  #16
Old 07-17-2017, 05:39 AM
kowclub173 kowclub173 is offline
FNG
Default
Quote:
Originally Posted by hondarider552 View Post
They don't lower overall temps one bit.
Dyno and countless first had reviews state you are wrong. Peak might still be the same but takes much longer to get there.
  #17
Old 07-17-2017, 07:09 AM
monster50iii's Avatar
monster50iii monster50iii is offline
Default
I've found egts are a bit higher just cruising with my profab manifolds and up pipes vs the stock stuff. WOT i definitely a different story though. Bigger isnt always better for towing. Honestly for towing heavy the 3794 is probably about as big as you want to go to keep egts in control. Any bigger and the stock turbo is probably better. Twins would be best, but its alot of cash. Danville's 3794 has done well for me towing. I'll be honest though, power is up, and so are the egts a bit while towing. The stock turbo ran pretty dang cool for me towing here in MN. It barely ever broke 1100*. BUT, also had quite a bit less pulling power vs the 3794. My buddy has danvilles 4094 stg2r, and his truck runs warmer than mine towing, even though his spoolup from a stop is about twice as quick as mine.(4094 ex. housing is quite a bit bigger than the 3794)
__________________
Love your country, never trust your gov't
  #18
Old 07-17-2017, 07:22 AM
TROJAN366's Avatar
TROJAN366 TROJAN366 is offline
Gold Rush
Default
Twins FTW.
__________________
05 LLY CC/SB
Roderiques ATV Built Motor, HSP Twins, NLX88/Danville72R,
S&S 200s, S&S 10mm & LBZ, Tuned by Danville Performance
Suncoast Competition trans and Goerend Converter
1125hp/1628lbft 10.52@132
Thanks to
Chris @ Roderiques ATV in Westport MA
Mark Broviak @ Danville
Joe and Dave @ HSPdiesel
  #19
Old 07-17-2017, 07:43 AM
novaman64's Avatar
novaman64 novaman64 is offline
that guy
Default
Quote:
Who's tuning do you have? I heard Mark's tunes run super cool....
__________________
-Jimmy
08' Silverado 3500HD CCLB LMM 4x4 - Build Thread
02' Silverado 2500HD CCLB LB7 4x4 - RIP 12/15/2016
  #20
Old 07-17-2017, 09:56 AM
Default
I had Mark's stuff for a year or two and now am doing my own tuning. Marks stuff ran alot cooler than the PPEI stuff I tried originally. Marks tuning was alot more fun to drive than the PPEI tunes. That and Mark is a super nice guy. But, tuning only goes so far for spool up etc.
__________________
  #21
Old 07-17-2017, 12:54 PM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
Default
I personally would look at getting your turbo rebuild with a port and polish. Not sure what that's worth for EGT's exactly but if you're not really after more power no point in spending thousands when you can spend hundreds.
__________________
06 GMC 2500 CCSB SLT LBZ 4X4
These views expressed on this post are not my own, but rather randomly generated computer gibberish, and in no way should be used to judge the author's IQ or mental health.
  #22
Old 07-17-2017, 09:39 PM
2008lmmchopper 2008lmmchopper is offline
Default
What all else is done in the motor? If your stock internally I'd be careful. I'm running everything you can do basically with stock turbo , injectors, and cp3 in my lmm and motor innards are stock. Got max effort tuning by ppei and I'm a turbo size bigger or injector size from popping my motor.
Sent from my STV100-2 using Tapatalk
  #23
Old 07-17-2017, 10:01 PM
novaman64's Avatar
that guy
Default
Stock aside from my AD2 165 and PPEI tuning...
__________________
-Jimmy
  #24
Old 07-17-2017, 11:39 PM
Budneeds2beers's Avatar
Budneeds2beers Budneeds2beers is offline
Aka Mike Honcho....
Default
P&P with new vanes and wheel call it done.
  #25
Old 07-18-2017, 12:20 AM
Stancedlb7's Avatar
Stancedlb7 Stancedlb7 is offline
Cummin Stroke this Duramax
Default
Quote:
This with water/Meth or S475/stock. No need to build the trans unless you are going to race it...
__________________
Marco
It's "stock"
Built trans
Too much Nitrous
  #26
Old 07-18-2017, 05:39 AM
TROJAN366's Avatar
Gold Rush
Default
Quote:
So you think a stock trans will hold up towing with twin turbos and a tune? I wouldn't give too much advice......
__________________
05 LLY CC/SB
Thanks to
  #27
Old 07-18-2017, 08:15 PM
NC-smokinlmm's Avatar
NC-smokinlmm NC-smokinlmm is offline
<<<Future tuna killer
Default
Quote:
__________________
2010 GMC 1500 SCSB Denali Clone < lifted 22's/33's, Kooks, Magnaflow, 5.3, 6l80, TVS1900, lots of boost, Mayhem tuned, etc...
2015 Corvette Stingray Z 51 < Stock...
2016 LML CCSB Denali < Lifted 22's/35's, Fox 2.0 < I officially need help.
  #28
Old 07-18-2017, 08:26 PM
WVRigrat05's Avatar
WVRigrat05 WVRigrat05 is offline
Wound for sound
Default
I couldn't tow on a stock turbo without limping my Lilly, I could make my LMM converter cry the few times I actually towed.
I built my trans ASAP this go around, well, it came out real fast but it was sooner than later, lol.
__________________
Reger
05' Black Chevy CC/SB LT- Blackout Performance built motor/trans/tuning- Gone
The Blessed Hellride- 08' White GMC Sierra SLT CC/SB,
100k miles. Piston eater.
Wife's ride- 2016 Pearl white Legacy limited 3.6R
Rig ride/new DD-02' Black Eddie Bauer explorer 4.6, -180k, still sporting original trans, outlasted two Duramaxs.
  #29
Old 07-23-2017, 11:32 PM
novaman64's Avatar
that guy
Default
Ok, so been doing a bunch more reading, including 90+ pages on Mark's BMW 3794 Stage 2, and a ton of threads on his 68mm Stg2R.
I think I have decided that I am going to replace the factory turbo, then start building another motor. Once I have a short block done in a couple years (LML crank, carillo rods, Mahle cast pistons) I think I will throw a S480 on top over whatever valley charger I am choosing now....
That being said, I think I have narrowed it down to 3 valley chargers. SDP's 3794 68mm w/billet wheel, Danville BMW 3794 Stage 2 or Danville's 68mm Stg2R. All the threads I have been reading about the Danville BMW 3794 make it sounds like the bees knees when it came out, then about a year or 2 later when the 68 Stg2R came out, a bunch of people who were running the 3794 switched to it and said spoolup was about the same but the turbo had more up top...
Prolly going to send my injectors out to Exergy to get them honed to 45% over when I put the turbo in...
So thoughts between the 3 turbos I listed?
__________________
-Jimmy
  #30
Old 07-24-2017, 05:29 AM
oscyjack's Avatar
oscyjack oscyjack is offline
Default
3 good choices imo. I'm stuck in the same boat with my LMM. I decided to wait until I can afford a full engine build but I've pretty much landed on the 68stg2r.
__________________
'08 LMM CCSB
Limitless trans
EFIlive - PPEI
Built front end
All the bolt ons
33x11.5 on 17x9 -12
HB/brake upgrades
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
