Old 12-08-2017, 04:40 PM
malibu795's Avatar
malibu795 malibu795 is offline
Got close to 4000mile on it.. gearing is good, need to get Engine HP up for most part the 8.3 is still stock fuel wise..
mispeeling wrods n a thraed nere u
07.5 3500hd RCLB LMM GT4088R, 4.56 gears 225/70/19.5 efi live 478k broke block
99 FL60 8.3 12v 13sp
smooth seas never made a skillfull salior
Old 12-08-2017, 07:02 PM
jlawles2 jlawles2 is offline
New tires for the truck?? Singles all the way around. Wide in the front and extra wide in the rear.
Silver Birch Metallic 2004.5 GMC K2500HD with 265/75's
Banks super scoop, tubing, intercooler, and cat back with the IQ on the Window (for now). BD driver side Exhaust manifold.
Airdog 150 on frame rail. Amsoil synthetics for lubrication, and dual Amsoil filters on the driver frame rail. PPE centrifuge install.
EGR blocked. PCV rerouted. Resonator blocked (reinstalled for looks). Bladerunner installed. Dead kitty by MBRP (front pipe) and down tube replaced with the MBRP (heat wrapped from the turbo down to the front pipe).
Performax Gauges by ISSPRO in pod over mirror and overhead console (console pod by PPE). Mike L Transmission.
----Looking to do an onboard air with a set of truck air horns. Want Nathan K5LA's but not in the budget at the moment.----
06 GMC CCSB 2WD LBZ SLT package. Traded for '17 Denali
18 Denali CCSB 2500 4WD Mineral Metallic with Cocoa/Dark Sand Interior
Old 12-08-2017, 07:31 PM
2004LB7's Avatar
2004LB7 2004LB7 is offline
Maybe he's going to enter it into the tractor pulls
2008 Chevrolet 3500HD DRW LTZ
Old 12-08-2017, 07:58 PM
Not really much of a load, but had to give her a little workout, so I did 3 loads of hay this week. Wished I had a better trailer as 10 bales was ALL this trailer could handle. Springs did not look that happy on the trailer. Was loaded down heavy enough it sunk down into his field loading. Had fun on the long drive out through sugar sand, thank God for that lever on the floor, otherwise he would have had to pushed me out with his tractor.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
