Old 04-16-2018, 12:01 PM
500hpduramally 500hpduramally is offline
FNG
Default LLY rough idle
Having a couple problems with my truck. On first start up truck runs rough for a few minutes. When itís running rough actual rail pressure is inconsistent. Truck also blows blue smoke for 5-10 minutes. temps in 45-50 degrees. injectors were sent back to S&S because #2 balance rate was 4ish. All injectors tested good. #2 injector went back in #8 hole. Balance rate on #8 is 2-2.5 now and still smokes blue.
Other problem is once truck is up to temperature idle is very choppy and slight loping. Desired rail pressure is 4.4 and actual fluctuates from 4.2 to 4.4 balance rates wonít read (all read 0.0) in park unless I hold the brake
Have sent log to tuner they bumped rail pressure to 6.5 at idle but it didnít do anything to smooth it out. Any help would be appreciated
2005 CC/SB LLY 4X4
EFI Live by Duramax tuner
Build trans
Fass 150
MBRP exhaust
Diamond eye downpipe
Exergy sportman cp3 lbz regulater
45 over S&S injectors
Danville 3794 stg2
Wcfab y bridge intercooler pipes intake and turbo mouthpiece
Long Horn fab traction bars
Old 04-16-2018, 12:48 PM
Nathan.'s Avatar
Nathan. Nathan. is offline
I may be wrong (I welcome corrections) but isn't blue smoke oil?
2005 Sierra CC LLY
2006 Jetta TDI BRM
2014 Harley Davidson Street Glide Special
Old 04-16-2018, 12:57 PM
torqued2dmax's Avatar
How many miles on eng , what tune has it lived its life in , how is the truck used , did you buy the cp3 new , what type of fuel pickup are you using , have you done a compression test yet ?
05 CC/LB DRW LLY Allison
Old 04-16-2018, 01:22 PM
FNG
175000 miles. Tune #4. No idea on the hp. Yes cp3 was bought new and has about 10,000 miles since. Thereís a fass draw straw in the tank. No compression test yet. Was planning on doing one.
I have replaced the FPR twince since the cp3 going in. Before winter was loping pretty hard so replaced it and a couple months after replacing it it starting loping again so LDS sent me another under warranty
2005 CC/SB LLY 4X4
Build trans
Fass 150
MBRP exhaust
Danville 3794 stg2
Old 04-16-2018, 01:29 PM
FNG
Truck is mostly just daily driven some light towing
2005 CC/SB LLY 4X4
Build trans
Fass 150
MBRP exhaust
Danville 3794 stg2
Old 04-18-2018, 12:24 PM
Now that you switched injector positions is # 2 still off a bit ? If so the compression test might help a bit to narrow it down . Good luck though !
Old 04-18-2018, 02:10 PM
FNG
No #2 balance rate is great. Reads Around 0.5. Thanks for your help
2005 CC/SB LLY 4X4
Build trans
Fass 150
MBRP exhaust
Danville 3794 stg2
Old 04-18-2018, 04:48 PM
aklbz's Avatar
aklbz aklbz is offline
What do the rates do in gear on the brake with with engine warm of course?
2005 Chevy CC/SB LLY
HSP Mouth piece
EGR Delete
PCV reroute
5" Exhaust
Raptor 150 with water seperator and cat filter
Edge Insight CTS2
Tuned by Danville Performance
  #9
Old 04-18-2018, 06:22 PM
I forgot to ask if you have a v2 or tech 2 for code reading ? There is a problem with a truck posting right now that has crazy problems that may be linked to the $15 engine coolant temp sensor , its strange how a small thing can cause big problems ! I hope someone can help you out !
  #10
Old 04-18-2018, 06:25 PM
FNG
All cylinder read read + or - .5 except #8 which is between 2.5 to 3.5. I can get actual rates tomorrow.m
Only way I can get them to read in park is if I hold the brake pedal down really hard
2005 CC/SB LLY 4X4
Build trans
Fass 150
MBRP exhaust
Danville 3794 stg2
  #11
Old 04-18-2018, 06:33 PM
FNG
No v2 or tech 2. Have a autocal though. No code show up on my cts2 but will see if code should up in autocal
2005 CC/SB LLY 4X4
Build trans
Fass 150
MBRP exhaust
Danville 3794 stg2
  #12
Old 04-18-2018, 06:42 PM
That is strange that the injector that was in #2 that you were getting 4 rates , you put it in #8 and now that same injector is near 4 again after being checked out ! I am not saying 4 is all that bad , but its just strange ! I would not think that would be within there limits but I am not sure . Good luck though !
  #13
Old 04-18-2018, 06:50 PM
FNG
Yeah I have a feeling that there might be something up with that injector. I put an email into them again and see what they have to say. Thank you for the input
2005 CC/SB LLY 4X4
Build trans
Fass 150
MBRP exhaust
Danville 3794 stg2
  #14
Old 04-18-2018, 06:55 PM
TheBac's Avatar
TheBac TheBac is offline
Being an LLY, the connector could need to be ice-picked.
Tom
  #15
Old 04-18-2018, 06:58 PM
FNG
Replaced #2 injector plug and ice picked the rest of them
2005 CC/SB LLY 4X4
Build trans
Fass 150
MBRP exhaust
Danville 3794 stg2
