  #76
Old 07-13-2017, 03:38 AM
cardiac cardiac is offline
Gearhead
Default Smoke
Well the 60 overs and the 68mm are for sale if you would like to try and prove your theory. I'm sick of the smoke caused by the turbo lag at low rpm's.
  #77
Old 07-13-2017, 07:29 AM
Chevy1925's Avatar
Chevy1925 Chevy1925 is offline
Default
Quote:
its really not a theory, ive personally been in two trucks with this setup that are clean. Even sat in the truck with the tuner as he dialed it in to make sure it was up to what i wanted for a built truck . you have another issue that flat out needs to be address that we probably wont be able to do over text
__________________
Quote:
Originally Posted by JoshH View Post
Mike L is my role model. I want to be like him when I grow up.
James
02 LL7 2500HD CC/LB dmax/alli "The Limo"
BIG THANKS TO: Mike L, Steve, Trent, Guy, Dan, Ruben, Josh H, Scott, Brian and everyone else who has put a hand in to help me.
best time to date: 12.39
motor died/bent rods = 3/11/11
back from the dead 7:04pm 4/9/2012
Limo is back in the garage, now driving a built chevy tracker
Tailgate Crew Member #4
  #78
Old 07-13-2017, 08:38 AM
torqued2dmax's Avatar
torqued2dmax torqued2dmax is offline
Default
Will you be charging for this added service ? LOL
__________________
05 CC/LB DRW LLY Allison
AFE Blade Runner,AFE Momentum CAI,DHD Big Air intake Y pipe, DHD fuel block,DHD pcv reroute,MBRP 4 inch exhaust,DHD 3 inch downpipe,BD driver's side manifold,DHD pass side up pipe,DHD 3 inch intercooler hot&cold pipes, ATI damper,Empire pin kit by Big Foot on & off road shop, FASS fuel system,5/8 inch pickup, FASS fuel filter delete, EFI live,V2 & lap top , 5 position switch 250 hp big tune, shimmed fprv by Crank it up , built SunCoast Allison 1078 converter aftermarket trany mount by Limitless Diesel,ARP head studs,grade C gaskets,tig-welded water pump,T stats by Blackout performance,MA t case brace , Kriptonite motor mounts,MA pump rub kit,HD drive shaft 1480joints by Greensburg machine,BDS Recoil traction bars, PPE finned deep pan , Mike L trany cooler, PSC pump, 5100s, Sulastic Shackles, Curt com 2.5 hitch
  #79
Old 07-13-2017, 01:24 PM
WVRigrat05's Avatar
WVRigrat05 WVRigrat05 is online now
Wound for sound
Default
What do you want for that 68? I'll smoke the whole hillside out for all I care.
__________________
Reger
05' Black Chevy CC/SB LT- Blackout Performance built motor/trans/tuning- Gone
The Blessed Hellride- 08' White GMC Sierra SLT CC/SB,
100k miles. Piston eater.
Wife's ride- 2016 Pearl white Legacy limited 3.6R
Rig ride/new DD-02' Black Eddie Bauer explorer 4.6, -180k, still sporting original trans, outlasted two Duramaxs.
  #80
Old 07-14-2017, 06:06 PM
Gearhead
Default Fuel return line
Well I been thinking. I changed out all the factory fuel return lines with 1/8" hose between the injectors going into a 1/4" tee out of that tee into a 5/16" tee that was going into the 10mm pump and out to the return line with 5/16" hose.
With all that being said, could the pump put out more fuel to the return than the 5/16" hose can get rid of and be causing extra fuel to stay in the cyl and cause the extra smoke?
  #81
Old 07-14-2017, 06:16 PM
DAVe3283's Avatar
DAVe3283 DAVe3283 is offline
Default
To end up in the cylinder, the return line would be hundreds, if not thousands of PSI. And even then, my limited understanding of the solenoid injectors says that they would just stop firing at some point, not hang open.
If you swapped injectors and the problem stayed with the cylinder, not the injector, the issue isn't the injector. It is something else. Could be electrical, could be mechanical, but it isn't the injector.
__________________
  #82
Old 07-14-2017, 06:21 PM
Gearhead
Default
Ok thanks
  #83
Old 07-17-2017, 11:02 AM
Wikid's Avatar
Wikid Wikid is offline
Machinist and Know things
Default
I changed out all my fuel return and feed lines, I did talk to Exergy about this, he did say that too small of a fuel return can cause issues. One issue being that the fuel pump builds more pressure than is commanded because it cant return the fuel. So thats something to be careful of.
__________________
LBZ Block, LML Crank, Carrilo Rods, Fingers Pistons 16.5, AF 6480 Cam, ATI damper, Socal Flexplate, Stock Heads, Socal Springs. Exergy 12mm CP3, Exergy 100% injectors, SDP 3" Y Bridge, SDP 3794 68mm Billet, SDP S480 Billet. Mishimoto Intercooler. Tuned by ATP
  #84
Old 07-17-2017, 03:01 PM
Kunz111 Kunz111 is offline
Gearhead
Default
I'll buy/trade you my 61k mile motor for your built motor if you wanna go back to stock.
  #85
Old 07-17-2017, 03:12 PM
S Phinney's Avatar
S Phinney S Phinney is offline
Default
It should not do that but will cause failure from heat build up. All my return god from minimal 4 am to 8 am. I calculated return based off information from exergy on my set and made sure my return exceeded any possible flow on return.
__________________
03 GMC 4x4 CC/SB Intake, Dual Exhaust, built motor by Me, Cognito Kryptonite Suspension upgrades, Custom Traction Bars by Me, Suncoast Trans, 1055-1 Convertor, Two AirDog II 200's, Billet Sump, Venom Tuning AKA Me, Custom Fabbed Fuel system, Flexlite Fans, Best Time to date 7.14 at 98.21 mph 1211.8HP 1954.5 FT/Lb torque
2013 LML Daily Driver, 5" FloPro Exhaust, Venom Tuning, Ad 165 4G Lift Pump, Upcoming HSP Billet Bridge And Piping, Upcoming CP3 Conversion
  #86
Old 07-17-2017, 06:03 PM
Gearhead
Default Return lines
Where did you find (All my return god from minimal 4 am to 8 am.) hose and fitting for the injectors? I can make all the other return hoses bigger if I could get the injectors hoses bigger than stock.
  #87
Old 07-17-2017, 06:09 PM
Gearhead
Default turbo
What would a guy expect to pay to swap turbo's? Do you have to raise the back of the cab to get to the up pipe bolts? I got quoted 850 for 10 hours is that in the ball park?
It was easy to install the turbo on the engine stand. lol
  #88
Old 07-17-2017, 10:11 PM
DAVe3283's Avatar
Default
10 hours is plausible. It is trivial on am engine stand, but sucks hard in the truck. IMO, raising the cab would be quicker than working around it.
If you don't have a bunch of aftermarket stuff running into your cab, raising the cab is probably an hour or two, then the turbo is cake. I'd try and talk the shop down below 10 hours, but really, expect to pay at least 6-8.
Sent from my S60 using Tapatalk
__________________
  #89
Old 07-18-2017, 03:05 AM
Gearhead
Default
Thanks, he came down from 12hr to 10hr trying to help out, because of all the problems I'm having.
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
