted.
EDIT: Maybe get in touch with Diesel Day Dreams and see what they might suggest?
__________________
Wil
2008 CC/SB LMM SLT
  #5814
Old 04-18-2018, 03:54 AM
CarolinaHD CarolinaHD is online now
Default
Ordered a 68stg2r from Mark last night
Last night/this morning finished installing the injectors, hard lines and modified the fuel test port supply line. You can see to the left of the oil fill tube where I shaved it down. Also, made the lbz oil fill tube to clear the van thermostat housing.
__________________
Alex
LBZ CCSB 4x4
EFI Live
RDL Y-bridge
166,000 miles
Sold
2003 C&C lb7/zf6
275,000 miles
LBZ & 4x4 Conversion in progress...
Turned into a frame off restomod
  #5815
Old 04-18-2018, 05:11 AM
zakkb787's Avatar
zakkb787 zakkb787 is online now
<that’s not me...
Default
You outta come get these flares off my back porch 😂
__________________
2006 LLY CC/SB LT3 mostly stock
Other toys:
1982 K10 6.2 Detroit diesel/sm465/np205 with 4 inch lift and 35s. And it’s currently broke
2011 Yamaha YFZ450X
2003 Yamaha YZ250
2003 Kawasaki Z1000
  #5816
Old 04-18-2018, 07:37 AM
Novak's Avatar
Novak Novak is offline
SQUIRREL TRYN TO GET A NUT
Default
Brought Verlon’s truck home. Pulled the shot 18"s off and swapped on some 20” proxes. Pulled the broken bug shield off. Needs a bath and a good cleaning. Also has annoying up-pipe gasket leaking, but that’s for another day.
For some reason I thought he was gonna use that to compete this year. Good buy though! I seen it do some pretty impressive things!
__________________
2008 LMM :SOLD 2/18
4" MBRP TB AXLE DUMP, EFI IDAHO ROB, PPE RAIL PLUG, S&B AIR, PPE TRANS COOLER, FLEECE TRANS LINES, AIRDOGG 165, EDGE CTS, KRYPTONITE STEERING RODS AND KRYPTONITE IDLER, COGNITO STEERING BRACES, COGNITO DIFF MOUNT, BARS TURNED DOWN AND DROP SHACKLES ON REAR, ALL OTHER PM (REROUTES AND DELETES) PAINT PAINT PAINT
2004.5 LLY :SOLD 2/15
5" TB EXHAUST, FASS LIFT PUMP, PPE TUNE, PUMP RUB, MOUTHPIECE, PAINT PAINT AND PAINT
  #5817
Old 04-18-2018, 01:15 PM
Default
Quote:
You outta just give em to me
__________________
Alex
LBZ CCSB 4x4
EFI Live
RDL Y-bridge
166,000 miles
Sold
2003 C&C lb7/zf6
275,000 miles
  #5818
Old 04-19-2018, 01:30 PM
black00chev's Avatar
black00chev black00chev is offline
FNG
Default
Yesterday I installed the LBZ mouthpiece and ProFab intake kit. Just need to figure out what I wanna do to reroute the PCV.
__________________
2004 LLY 2500HD CCSB 4x4 - only 36,000 miles and 100% stock..... for now.
2000 5.3L Z71 - 200,000 miles and counting... makes ~340/330.
  #5819
Old 04-19-2018, 09:21 PM
Burn Down's Avatar
Default
Quote:
Shamu is the race truck. Silver 06 CCSB LBZ, its the one with the sponsor wrap on it. I bought the white "tow truck" 05' LLY.
__________________
03’ Reg Cab ZF 6
  #5820
Old 04-21-2018, 10:38 PM
Wturnbo Wturnbo is offline
FNG
Default
Took off the stock fender flares. Surprise no rust just tge annoying adhesive gm used took couple hours to get that fully off. Looks so much better.
__________________
2006 lbz GMC 2500HD SLT 4x4 KN intake straight piped.
https://www.instagram.com/p/BbNDs6dH...bRnAcYIawGz00/
1990 f150 302 single cab long bed
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
vB.Sponsors
