  #16
Old 03-07-2017, 11:36 PM
greendury's Avatar
greendury greendury is offline
Default
Well I ordered a set of 100% exergys I hope they work out. I am going to redo the filter setup and the cp3 supply lines to rule any of that out.
__________________
02 GMC Reg cab lb7 2.6 puller sold
03 GMC Ext cab lb7 WS puller.
03 GMC Crew dually lb7 sold
  #17
Old 03-08-2017, 06:25 AM
onebaddmaxxx onebaddmaxxx is offline
Default
You will enjoy it!
__________________
2005 lly
Lots of thanks to Diesels Unlimited, Evan@limitless & Mark@danville
  #18
Old 07-17-2017, 05:44 AM
greendury's Avatar
Default
An update this season. I am running 100% over exergy injectors with the same 12mm pump and will still drop actual rail down to 22000 psi when commanding 26000 during a pull. Pulse is at 2300us. 1/2 inch feed all the way to the pump. Holding 2-10 psi during a run.
__________________
  #19
Old 07-17-2017, 06:54 AM
JoshH's Avatar
JoshH JoshH is offline
Default
Could be a bad pump. Only way to know is to have it tested.
__________________
06 Silverado 4x4 CC/SB
06 Express 2500 Duramax Van "The Dumpster"
  #20
Old 07-17-2017, 07:12 AM
greendury's Avatar
Default
So I am assuming you think the pump should hold 26000. It seems to do better when rpm is 3300 and under but once past 3700rpm sustained when I'm pulling is when it drops.
__________________
  #21
Old 07-17-2017, 07:23 AM
S Phinney's Avatar
S Phinney S Phinney is offline
Default
The pump is rated to 4500 rpms. Do you have a sump? Either something is causing a restriction or the pump has a problem.
__________________
03 GMC 4x4 CC/SB Intake, Dual Exhaust, built motor by Me, Cognito Kryptonite Suspension upgrades, Custom Traction Bars by Me, Suncoast Trans, 1055-1 Convertor, Two AirDog II 200's, Billet Sump, Venom Tuning AKA Me, Custom Fabbed Fuel system, Flexlite Fans, Best Time to date 7.14 at 98.21 mph 1211.8HP 1954.5 FT/Lb torque
2013 LML Daily Driver, 5" FloPro Exhaust, Venom Tuning, Ad 165 4G Lift Pump, Upcoming HSP Billet Bridge And Piping, Upcoming CP3 Conversion
  #22
Old 07-17-2017, 08:11 AM
greendury's Avatar
Default
I do not have a sump pulling from stock pickup. I'm keeping positive lift pump pressure though.
__________________
  #23
Old 07-17-2017, 08:18 AM
Awenta's Avatar
Awenta Awenta is offline
Default
What's lift pump pressure during this?
I think that's your restriction. What size lift pump?
__________________
Arek
2003 CCSB LT LB7 deleted
Some cool stuff, some fast stuff, some slow stuff
EFI by Kory
Special thanks to Evan@Limitless
  #24
Old 07-17-2017, 08:33 AM
greendury's Avatar
Default
It's a ppe 160. Lift pump will drop to 2 psi but will stay positive pressure.
__________________
  #25
Old 07-17-2017, 09:12 AM
WolfLLY's Avatar
WolfLLY WolfLLY is offline
Making Chips
Default
Quote:
My 12mm is holding 29,000 psi on 1800ish pulse with 200% overs. Just for comparisons sake.
__________________
LMM CCSB LTZ Z71. SoCal motor, s485/68r, 1078 Limitless converter, S&S 200s.
LB7 ECSB 4X4
Thanks to Evan@Limitless, Mark@Danville Performance, Josh Harris@Top Notch, and Corbin(crussel)
  #26
Old 07-17-2017, 10:25 AM
IOWA LLY's Avatar
IOWA LLY IOWA LLY is offline
Yes, its really me
Default
Get a good lift pump. And put a sump in it.
__________________
2003 GMC CCSB LLY
Built by me, tuned by me.
2009 ECI Diesel Truck Points Champion
2010 ECI Diesel Truck Points Champion
2011 ECI Diesel Truck Points Champion
2012 ECI Diesel Truck Points Champion
Big thanks to everyone who helps me.
Best 1/8th, 7.29, 98.6MPH (Street tires, fuel only, single Journal bearing GT42 charger) (2010)
Best 1/8th, 6.93, 104.24MPH (Street tires, fuel only, single HX60 turbo) (2016)
Best 1/8th, 6.60, 106.6MPH (Street tires, fuel only, single HX60 turbo) (2017)
  #27
Old 07-17-2017, 10:32 AM
boostwhore's Avatar
boostwhore boostwhore is offline
Drag racer wannabe
Default
X2 2psi is not even close.
__________________
Chad
2007 lmm: kryptonite front end, full billet trans by Sdp, SoCal engine ovals and Carrillos, 12mm exergy stroker, 100 over exergy injectors, sdp billet 68mm over billet 480, tuning from Arron at All in trucks.
  #28
Old 07-17-2017, 10:38 AM
greendury's Avatar
Default
The same lift pump filter setup supported duel fuelers on 80% injector running a 2800us with out dropping rail so i figured it would be sufficient for my current setup. But agree sump and bigger lift pump is a good place to start.
__________________
  #29
Old 07-17-2017, 12:48 PM
Dozerboy's Avatar
Dozerboy Dozerboy is offline
Default
Can't you test the return rate of a stroker pump to find out if it's bad? I won't be throwing parts at this without knowing the CP3 good.
__________________
06 GMC 2500 CCSB SLT LBZ 4X4
These views expressed on this post are not my own, but rather randomly generated computer gibberish, and in no way should be used to judge the author's IQ or mental health.
  #30
Old 07-17-2017, 01:55 PM
gmduramax's Avatar
gmduramax gmduramax is offline
Shits broke
Default
Hook a 5/8 hose to the vent inside your fuel pick up and run that down into the cup. Hook your feed line to the vent. You'll be shocked how small the opening is in the cup.
__________________
2008 GMC duramax crew cab short bed 2500.
10.98@124mph
Thanks to Mike L, SoCal Diesel, and Abel Chevorlet.
Tailgate Crew Member #1
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
vB.Sponsors
